Question about Enlight Intel Xeon 470 WATT EN-470 MP (EN470MP) Power Supply
Canon PIXMA MP 470 Photo All in One Inkjet Printer manual
I have jsut purchases this printer and am having problems installing the ink cartridges! Is there a techinque to doing this as the instruction manual and pictures are less than useless!
Thanks
  • 9 more comments
  • Jack Hopkins
    Jack Hopkins Dec 22, 2007
    CAN'T LOAD THE CARTRIDGE
  • kittyjune Dec 23, 2007
    My son and I have tried very unsuccessfully to get the ink cartidges installed into the Canon Pixma MP 470, the pictures in the manual appear straight forward but I cannot see where the cartidges are supposed to click into???
  • Anonymous Dec 25, 2007
    I have a similar problem with the canon pixma mp470 cartridges.Unable to locate position of cartridges,Manual is not helpful..................
  • Anonymous Feb 11, 2008
    hands down the worst sonnova installation manual ever made.......they should fire whomever made that thing. I still can't figure it out even with the technique listed below
    i see why staples gave these things away with a camera purchase i cant do it with the solution listed below either
  • Anonymous Feb 19, 2008
    I been spending the pas 15 min trying to load the stupid cartridges, the cartridge doesnt even align completely on the holder, and there is nothing to click it onto
  • 9286 Feb 19, 2008
    also have that problem, theres nothing for the cartridge to click into.
  • Anonymous Feb 28, 2008
    I had the same problem! Stupid me. I read back to the previous page and I should have plugged it in. When I did, the moter began to run and the cartridges holder moved from the right to the left and the cartridges were able to pop right in to it. The entire problem was the power needed to be on.
  • Anonymous Jan 05, 2009
    **** PRINTER!!!!
  • jencampbell1 Mar 07, 2009
    I bought a canon mp470 which began having printing problems after about 2-3 months of use. I purchased 2 sets of black and color ink cartridges in hopes to resolve the issue with no success. I was not able to align the cartridges with the print head. I thought that the print head was bad possibly. I bought a new printer and the mp470 has been sitting on a shelf. I was hoping to find a part and repair it, but after reading this site, It may just be a defect.
  • barl416 May 05, 2009
    same probvlem awful problem thru at the door!
I figured it out!
For all those who have problems clicking it into place it's probably the printer's not on. Turn it on an the top half of the cartridge holder which is connected to the printing head should slide to the left part of the printer when it's on, then slide the cartridges in an click in.
Posted on Feb 19, 2008
Will not print says here is anerror no 5100
Posted on Nov 07, 2008
  • 1 more comment
  • rwhit18 Nov 07, 2008
    error code 5100 will not print
    the mp 470 popup says we have an 5100 error turn off and backmon does not work have no manuel
    where can I purchase a manuel for this 470 printer
Plug it in. Turn machine on....wait a few seconds until the printer cartridge tray moves itself all the way to the left and stops.
You have to put them in with the front bottom side of the ink cartridge resting on the tray and cartridge back as far as it will go. Gently push the cocked ink cartridge up until it clicks in place.
Best I can explain.
Posted on Jun 15, 2008
I spent the past hour trying to insert the ink cartridges. My problem turned out to be that the holders were, for some reason, on the right rather than the left side of the mechanism. I gently pullled them to the left and was then able to insert the cartridges. Super frustrating. I spent 60 minutes thinking that I wasn't as smart as a 5 year old but it was the freaking machine's inability to posiiton the cartridges holders correctly that was to blame.
Posted on Nov 29, 2008
The installation is easy .. so easy than a 5 year old kid could do it.
all you have to do is read..it's on the manual!!
Posted on Apr 21, 2008
The great big red-n-white "quick start" guide - to me - made the cartridge installation MUCH easier. Mine slid in at a slight angle just as Canon noted they should ... then snapped UP into place with a secure "CLICK!". Absolutely ZERO problems on the first try - and this prints like a PIXMA alright: First print was dead-on perfect.
Posted on Feb 12, 2008
I also just set up this printer. Inserting the cartridge is tricky but not diificult. Just plave the cartridges in the each slot until they can no longer move forward. Then you simply the cartridge up until you the hear the click, you have to use a little force to ensure it clicks.
Posted on Dec 28, 2007
Thank you so much! I turned it on and the cartridge went right in!!
Posted on Apr 30, 2008
SOURCE:
What type of ink cartridge does this cannon pixma mp 160 printer use
Look inside the instruction book that came with the printer. It lists the proper number of the items required even Ink for your printer. You have to buy the right size. Or look online on the web under Canon PIXMA MP160 All-in-One InkJet Printer. Maybe even just look under Canon Printers and it will lead you to the correct type number of ink cartridges required for your machine. Make sure you get the correct number, size etc....and follow directions how to install. Did you know, I found out Ink Cartridges are ALMOST the SAME PRICE AS The Entire Printer???? that ink costs a bundle! at least me, I think I found my Ink replacements online purchase on sale, at OfficeMax. I had to orderr online, then go pick it up at the store itself. It was more expensive than the printer was! what the heck?????julie
Jul 04, 2014 | Canon PIXMA MP160 All-In-One InkJet...
My Pixma MP 150 is flashing E 5. Any remedy?
Mainly this error is related to ink cartridge. 1 Its setting - installing/removing 2 Replacing 3 Re-seating 4 Installing the correct ink cartridge.
If you have the user guide/manual with you can do it yourself.
If the above process does not solve the problem then it means that the printer require repair for which you have to refer to the nearest Canon service center
Sep 05, 2011 | Canon PIXMA MP150 All-In-One InkJet...
Mty printer is a PIXMA MP 470 it has an error code saying 'print head is not installed, install print head' It wont do anything or let me even go onto the menu??????
There are 2 ink cartridges that came with the printer (PG-40 and CL-31). These are the consumables that are also print head. You must install these in your printer.
Follow the setup guides/manuals that came with your printer. If you can't find them, they're downloadable from Canon's website.
http://support-ph.canon-asia.com/EN/sear...
hope this helps you.. please kindly vote.. thanks
May 19, 2011 | Canon PIXMA MP170 All-In-One InkJet...
What is error e5 in mp 198 printer
E5 - The ink cartridges are not installed or a non-supported ink cartridge is installed , or the ink cartridges are not installed properly..
  • In certain models of Canon Pixma printers such as the Canon MP160 and Canon MP150, you may receive an E5 error when trying to print. In this state, you will not be able to use any of the functions of your printer. The error itself is an ink cartridge error. It may be that you are using generic or off-brand ink cartridges in your Canon Pixma printer. Canon Pixma printers do not work with other brands of print cartridges; invest in Canon brand ink cartridges and this should take care of your problem.
  • Nov 18, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
    E5 flashing - do not want to use colour ink
    use any color cartridge that is no sort & see canon error e5 solution
    Jul 21, 2010 | Canon MP140 PHOTO AIO All-In-One InkJet...
    Is MP210 and MP240 the same? can i use the same cartridge?
    no both are different
    Here are the list of cartridges u can use
    MP210
    PG-30 Pigment Black
    PG-30 Pigment Black Ink Cartridge
    PG-40 BLACK
    CL-31 Color FINE Ink Cartridge
    CL-41 Color
    MP240
    PG-210 Black Cartridge
    CL-211XL Color Cartridge
    CL-211 Color Cartridge
    PG-210 XL Black Cartridge
    Nov 28, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
    Canon pixma mp 145 E4 problem
    Dear Sir,
    Error Code E4 = No ink.
    Generally printer doesnt recognise refilled ink.
    Try the to reset the ink catridges
    by mp tool software,mptool reset the printers canon pixma series like MP150, MP160, MP170, MP180, MP450 and MP460.And there also facility to write and read EEPROM in the printer. Other excess this software is detect automatically installing printers in the computer.
    Download Mp tool
    i think it solves your problem,But the actual procedure and best solution is replace the ink catridges,according to canon new genuine canon ink catridges save your printer life also.
    if you find any difficulty leave a feedback,we will glad to assist you
    good luck
    Sep 08, 2009 | Canon PIXMA MP160 All-In-One InkJet...
    Use of High yield Cartridges in Canon Pixma 150
    have u tried to remove the cartridge again, proably some contact problem
    May 27, 2008 | Canon PIXMA MP150 All-In-One InkJet...
    Open Questions:
    See all Enlight Intel Xeon 470 WATT EN-470 MP (EN470MP) Questions
    Computers & Internet Logo
    5,737 people viewed this question
    Top Enlight Computers & Internet Experts
    Ekse
    Alun Cox
    Are you an Enlight Computer and Internet Expert? Answer questions, earn points and help others
