Question about LG KG800 Cellular Phone
Buttons stopped working
I've got a problem with the phone's keypad, can anyone tell how I open it up? I removed the battery and sim card, unscrewed the four screws from the back but what now? I'm a little hesitant to just pull but I can't see any other way...
  • RAYMONDM Dec 03, 2007
    my lg kg800 phone used to turn on sometime, now it wont turn on at all. please can you help ? yours ray.
  • 175 Answers
I don't have a video for disassible of KG800
only pictures here's the link
just click here :-)
peace!
Posted on Nov 29, 2007
SOURCE:
I got water in my Nokia E71... there are marks on my screen... the water did not damage my LCD, but it left something like water vapour between the LCD and the glass screen. how do i get rid of it?
SWITCH OFF YOUR PHONE
AND REMOVE BATTERY AND SIM CARD
AND PLACED IN NEAR FAN FOR 2 HOURS
Release battery cover.
Remove battery cover.
Unscrew four T4+ screws.
Open the two clips.
Do the same on the other side.
Lift the bottom of top cover NOT the bottom cover!
Remove the top cover as shown.
Press out the qwerty keypad.
Nov 25, 2010 | Nokia E71 Smartphone
My phone screen not working, key pad working but my phone was keypad locked. to unlock i need to press unlock button on screen but screen is not working .. i have restarted and remove memory, sim card also...
The reason your screens touch pad is not working is because the sensor board is no longer connected to the main panel of the phone, or the ribbon that connects the screen to the main board is faulty.
Try to open up the phone, by unscrewing it open from the back, then locating the ribbon and either try to reconnect it or replace the ribbon with a new one.
Remove your back cover, battery, sim, stylus and memory card. Now remove the cross head screw,
Lever the antenna cover off using a mobile phone opening tool.
Now remove the six screws you have access to.
Next you need to separate the battery compartment from the rest of the phone. To do so lever it away using your opening tool. There are various recesses in the back of the phone do allow you to do this.
The volume buttons are stuck to the side of the housing and need to be carefully peeled away. you can see the volume buttons after they have been unstuck from the side of the phone. You can now peel the large brown/orange ribbon away from the phone. It's held in place with double sided tape. The circuit board which the ribbon is connected to will come away with it. The on/off switch will be stuck down in the same way the volume button was and also needs to be peeled away when you remove the circuit board.
The on/off button will also come loose. Remove the screw, circled bottom left. The vibrating motor, bottom right, should be levered up so it is loose.
Lift the lower circuit board up and you'll be able to see another ribbon connector which needs to be disconnected. Again, it attaches like a plug and socket. Just lever this away from the circuit board to unplug.
To screen is held firmly in place with double sided tape and to remove it you first need to heat the screen (using a hot air gun or a hair dryer), then push your opening tool very firmly. You'll then see the screen raise slightly allowing you to slide something like a guitar plectrum or credit card behind it. Move your plastic tool all the way around the edge of the screen to release it.
You can now simply lift the screen away from the housing.
You should now have the screen removed. Reverse the whole procedure for reassembly.
Take care and good luck
Oct 13, 2010 | HTC Touch P3450 Smartphone
Looking to replace speakers and don't know how to take apart
browse to the internet for motorola razor v3 dismantling
Oct 11, 2010 | Motorola Mobility RAZR V3
Nokia 2100 keypad suddenly stopped working
Please try to open the pad and clean its contacts. below is the proceedure to open the phone (if it is not under warranty). you two credit cards and a screw driver.
  • Take front faceplate off by inserting card 1 between housing and silver key. As you pull up, take card 2 and slide it on the side of the phone prying the clips off.
  • Unscrew these 6 screws at the edges with the T6 screwdriver and release the 4 clips surrounding the LCD screen.
  • Slip the little black frame off of the LCD screen, and lift the screen. You should now see a screw. Removing this screw removes the back cover.
  • That’s it! Put your new faceplate or housing in and figure out how to put things back by following the directions here in reverse order.
May 28, 2009 | Nokia 2100 Cellular Phone
Arrow failure
wicabix hello,
It seems like the keypad has moved perhaps because of a trauma to the phone.
I would suggest to send it to a lab if still under warranty.
If not, open the back lid, remove the battery. Then, unscrew both panels using a small screwdriver, and try to place the keypad in its right place.
Then, screw back on, put the battery in its place, and turn the phone on.
Good luck.
Sep 27, 2008 | Sony Ericsson Walkman W810i Cellular Phone
SCH-u740
ok one last shot i can think of is if you take the back cover off remove the battery and the sim card. if there is a reset button it should be there. that is all i can think of. one other thing is did she maybe hit the keypad lock by accident?
Aug 30, 2008 | Samsung SCH-u740 Cellular Phone
No response from keypad input?
check your volume keys or any side keys that get stuck... or if you can open your fone check its keypad for any shortage...
Oct 26, 2007 | Samsung SGH-d407 Cellular Phone
123 BUTTONS DON'T WORK ON MY SONY ERIKSON K750I
Try putting the phone in a very warm dry place, ay in the "Hot water cupboard" for a day or so and this may drive out any moisture that may be causing the problems, also shake the phone vigorously B4 you do so to try and dislodge any moisture. Or you could try disassembly and wiping the keypad contacts, perhaps there is still moisture there, or maybe it has shorted something else which is why ya gotta dry it out completely.
Jul 14, 2007 | Sony Ericsson K750
Moto v6 keypad problems
Hey,
I have or should I say I had the same problem with my v6 maxx keypad not working. So I started to look into the flex cable replacement idea. I remove the back cover. Removed the Sim Card, Battery and Memory card fully intending to split the phone and have a look around inside. But then I came to a grinding stop when I saw how small the hex screws are. Gotta get me some of those. While I was there staring at the screws I noticed a small amount of dirt residue inside the back of the phone so figured it wouldn't hurt to give it a spray with CRC Contact Cleaner (it leaves no residue). I left the mobile in the sun to dry for about 3 minutes. Replaced the battery, memory and sim card and now it's working PERFECTLY.
Done. fixed. *** twas just dirt.
Cheers
roddarockker
Jul 13, 2007 | Motorola Mobility MOTORAZR maxx V6...
Keypad buttons not working
ull have to open the mobile and check the keypad strip or change the strip
Jan 23, 2007 | Nokia 6600
LG KG800 Cellular Phone Logo
Top LG Cell Phones Experts
George Etukudo
George Etukudo
Sheldon Dedek
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
