Question about Nokia 6820
Nokia 6820 display does not work.
I have a Nokia 6820, which worked well for a couple of years. Recently it started giving problems with the display. After several trips to Nokia Care - and temporary fixes - the display is now permanently out. They recommend replacing the display, but for the expense, I might as well go for a newer model.
Question is: now my power does not turn on. It doesn't seem to charge either. Pressing the power button does nothing. I need to get my phonebook and all else downloaded. I have my Nokia PC Suite, but without bringing up blue tooth how do I get it synched to my PC? What can I do to turn the power on.
Unplug battery for 5 mins. plug back in and before powering on plug the charger to it. if there is a charging indicator light then this will tell you if the connection with your battery is dead. if it powers on then all you need to do is call your provider and they have the phone hand book to walk with you step by step to get what you need. hope this helps
Posted on Nov 29, 2007
SOURCE:
Hi I bought a nokia n97 mini some nine months back in the US , it fell down a couple of times it fell donw recently but still it worked normal for about six hours and right now the display does not work...
If your display worked for six hours, then maybe there is no fault in the display. The jack, which connects display to the board may have been broken or got loose. You should surely give it for service. As the service cost wold not be too high even if they have to change the display, it would cost you around 40 to 50 USD.
Hope it helps. Thanks for using FixYa. Please rate the answer.
Aug 26, 2010 | Nokia N97 Cell Phone
There is problem when giving print..thats the
check the sensors that makes the paper printer stops... 6820 and 6822 printers are one of a expensive printer in the market today and i been working of it for 3 years now as well as its handheld 700C and CN3... just email me in case it didn't give you a good solution coz theres a lot of approach to fix it. i do chip leveling....
Jun 04, 2010 | Intermec 6820 Matrix Label Printer
I want to format my Nokia 6820 and need a software for it as GPRS is not working I think its a virus problem
Hii
U can go to nokia website and click Get Support and Software > Download Software , select ur phone model and it will download the required softwares on ur pc , once done follow instructions on screen and connect ur phone. U will be updated with the new software on ur phone.
If GPRS is not working there must be something wrong wid the settings, contact ur network operator they will tell send u the perfect settings, the settings u wud receive it as a sms once ur receive the sms press save. Ur new settings wud be updated and gprs wud start working.
Also you can download official Manual for ur cell phone
Hope it helps u
Good Day
Sep 11, 2009 | Nokia 6820
How to unlock nokia 6820 security code
try this site http://www.peters1.dk/unlock/nokia/online.php?sprog=en
this site mite help u
Mar 18, 2009 | Nokia 6820
Nokia 6820 upper left side keypad dislodged
Press down, don't be afraid to use force. It will go back in eventually unless you broke a clip off. It should be fine.
Nokia 6820 black screen
you have a damaged screen. they generally go black when they have been cracked and the liquid crystal has leaked. the LCD can be replaced, but if it also has a tired battery, it is probably not worth repair. If you want to replace the display,you need the correct tool to remove the screws from the chassis internally, and the new LCD can be purchased from http://cellink.com.au/products/ They have the tools and parts to repair just about any phone. Good luck. A "fixya" rating for my advice would be great :)
Feb 02, 2008 | Nokia 6820
Problem with 6820
My suggestion is to do what the phone says, it usually means that theres something wrong with your phone and it needs technical assistance.
Aug 14, 2007 | Nokia 6820
Front keypad failure
Hello Kevin try cleaning the contact between the keypad on the flip and the board. And if that doesn't help teh flex will probably need to be replace. Hope that will solve your problem.
Jun 01, 2006 | Nokia 6820
Nokia 6820 Logo
69 people viewed this question
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Ekse
