Question about Lands Phones
How to set dial seeting as tone from pulse in Panasonic KX-TC1000BXB
I just got Panasonic KX-TC1000BXB Cordless phone. i have connected phone to Line, but when i am dialing any number it is dialing in old fashion way.
The Telephone Line is capable to Tone dialing.
How to program this cordless handset to work as Tone Dialing.
Thanks & Regards,
Harry
  • pourdadp Aug 16, 2008
    my panasonic kx-t7433 dial in pulse mode.how can i chang to tone dialing?
SOURCE:
  • 7 Answers
SOURCE: Cordless phone
press menu then globel setup and then press dial mode then change the the dial tone you want
Posted on Nov 10, 2007
SOURCE: Dialing mode option change.
Program --> Auto --> ** --> Program (Pulse to DTMF)
Program --> Auto --> ## --> Program (DTMF to Pulse)
Posted on Dec 22, 2007
cnavarro
  • 2460 Answers
SOURCE: Registering a new cordless handset
It doesn't exactly "register" but you turn it on via phone programming.
Just plug it into the headset jack, then select a button to program and press PROG (the button) and dial 67 enter.
When you press the button, the light will turn on and the display will say HEADSET ON. Pressing it again will turn it off.
Carl
Posted on Sep 28, 2008
SOURCE: Pulse dialing
Setting for Tone: Phone is OFF, then press and hold CHANNEL button for 2 secs until beeps, then press TONE *
Setting for Pulse: Phone is OFF, then press and hold CHANNEL button for 2 secs until beeps, then press #
Posted on Aug 03, 2010
SOURCE: GE cordless phone
To set for Tone: Ensure the phone is OFF, then press and hold CHANNEL button for 2 secs until beeps, then press TONE *
To set for Pulse: Ensure the phone is OFF, then press and hold CHANNEL button for 2 secs until beeps, then press #
Posted on Aug 04, 2010
Where can I get a telephone manual for Panasonic KX-TG2205W
Hope this helps
Panasonic Telephone KX-TG2205W User Guide ' ManualsOnline.com
www.manualsonline.com > ... > Communications Panasonic > Panasonic Telephone
2.4GHz Digital Cordless Phone. Model No. KX-TG2205W. Pulse-or-tone dialing capability. OperatingInstructions. Charge the battery for about 15 hours before ...
Apr 02, 2017 | Panasonic Lands Phones
Selecting dialing mode
The directions for changing the dialing mode from tone to pulse can be found in the owner's manual for the main base unit.
Press the [MENU] button then choose "Set tel line". Then choose "Set dial mode", then choose Pulse or Tone and press [OK].
Additional details can be found in the below link.
http://service.us.panasonic.com/OPERMANPDF/KXTG1031.PDF#page=14
Jun 28, 2014 | Panasonic KX-TGA101S Cordless Handset
Changing from pulse to tone panasonic phone
Touch the following keys: Menu 0 5 1 and then select 1 (tone, the factory default) or 2. Then Save (a softkey with the label in the LCD screen) and Off (opposite Talk on the keypad).
The manual for the Panasonic KX-TG5664 is available from Panasonic here: http://service.us.panasonic.com/OPERMANPDF/KXTG5664.PDF . See page 17 for setting the Dialing mode.
I hope this helps.
Apr 06, 2013 | Panasonic Lands Phones
Hello, could you please help me with my panasonic kx-tc1200bx? How can I switch tone/pulse dialing tone? Thanks! Best Wishes.
The owner/user manual should have instructions on how to accomplish this. I take it that you no longer have the manual, so you'll have to root around in the phone's settings (you may have to access the tone/pulse setting from the base unit), to select the desired dialing mode. On some older phones (including cordless), the tone/pulse selection is a physical switch on the base unit (on the top/bottom/side/back). Look carefully... I hope I've helped you!
Aug 13, 2009 | Lands Phones
Both phones have no dial tone and don't work - could it be because they don't support digital?
Hi, Welcome to FixYa.
The cordless phones supports pulse dialing than tone now a days.
If your provider supports pulse dialing & tone you can just change the tone to pulse to use cordless phone. Otherwise you have to request for pulse dialing from your provider.
We appreciate your feedback; it will help us improve this Web site.
Please select 'YES' if satisfied.
Jul 08, 2009 | Panasonic KX-TG2352 Cordless Phone
Need to change phone back to tone dialing
Here's what the manual says: Changing the Dial Mode (Tone or Pulse Dialing) (HS1 only) Your phone can communicate with the telephone network in two different ways: tone dialing or pulse dialing. These days, most phone networks use a method called tone dialing, so your phone comes programmed for tone dialing. If your phone company uses pulse dialing, you need to change your phone's dial mode. If you don't get a dial tone or can't connect to the telephone network, follow the steps below to modify your phone?s settings: With the phone in standby, press and hold [cid/menu]. Press [vol/ / ] to move the pointer to select DIAL. Press [select/channel] to set the phone to pulse dialing. Press [end]. Return the handset to the base. The handset communicates the new setting to the base, and the base activates the setting on any other handsets. Hope this helps out. K
Jun 05, 2009 | Uniden 2.4 GHz Cordless Phone System
Change pulse into tone
Go to the menu and choose Tel line and the go to set dial mode and then choose the dial mode like dial or pulse mode
Nov 22, 2008 | Panasonic KX-TG2631 Cordless Phone
TC1200 TONES/PULSES
There is usually a switch to change it from dial pulse to touch tone.If there is no switch check your user manual to see if there is a screen option.
tk46
Jun 19, 2008 | Panasonic KX-TG1033S Cordless Phone
Panasonic cordless phone KX-TG6052
reset the dial mode if it is on tone and you have pulse it will not dial out.
Feb 08, 2008 | Panasonic KX-TG6052B Phone
Lands Phones Logo
255 people viewed this question
Top Lands Phones Experts
Ekse
Marvin
Marvin
Are you a Lands Phone Expert? Answer questions, earn points and help others
