Depending on the depth of the scratch, you should be able to sand them out- this does require basic knowledge of grit progression and also requires practice going straight with the grain. Try first with a 180 grit paper, you may be able to finish sand with this grit. The final grit or "grain" is between 180 and 240. After the final sanding which "stretched" the area use a scotch brite #7447 pad. The pad purchase at a Nappa or Carquest type store. While there buy the sticky back sand paper- its easier to keep going in straightline with grain. Start out with light pressure till you are confident in maintaining straight sanding. Finish cleaning and maintaining with DeBruce Polish. Debruce Polish is non-toxic and odorless- its all we use on our stainless steel and cook tops. We buy DeBruce Polish at debrucepolish.com, you will love it. Be patient.
Was this helpful?
Yes
No
Popular Solutions for Thermador 37 in. SGSX365 Gas
I need an electronic control parts #189807 for my model CT130S-2. Have been told it is discontinued....
(More)
I need an electronic control parts #189807 for my model CT130S-2. Have been told it is discontinued. Can you help?
Need Thermador printed instructions re: installation of Cross Flow Magnetron Tube Kit 35-00-69....
(More)
Need Thermador printed instructions re: installation of Cross Flow Magnetron Tube Kit 35-00-69. Literature number 582341 was 96-93-570. PDF or DOC or high res JPEG. Thank you from New Jersey.
