Transcend 32GB ExpressCard SSD, MLC 32 GB Hard Drive
Problem for Transcend 32GB ExpressCard SSD, MLC 32 GB Hard Drive
Pendrive Shows Write Protected
By c_wintech on Aug 12, 2009
I am using Transcent 2GB pen drive,When I connect it to PC It shows Removable Disk.But when I double click it, It shows a dialogue box to format the same.When I choose Yes to fomat ,a dialogue box appears ''The Drive is write-Protected''.There is no Switch on it.Could you help me...Please..
Solution #1
posted on Aug 12, 2009
Not Rated)
955_mike
Rank: Master
Rating: 75%, 1 votes
Two things to try here. If your pen drive came with a mini cd then load the driver from the cd. If it didn't then try the pen drive on a different pc.
I do not have a Transcend pen drive, but all of my other ones either have a micro switch located on them (sometimes very hard to find) or they need to be formatted from within windows using a tool fom the transcend website below.
http://www.transcendusa.com/Support/DLCenter/index.asp
Was this helpful?
Yes
No
Solution #2
Not Rated)
male_28_cam
Rank: Wiz
Rating: 85%, 272 votes
These are the tech specifications of your pen drive which includes write protection micro S/D switch. So search it and make it read and write
USB 1.1 compliant and 2.0 compatible,
True Plug and Play for hot swap function
Maximum Transfer speed of 1.5MB (12M bit) per second at full speed
Powered directly via the USB port.
No external power or battery needed.
Operating Systems Supported: No driver required for Windows Me/2000/XP, Mac OS 9.0 or later, or Linux kernel 2.4 or later.Only Windows 98SE needs the provided drive
Write-Protect Function: Write-protect switch Security Function: Password protection available via supplied software (Windows environment only) Boot-Up
Function: Makes JetFlash a MS-DOS Boot Disk LED: Flashing LED indicates
Data Traffic Specifications : Size: 75mm X 11mm X 25mm (L x W x H)
Weight: 15g Data Retention: Up to 10 years Shock Resistance: 1000G (maximum) Erase Cycles: 1,000,000 times Speed: Read 9.0 Mbyte/s, Write 8.0 Mbyte/s (Max.) Certificate: FCC, CE,
BSMI System Requirements: Win 98/98SE/ME/2000/XP, Linux Kernel 2.4 and above, Mac OS 8.6 or later
Was this helpful?
Yes
No
Popular Solutions for Transcend 32GB ExpressCard
Questions and Unsolved Problems for Transcend 32GB ExpressCard
Do you recommend Transcend 32GB ExpressCard SSD, MLC 32 GB Hard Drive?
Answer
Answer
i santanu from kolkata. my 64gb pen drive asking for formatting.trying so many times.help me
Answer
when insert my 4GB pendrive my computer does not read it
Answer
my transcend JetFlash 4 GB drive got detected but I can't access it...the error said please insert a... (More)
Answer
I have 2 gb pendrive transcand. it has problem of detect. i want to repalce it but i have lost my... (More)
Answer
i have an external hardisk wd500 and an ibm laptop. the problem is when i copy/cut a file from my... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Transcend 32GB ExpressCard...:
Top Hard Drive Experts
Rank: Guru Guru
Solutions: 14885
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Hard Drive Experts
Top Computer & Laptop Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
