Question about HP LaserJet 4600dn Color Printer
Problems during warm up
On powering up the printer, it goes through the initializing process but stops at the 'performing calibration' stage. Sometimes it then goes through the motins and is in the 'Ready' status but when it comes to printing from the computer, this is intermittent and sometimes not at all. Any suggestions as to fixes would be appreciated.
  • Anonymous May 15, 2008
    Printer hangs during power up. Sometimes at the memory check, sometimes at the "Initializing..." or "Calibrating". First sign of any trouble was an EIO error message that I didnt note down.
  • 89 Answers
Have you tried updating the firmware. You can get the updates at http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?lang=en&cc=us&prodNameId=74303&taskId=135&prodTypeId=18972&prodSeriesId=74301&lang=en&cc=us
If that does not solve it you may need to try increasing your memory,
Hope this helps.
Posted on Nov 29, 2007
When I open the toolbox for the LaserJet 2600n printer, it tells the website is not available. I need to clean the jets etc.
You need not to clean laser printer cartridges,it may color or mono. Print cartridges them selves having cleaning blade to clean the surface of the OPC drum every time when its initializing or printing. If you found any vertical tracks on print outs replace the particular cartridge.. If you have any kind of print quality issue,perform calibrate process through printer menu..quality..calibrating.. even if you found quality issue clean the Laser scanner assm.(professionals only can do)
Oct 28, 2011 | HP Color LaserJet 2600n Printer
CM 1015mfp Colors are not aligned. when printing the characters looks like 3D.
If nothing else works, you may have to manually calibrate the dials inside the mirror box. This video link will show you how. http://youtu.be/R1DIko0a1MA
This may be necessary if the printer got bumped really hard.
Aug 17, 2011 | HP Color LaserJet CM1015 Printer
Por que me sale an internal error in the initialization stage
Initialing stage is indication that the computer is undergoing restore to system default. First, at which stage where the computer stops performing restore is indication that disk is either scatched or dusty requiring cleaning. Power shut the computer completely from the shut off button because attempting to press the disk button instantly would cause impact that may damage the restore disk. Power on the computer from the power on button area. Immediately press the disk button to before the computer attempts to capture the media in disk driver. The computer disk driver should pop open immediately to make available the disk. At which point, inspect the restore disk for scratches or dust by simply cleaning with clean tissue paper. Also, observe the disk for compartibility with the computer systems. For example a computer performing on windows XP would least require update restore with disks that are Windows 7. Discontinue restore if realised that the computer is inconpartible to the disk attempting to derive restoration from. If the condition was due to dusty or scratches, simply cleaning the disk should make commenceable the restore process.
Feb 08, 2011 | HP Pavilion dv6000z Notebook
At a startup performing calibration initialization long HP Color Laserjet 4600dn
Calibration bypass
During certain diagnostic procedures, you will need to bypass the automatic calibration that is
performed whenever the printer is turned on.
To bypass calibration
1 Turn the printer on and watch the control panel display.
2 When the display begins showing the memory count, press and hold until all three lights on
the control panel are lit.
3 Press .
4 Press PAUSE/RESUME. The display should show SKIP DISK LOAD.
5 Press until SKIP CALIBRATION is highlighted.
6 Press . The printer will skip calibration and then continue its power-on sequence.
Please refer here for further details if required
Let me know if any further clarification is required. Hope this helps!
CreativeTECH
Nov 26, 2010 | HP LaserJet 4600dn Color Printer
Reader 6oo Touch : calibration error detected.
This error indicates that an issue occurred during the calibration procedure. Follow this procedure to resolve this issue.
1. Using the stylus, tap the "X" to restart the calibration process.
2. Tap the center of each "X" that appears on the screen.
3. When "Touch Panel calibration completed" is displayed, click "OK".
After performing the above steps, the issue should be resolved.
If the issue still persists, perform a soft reset. To soft reset the Reader, press the RESET button using a sharp-pointed object.
If unfortunately the issue still didn't resolve, service of the Reader may require. Follow the below link to initiate the repair: http://eservice.sony.com
Feb 04, 2010 | Sony E-reader Portable E-book MP3 Player
Recalibrate process
1. Using the stylus, tap the "X" to restart the calibration process. 2. Tap the center of each "X" that appears on the screen. 3. When "Touch Panel calibration completed" is displayed, click "OK".
Dec 25, 2009 | Sony Reader Touch PRS-600
Machine freezes and needs to be restarted, but buttons freeze. Must restart by unplugging and using reset, the 6 and # keys. Then it waste too much ink realigning. wirless setup will sometimes freeze the...
we need to perform a reset, it will take the pritner to the factory settings and this may help you,
the process of reset goes like.
unplug the power cable from the pritner >
then press and hold down the # key and 6 key >
while pressing and holding these keys plug in the power cable back into the printer and wait for 20 secs and then release the buttons..
after this the printer will re-initialize and this might take few minutes.. so wait untill it finishes and follow the onscreeen instruction as well.(if any)
Nov 03, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
Can't stop the printer calibrating
No guarantee this will fix your problem, but the last time I experienced this problem it ended up being one of the toner cartridges. I replace her refurb. toners to OEM brand.
Jun 02, 2009 | HP LaserJet 4600dn Color Printer
Ink system failure
Follow the below steps on the front panel of the All-in-One printer:
A. - Press and Hold the “Print Photos” & “Red Eye Removal” buttons. Release both buttons. Display should say “Enter Special Key Combo”
B. - Press and release in sequence “Red Eye Removal”, “Print Photos”, “Red Eye Removal”
display says: "enter special key combo"
C. - Press and release in sequence “Red Eye Removal”, “Print Photos”, “Red Eye Removal”
display says: "uiaux"
display says: "support COxxFN0723BR"
Perform the below steps:
2. Press and release the right arrow button until the display says “System Configuration Menu”. (on C8100 use Touch Screen)
3. Press and release the “OK” button.
4. Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status
5. Press and release the “OK” button
6. Display should say “Hardware failure status: Clear. Press OK to clear”.
7. Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
8. Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
9. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
Make sure that you perform steps from 2-9.
10. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
11. Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK.
12. If the printer has already initialized, then go to the next step. If not, the printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
13. To verify printer functionality print a SELF TEST PAGE.
Please perform all the above steps from 10 to 13 .
Jan 06, 2009 | HP Photosmart C6280 Printer
HP LaserJet 4600dn Color Printer Logo
155 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
