Hi Oye!
Here is all avalible drivers for your HP M1005 MFP
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?lang=en&cc=us&prodNameId=1839459&taskId=135&prodTypeId=18972&prodSeriesId=1839458&submit.y=4&submit.x=9&lang=en&cc=us
Select the OS you running and download the drivers you need
Good luck
Nic
You can download your driver from http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=1839459&lang=en&cc=us&prodTypeId=18972&prodSeriesId=1839458&taskId=135. Just choose your OS type first.
Regards,
Jeep Brainy
SOURCE: HP Laserjet M1005 MFP scanner and printer shows
The job that you are trying to print is too complex for the printer. Add more memory. Or simplify the job.
SOURCE: hp laserjet m1005 mfp printer, but it's cd was crack
You can downlaod the original drivers and software from the following link.
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=1839459&prodTypeId=18972&prodSeriesId=1839458&swLang=8&taskId=135&swEnvOID=228
SOURCE: my HP Laserjet m1005 mfp
If the message is Scanner Error 6, then there is an error in the scanner subassembly.
Try powering printer off, wait about 30 seconds and power on. Make sure printer is not plugged into a 'surge protector'. You want it plugged directly into a wall outlet.
If error doesn't go away, the scanner assembly has to be replaced.
SOURCE: driver for HP laserjet M1005 MFP printer for
Here is the Driver and Software download page for your HP Laser Jet M1005 at hp.com:
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?lang=en&cc=us&prodNameId=1839459&taskId=135&prodTypeId=18972&prodSeriesId=1839458&lang=en&cc=us
1. After you click on the link above, select the language for your printer driver from the drop down menu.
2. Select the version of Windows 7 you have. (either 32- bit or 64-bit)
3. Save the file to a new folder on your desktop. (It will be easy to locate after downloading it)
4. I would also download the Windows 7 Print Driver - Installation Instructions save it to the folder on your desktop and read it before you install the printer driver.
