Question about Xerox DocuColor 12 Printer
Top Margin print cut
I have problem in dc 12 , that was 12x18 size print is cut in buttom
I get extra margin top side how i can solve this problem
plz give a solution
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
If you are using the bypass (tray 5), you need to move the limit of your tray from the normal position to 12" position.
Hope this help.
Posted on Dec 18, 2007
SOURCE:
Left margin cuts off
Try changing the left margin size in the page setup. Decrease the left margin size.
You could also try printing in Landscape instead of Portrait just to see if it captures the left margin.
May 31, 2012 | Samsung CLX-3175FW Multifunction Laser...
The printer cuts off the top part of the document when printing. Is this a margin issue?
Yes, most likely your application's margin settings are incorrect. Try printing a test page - NOT from the application. If this is Windows, go to printers in control panel, right-click on the subject printer, choose Properties, then click the Print Test Page button. You should get the standard Windows printer test page with the logo at the top and all the printer specifics below. If the test page is also cut off, look around in the HP-provided software for any margin and/or page size settings that are incorrect, such as A4 paper when it should really be Letter size.
Feb 18, 2011 | HP Officejet Pro L7680 All-In-One Printer
Windows driver
.Normal{margin:0.0pt;margin-top:0.0pt;margin-bottom:0.0pt;margin-left:0.0pt;margin-right:0.0pt;text-indent:0.0pt;font-family:"Times New Roman";font-size:10.0pt;color:Black;font-weight:normal;}H1{margin:0.0pt;margin-top:12.0pt;margin-bottom:3.0pt;margin-left:0.0pt;margin-right:0.0pt;text-indent:0.0pt;font-family:"Arial";font-size:18.0pt;color:Black;font-weight:bold;}H2{margin:0.0pt;margin-top:12.0pt;margin-bottom:3.0pt;margin-left:0.0pt;margin-right:0.0pt;text-indent:0.0pt;font-family:"Arial";font-size:16.0pt;color:Black;font-weight:bold;}H3{margin:0.0pt;margin-top:12.0pt;margin-bottom:3.0pt;margin-left:0.0pt;margin-right:0.0pt;text-indent:0.0pt;font-family:"Arial";font-size:14.0pt;color:Black;font-weight:bold;} .Normal{margin:0.0pt;margin-top:0.0pt;margin-bottom:0.0pt;margin-left:0.0pt;margin-right:0.0pt;text-indent:0.0pt;font-family:"Times New Roman";font-size:10.0pt;color:Black;font-weight:normal;}H1{margin:0.0pt;margin-top:12.0pt;margin-bottom:3.0pt;margin-left:0.0pt;margin-right:0.0pt;text-indent:0.0pt;font-family:"Arial";font-size:18.0pt;color:Black;font-weight:bold;}H2{margin:0.0pt;margin-top:12.0pt;margin-bottom:3.0pt;margin-left:0.0pt;margin-right:0.0pt;text-indent:0.0pt;font-family:"Arial";font-size:16.0pt;color:Black;font-weight:bold;}H3{margin:0.0pt;margin-top:12.0pt;margin-bottom:3.0pt;margin-left:0.0pt;margin-right:0.0pt;text-indent:0.0pt;font-family:"Arial";font-size:14.0pt;color:Black;font-weight:bold;}
The entire installation cd here: http://d01.megashares.com/index.php?d01=6b830bb. It‘s an image file that you‘ll have to burn to a cd. You can use a Nero, Imgburn, Roxio, or any program that will burn aniso image to a blank cd. Burn the cd, install the driver, and then start using your webcam!
Apr 03, 2010 | Radio Shack VGA PC Camera Webcam
Printing Legal size brochure (landscape) that gets cut off
readjust the margins in the printer page set up just before printing
Sep 08, 2017 | HP Inkjet 1200D Printer
Always prints more to left than established margin
Check you Page Setup andmargin set. Sounds like the page isn't set up properly. When you typing a document, go to the FILE then PAGE SETUP. Margins and Paper Layout.
Hope this helps. Bud
Jan 08, 2009 | Lexmark Optra T610 Laser Printer
Printing document
Did you change the top margin setting?
Make sure that the paper size is correct in the printer settings of the control panel when you print. You have to tell it what size paper you are printing on.
Aug 15, 2008 | Sharp AL-1551CS Copier
HP PCS 750 cuts off bottom of 8 1/2 X 11 page when printing. Auto reduces page.I need 100%.
The PSC 750 cannot print a full borderless page, it requires a bottom margin of 0.46", a top margin of 0.08" and side margins of 0.25" when printing on 8.5x11 pages.
Regards,
Bob Headrick, MS MVP Printing/Imaging
Jul 04, 2008 | Office Equipment & Supplies
Printer cuts off top 1 inch of PDF document
Go to the printer properties and try setting it up with border less printing.
Cheers
May 23, 2008 | Lexmark X4270 All-In-One InkJet Printer
Margin printing problems
Check your application's print settings (for e.g. MS Word). Then check the printer's properties and print settings. If nothing works you also try re-installing the latest printer driver. If you use MS word should check the page setup option, for paper size errrors. If the color of your margin is red and the red ink is out then you won't se the margin line.
Oct 09, 2007 | HP Color LaserJet 2600n Printer
Paper margin problem in pagemaker application
Do you mean the left margin is too large so all the content is shifted to the right and off the page? If this is the case, it is probably a setting in Pagemaker. In the file menu, choose "page setup" or "print setup". Check the paper size. Check the margins.
Jun 24, 2006 | HP Color LaserJet 2600n Printer
Xerox DocuColor 12 Printer Logo
282 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Clive
Clive
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
