Back to:
Tags:
Fuji GX680 III S Medium Format Camera
Fuji GX680
By Duke - usenet poster
I own Fuji GX680 with 180 and 300 mm lenses as well as other
accessories. Sometimes I feel I am not getting what I should
from this expensive camera. For example, the same object
shot with Nikon F4 appears better than the result from Fuji
GX680.  They say the lenses (Fujinon series) are excellent,
but the sharpness of resulting images do not seem as they
should be.  I am not sure whether such results come from
minute misadjustment in the lens attachment mechanism or
whether they are the inherent limit of the lenses'
resolution.   I would like to communicate with photographers
who own the same camera or have experiences with it,  hear
their opinions and improve my knowledge and skill if I am
missing something. Please contact me through this group or,
for continuous future contact, e-mail me.  Thanks.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Aug 09, 2005
FixYa! (100)
pandamama
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
I also doubt the problem is with the glass. But why assume? Buy a test target
on film and tape it to the film plane of your camera. Then take the lens out of
a slide projector and use the projector as a light source to project the image
of the test target through the camera lens. Compare the results with a test of
another lens you have confidence in. I bought my 6x6cm test target from Four
Designs, 9400 Wystone Ave, Northridge, CA in 1993. It is a multiple image of
the 1951 USAF test target. You can determine resolution in terms of line-pairs
per mm but you have to make your own subjective determination of pass/fail at
any particular resolution level. This is the reason for the reference lens.
Presumably you will apply the same subjective pass/fail criterion to both
lenses.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Fuji GX680:
I don't want to Accept this solution
Solution #2
Not Rated (0)
Ross
Rating: 0%, 0 votes
        But be sure to read the fine print. There are limitations
that you should be aware of.
Regards
 John S. Douglas                         Photographer & Webmaster
 http://www.darkroom-pro.com - http://www.darkroompro.net
     Formulas, Facts and Info on the Photographic Process
On Sat, 02 Feb 2002 04:13:05 GMT, Pam Niedermayer
Thank You!
Solution #3
Not Rated (0)
man1
Rating: 0%, 0 votes
That's what insurance is for.
Pam
Pamela G. Niedermayer
Pinehill Softworks Inc.
600 W. 28th St., Suite 103
Austin, TX 78705
512-236-1677
http://www.pinehill.com
Thank You!
Solution #4
Not Rated (0)
Rogers
Rating: 0%, 0 votes
Thanks for advice.  According to Fuji Film web site, all repairs of GX680 appears
to need to be shipped to New Jersy.  I am a little apprehensive about shipping this
expensive camera and accessories this far, though.
Thank You!
Solution #5
Not Rated (0)
herself
Rating: 0%, 0 votes
Consider sending it to Fuji's professional camera repair department.  I had one
repaired once and the price was very reasonable and of course the work was
flawless.
God Bless,
Don Allen
http://www.DonAllen.net
Photos + a large set of photo links including my PHOTO BOOK LIST - NOW WITH
BOOK REVIEWS!!!!
Thank You!
Solution #6
Not Rated (0)
Jimmy NY
Rating: 0%, 0 votes
Check if all tilt and shift controls are in their neutral positions (tilted
lens *may* account for the lack of sharpness...)
If they are -  get the camera to a *qualified* repair technician. The
focusing screen, the lens mount or the mirror may be misaligned, the
focusing mechanism may need adjustments, or the entire mirror box has been
moved (say, possible if the camera takes a hard fall...)  There is also a
possibility that the film magazine mount has been somehow moved, or that the
pressure plate in the magazine is busted.  In short - have the camera, all
magazines, viewfinders AND lenses checked by a pro Fuji repair person.
I have neither heard of, nor experienced the type of problems you are
reporting in many years of shooting catalog photos with the 680 Fuji.  To
the contrary - in terms of sharpness, contrast and the lack of internal
flare the lenses for Fuji 680 are second to none IMO.
Michael
Thank You!
Solution #7
Not Rated (0)
Hart
Rating: 0%, 0 votes
Thanks a lot to all who responded to my posting.
Fuji GW680 is a kind of large-format camera except the film
size, and the construction is completely different from that of
Fuji 690 and accordingly uses lenses specifically designed for
it..   Because of its heavy weight it is practically impossible
to use it without putting it on a sturdy tripod.  I usually use
5 m electronic release cable.  So vibration should not be the
problem.
As Anthony Polson suggested, it is possible that the distance
between the lense and the focussing screen and that  for the
film plane may not be set correctly so that precise focussing
obtained on the screen is not transferred to the film plane when
the mirror is lifted.  There is practically no wiglling room for
how to place a focussing screen.  In my opinion, the mechanism
to hold a focussing screen on the camera body is not very firm,
perhaps a small sacrifice for quick change. I do not know,
however, if this causes discrepancy in focussing between the
screen and film plane.  I wonder if the mirror's rotating axis
might not be set or constructed correctly or if the mechanism to
hold the mirror at the precise position when it is lifted might
be loosened for some reason.
If anyone owns this camera and experienced problems which might
be ascribed to a mechanical construction such as above, please
tell me about it and how it is dealt.
Chiropter
Thank You!
Solution #8
Not Rated (0)
Bouncy
Rating: 0%, 0 votes
I agree with all the other raves about Fuji lenses.
I've rented the 680 as well as a couple of 617's. I also own a 617 and a
GW690II. Fuji lenses are the breathtakingly sharp.
The problem lies elsewhere.
Rob
Thank You!
Solution #9
Not Rated (0)
lawyer
Rating: 0%, 0 votes
Have you checked the focus accuracy? A couple of ways to do this. One is to
put a ground glass on the film plane and check the focus on the focus
screen, then fire the shutter on bulb and check it at the film plane.
Another is to set up something like several cards at different distances
from the camera a few inches apart, then focus on the middel one and see if
the middle one is in focus on film.
Are you sure it's not camera shake somehow?
As far as the lenses, I have a fuji 6X9 65mm GSW and have cropped a 35mm
section from the center of the film and it's just as sharp if not sharper
than GOOD olympus zuiko prime lenses. I'd be shocked if it was the glass.
  Stephe
Thank You!
Solution #10
Not Rated (0)
Powe33
Rating: 0%, 0 votes
There are several possible reasons, included among which are:
1)  Your mirror needs re-setting by a competent repairer,
2)  Your focusing screen is incorrectly seated,
3)  Your eyesight is not what it used to be, <g>
4)  You are in the habit of using over-wide apertures that offer
    little depth of field to cover small errors in focusing,
5)  You are not able to hold the camera sufficiently steady (it is
    VERY heavy!) and/or you aren't using a tripod when you should,
    especially when using slower shutter speeds.
Try renting or borrowing a medium format AF SLR (Pentax, Contax,
Mamiya) and use it on a tripod making sure you locate carefully
the camera's focus point on the subject.  If you find that the
results are sharp you should address the problem areas I listed,
one by one, until you identify the problem.
I hope this is useful.  Good luck!
Best regards,
Anthony Polson
Thank You!
Can you Help with these Film Cameras problems?
Film Cameras
yes, I still use film & went on camping trip recently,...
Film Cameras
how can I clean the viewfinder on my linhof 6x9 super...
Film Cameras
A friend game me an Olympus XA1 Camera with an Electronic...
Film Cameras
I recently picked up a Ricoh KR10 Super. The problem is...
Film Cameras
Hi, as you advised we removed the bottom of the camera and...
Loading problems.
Repair Service
Find Film Camera Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
