Question about Motorola Mobility RAZR V3
Motorola V3 Phone
How can I turn off the "boot-up" and "shut-down" sounds on my Razor V3 Camera phone? I want to be able to turn the phone on and off withotu it making the noise it plays thru the speaker..........
I have a Motorola Razr V3 and I had some ringtones bluetoothed to my phone. They came through just fine. I stored them, they show up in my media sounds but I can not set them as ring tones. Does anyone know what I am doing wrong?
Posted on Sep 16, 2008
I have a sprint razr and this is what I did. First you go to the menu and click on settings. once you are at settings click on sounds. Then click on volume and scroll down until you get to power on and click on that and from there you can turn off that sound.
Posted on Nov 29, 2007
SOURCE:
My razor v3 is stuck on the hello screen and do not turn off by pushing the power off button.
Sounds like the firmware has gotten stuck it was a common bug in some of the v3 firmware versions. Pull the battery, replace it and then power on while holding down the # and * keys it will go into bootloader mode. Once on the text bootloader screen you can use flashback (google for it) and flash a more current firmware which will fix the phone.
Jan 07, 2009 | Motorola Mobility RAZR V3
Razor making double beeps or weird sounds while on battery seems to be going down quick
remember to turn your bluetooth off and set the backlight lower. the double sound is probably telling u low battery
Aug 16, 2008 | Motorola Mobility RAZR V3
Broken razor
you have a rom boot up problem but you will need to replace the main-board on the phone or replae the phone itself.
Jun 27, 2008 | Motorola Mobility RAZR V3
Razor phone from att
disconnect when you shut the fone lid down is a call seting in the fone
Jun 19, 2008 | Motorola Mobility RAZR V3
Motorola razor v3 cell phone file transfer to PC
You can download the software HERE.
Dont forget a Fixya rating!
May 09, 2008 | Motorola Mobility RAZR V3
Phone shuts down during a charge
change the battery and if that does not work take the phone and have the service center reflash the firmware on the phone this method should correct it.
Aug 28, 2007 | Motorola Mobility RAZR V3
Motorola RazorV3 Camera Error
hi there, your camera is faulty and needs to be replaced or it could be a problem with the phone. I suspect the camera once everything else is working o.k. You need 2 take your phone to the nearest service technician to get it replaced. Replacing the camera is fairly easy from my experience as a repair tech. Sam !
Jul 10, 2007 | Motorola Mobility RAZR V3
Has your Razor screen shut down?
It's possible that your sensor that connects to your screen has become dislodged. (if you're brave) check out the do-it-yourself repair guide: http://www.lovehopefaith.com/V3.files/V3-repair.pdf
Nov 26, 2006 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
198 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
