Access your manual numbered channel mode so you can "step" through each channel manually. Make sure that each channel is NOT in L/O or locked out mode. If it is, use the key that un-locks that channel. Also, make sure the frequency is correctly entered for each channel in question.
Was this helpful?
Yes
No
Popular Solutions for Radio Shack Pro-2018 Scanner
after I orogram frequencys in they look as if they are receiving but I hear nothing or squelch on my...
(More)
after I orogram frequencys in they look as if they are receiving but I hear nothing or squelch on my pro 2018
i am looking for new berlinville station 17 frequencys and i cant seem to find it starting monday i...
(More)
i am looking for new berlinville station 17 frequencys and i cant seem to find it starting monday i will be a firfighter and they may nt have any pagers so i have a scanner and i cant find the frequencys that i need can u help me
radio shack pro 2018 seems to fine but it makes a popping sound moving form freq to freq why? is it...
(More)
radio shack pro 2018 seems to fine but it makes a popping sound moving form freq to freq why? is it supposed to? im new to this.
I use the scanner to monitor water tower level, so it stays on one
frequency all the time (never...
(More)
frequency all the time (never use it to scan). When there is a storm, I
unplug it. This time when I plugged it in, it went into scan mode like
usual, but the buttons had no effect: Couldn't stop scan to select a
channel. Often one can reset some units by unplugging for a minute or
so. Even 48 hours. If I turn off the unit, hold PROGRAM and
1,2,4,5,7,or 8, while I turn it on, it beeps and does not scan. Still,
no entries can be made from the pad. It is stuck until I turn off/on,
when it goes back to scanning. I can do the off/on trick while holding
LOCKOUT, where it locks out the lowest channel, but can't unlock.
Channel 1 and 2 are locked out now. The battery is dead, so I lost all
my memory frequencies (that's OK, I only used one of them). SCAN or
MANUAL buttons are supposed to stop the scan, but they don't. Is this
thing toast?
