Question about Acer AL2016W 20" LCD Monitor
X193wlcd monitor i need help. have purchased 19"acer monitor.cd rom disc that goes wih it only goes to "which language". noone at acers office in plymouth will help ,in fact they were quite rude. my problem?, simple how do i reduce screen brightness? please email me at [email protected] acer instruction book says there is brigtness and contrast but avoids telling you how to adjust. acer"s assistance is non existant.please put this right
On mine you can adjust brightness with buttons on the front. The button under the R gets you in, far left to exit.
Got a phone number for ACER? I can't get it to work with WIN2K, just WIN98SE by using powerstrip.
Posted on Dec 20, 2007
SOURCE:
CANNOT EJECT DISC IN ACER
every cd rom have a failsafe button should you have ejection issue. This usually a very small tiny hole normally next to the button that you need to press to eject the cd.
Please look for this small hole and use an office pin (which you need to straighten and insert it into the hole to eject the cd. This works even if the pc is off.
Good luck and let me know of the outcome
Nov 02, 2010 | Acer (91.49C37.001) CD-ROM Drive
Acer monitor says no signal, then goes blank. Is
We are using the same monitor type.. humm it's good that i already had experience with it. No drivers needed to install this monitor, check the connection to the PC and to the monitor, make sure they are inserted properly. Sometimes when you put on the PC first and then power on the Monitor causes this problem. The best recommend resolution is 1440X990, good luck..
May 15, 2010 | Acer AL1916W 19" LCD Monitor
All Acer Laptops Compatible wih all Acer LCD Monitors ? Is there any thing specific to look into when an LCD Monitor has to be Purchased to be connected to an USB Port of an Acer Laptop?
You can hook up any brand of monitor to your Acer laptop.
The only thing you may have to check for is that the connector on the back of the Acer (and all laptops for that matter) is a VGA type. This is the older style of monitor connector. Some new monitors come with a HDMI connector. All you need to do is buy an adaper, put that on the end of the cable and plug it in.
When you get the monitor plugged into the laptop and powered up then you will need to go into you display setting and check to see the external monitor is detected and how you want to use it. You can extend your desktop ie make you screen size cover or use both monitors. You can also set it to put your desktop out to the monitor and perhaps one or two other options depending on your laptop model. Once you have it setup it should use those setting automatically the next time you plug a monitor in.
May 02, 2010 | Acer AL1916W 19" LCD Monitor
I can't open the case on a ACER AL1916B monitor,it does not match the Acer service manuals.Other than the base bracket mounting screws,mine has only 2 screws at the bottom of the case. I would like to open...
refortsm, you didn't say that you looked at any video clips on YOUTUBE that deal with LCD monitor disassembly. Find very , very DULL butter knife or table knife. You do not need a trip to the "ER" for a self-inflicted stab-wound!!! Some use old cd rom disc's for release of perimeter locking tabs???? Protect the units glass LCD panel at all times. You crack-it, then it's "You bought it you own it toyota!" "game over" for you. Removal of rear cover is hardest part of unit "tear-down" and inspection. Key for you is START at bottom with B-knife and pry gently. I hope this helps. Let me know about your "switch-mode-power-supply" condition. lmistyrel on aim. or 12fixlouie on Fixya
Feb 05, 2010 | Acer AL1916B 19" LCD Monitor
PROBLEM WITH ACER ASPIRE 7535 CD-ROM
Put Lense Clener In To CD ROM
[email protected] WWW.RSINFOTECHSYS.BLOGSPOT.COM
Oct 18, 2009 | Acer Aspire 5735 Notebook
After replugging lcd monitor and starting comp it was pink
Try disconnecting the VGA cable from the computer and checking that the pins in the connector are all straight
Mar 22, 2009 | Gateway 19" Flat Panel LCD Monitor
Microsoft Word Suite
One solution is USB memory stick.
You can copy contents of a CD to USB drive, and then run the installation from there.
You will need memory stick large enough to support this data (512 MB or 1 GB, it depends).
Create a folder named Word on USB disk, then copy all the files and folders from a CD to this folder.
Insert USB disk in Aspire One and run setup.exe from this folder you created.
Jan 16, 2009 | Acer Aspire One PC Notebook
Acer monitor parts
Acer offers access to spare parts for purchase for products still being supported through the Acer Network. Please contact spare part sales department at 1-800-816-2237 for more information
Dec 18, 2008 | Acer AL1912B 19" LCD Monitor
Acer AL1916W monitor
The AL1916W's native resolution is 1440 x 900. See if your display settings can produce that resolution.
Sep 22, 2006 | Acer AL1916W 19" LCD Monitor
Acer AL2016W 20" LCD Monitor Logo
90 people viewed this question
Ekse
Alun Cox
