Question about DeLonghi Pinguino PAC-02 Air Conditioner
Pac 60 how to clean unit
We have a Pac 60 how do you clean/descale the unit?
We have used it one summer and this is the second summer.
We have a bottle of Pinguino Mantex S.N.O but no book to follow directions for cleaning
email: paquinn7@bigpond.net.au
  • Anonymous Jun 09, 2008
    constantly needs to be reset
    Problem Solver:
  • 15 Answers
  • norman medalle
    norman medalle Dec 09, 2007
    myrepairmaster.com is all you need ,try and compare without having it, i know for sure you will get it.
Saeco Odea Go descaling
fill the tank with detergent and let the hot water run for about 15 seconds. Then turn off the machine for about 15 minutes. Then turn the machine back and let the hot water. Then rinse the water tank and fill it with clean water. Run hot water again to empty the tank. Fill clean water again and then you can put down coffee :)
Dec 02, 2013 | Saeco Odea Go
I have a Saniplus in my bathroom its connected to a sink, toilet and shower. The thing is when it is used its fine but after the pump stays running, until you tap the machine in the middle on the right,...
Your saniflo has a membrane that covers the electric and switch, it is probably starting to get covered in limescale, have you tried descaling the unit, you can get descaler from saniflo and the instructions are on the bottle, its very easy to do, there are otherb cheaper makes of descaler but as far as I know saniflo descaler is the only one with the instructions on the bottle.
There are other things it could be like a faulty switch or heavy/hardened lime scale on the same membrane mentioned above or the membrane could of be deformed and lost it's shape causing the problem, but all of those problems would need a engineer and maybe even parts, so try decaling first
Nov 20, 2012 | Home
Delonghi Clean Cal descaler, where can u buy this in North America? Is there a place where you can order it online? Looked everywhere, lots over in Great Britain, nothing on this side of the planet.
I did find one in North America (Canada) http://www.warehouseoutlet.ca/en/shop-by-category/delongi/p17631782.htm
If this one is not close enough, you can make your own descaling solution my mixing a 50/50 solution of White Vinegar and Bottled Distilled Water. I have been recommending this for years to folks who have a scaling problem with humidifiers, electric irons, coffee makers, etc. In every case it worked well for them.
Hope this helped you and thanks for choosing FixYa.
Sep 19, 2011 | DeLonghi PAC W130 Portable Air Conditioner
Red de scaling light won't shut off
Removing the red descaling light is simple.
1. Fill reservoir with half vinegar and half water (no need for the special descaling product from Tassimo).
2. Turn on machine.
3. Insert yellow cleaning disc found in back of machine.
4. This is where most people have the their problem...You must hold the start button for 3 to 5 seconds for the descaling program to start. Both green and red light will flash.
5. Once started, use a large cup to catch the output of water.
6. The machine will cycle through the descaling program in about 30 to 45 minutes. Be paitent!!!
7. Once completed, run many cups of plain water through the system to remove the vinegar taste.
8. Red light problem is solved.
Hope this works for you.
Apr 11, 2010 | Braun Tassimo Espresso Machine/Coffee...
Need descaling instructions for EAM 4500 auto espresso machine
use 1/4 cup of vinegar and fill pot with cold water, run through machine
Aug 01, 2009 | Coffee Makers & Espresso Machines
DeLonghi Pinguino PAC-290 - Compressor Won't Come On
Have you tried to descale the unit? I have this unit and it requires descaling often due to the hardness of the water you are using in said unit.
Jul 29, 2009 | DeLonghi Pinguino PAC-290 Air Conditioner
Descaler
Vinegar is the cheapest. or CLR @ home depot. Tom
Jun 18, 2009 | DeLonghi Pinguino PAC-290 Air Conditioner
Cleaning light came on and now, coffee pot will not work
Automatic clean function
The coffee maker is equipped with an automatic clean function. After 60 brewing cycles, the clean indicator/button (22) lights up. This indicates coffee maker should be cleaned by using the automatic clean function and the charcoal filter (17) should be replaced.
NOTE: The coffee maker can continue to be used, when clean indicator/button (22) is on.
• To begin the cleaning cycle, remove the charcoal filter (17) from the water tank (10). Fill the tank with a vinegar and water mixture (1/2 vinegar and 1/2 water) or a descaling product. Press clean (22) button for three seconds. The clean indicator/button (22) flashes and the cleaning process begins.
Cleaning process:
• 24 cycles of 7 seconds brewing and 21 seconds off
• 30 minutes rest
• Brewing the remaining descaling solution
• After cleaning process is complete the clean indicator/button (22) goes off. Fill water tank (10) with clean water and run one brewing cycle to rinse the coffee maker.
• Change the charcoal filter (17) (ill. k). Reinsert the charcoal filter to the coffee maker (ill. l).
NOTE: You can use the cleaning function before reaching 60 cycles (especially if the water hardness is above normal). Press and hold clean indicator/button (22) for 3 seconds.
NOTE: The Cleaning Process takes 60 minutes to complete. You cannot cancel the cleaning process before it is complete. Unplugging the machine only delays the cleaning process.
Jan 26, 2009 | GE 106591 Coffee Maker
Pinguino PAC 50
KABOOM® PRO Descaling Cleaner
Nov 22, 2007 | DeLonghi Pinguino PAC-02 Air Conditioner
DeLonghi Pinguino PAC-02 Air Conditioner Logo
921 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Michael Youngman
Michael Youngman
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
