HP Officejet 6500 Wireless All-in-One InkJet Printer Logo
Posted on Aug 12, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Printer says insert paper to align ink cartridges
My printer (an hp officejet 6500 wireless) will print and works fine except that it always tells me to put paper in the place where the paper goes and then hit ok so that it can align the cartridges but then it always fails at aligning them. and there is always paper in the tray?
Anonymous
Level 3:
President:
  • Master 3,085 Answers
  • Posted on Aug 12, 2009
Anonymous
Master
Level 3:
President:
Answers
3085
Questions
Helped
1006972
Points
9738
Replace all ink carts with NEW ones.
7helpful
I just replaced by black ink on HP Officejet 6500. It will not print black thought it maybe the cartridge I replaced it again. Still want print. I tried three new cartridges. The color works...
The following may work: remove all the ink supplies. Remove the printhead and soak it for about 5 minutes in 0.5" of very hot water. Gently blot the printhead on a soft damp paper towel to remove the excess water, then replace in the printer and then reinstall the ink supplies.
My HP Officejet 6500 Wireless printer won't print in black when trying to print from Microsoft Office Word and Microsoft Office Excel or PDF. The ink cartridge is new. I have turned the printer off and...
I also have the OfficeJet 6500 and had the same problem. The black text was printing using a mix of colored inks instead of the black ink, resulting in a grey, fuzzy text. I finally found a solution. In each application under Page Setup, there is an option called "Format for". Mine had been set to "Any Printer". I changed that to "Officejet 6500 E709n [830E4A]" and now it prints the black just fine. I have a Mac running 10.4.11. Hope this helps.
4helpful
HP Officejet 6500 Will not print black. All ink if full, even replaced the black cartridge with new. Clean heads (via utility) 3 times. All other color cartridges (c,m,y) are printing. Work fine...
two actions I took that worked.
1) Remove the print cartridges. Raise the lever that holds the printer casing down (plastic square box), lift it up gently, remove it, and wipe with a clean, dry paper towel.
2) from the menu option on the printer. Go through the set up option and select "clean printer head" from the options. It will also do a self clean.
I did those two and it works nice.
2helpful
Printer loads paper and goes through the same process it used to when printing but it spits out a blank sheet of paper. It got a new back ink cartridge in it.
Try Cleaning the Cartridges manually and automatically.
For the cartridge clean it with a damp lint free cloth and also for the printheads wher eyour gonna be inserting the cartridges.
Follow these steps do do the automatic aligning and cleaning:
Click Start and then go to Printers and Faxes (XP), Printers(Vista), Devices and Printers(Win 7)
1. Right Click on your printer Icon 2. Go to Printing Preferences 3. Click the Features Tab 4. At the bottom of the window you will see Printer Services or Device Services. Click on it. 5. Choose Align Printheads on the list.
For Cleaning the Printheads, Instead of choosing Align Printer choose Clean Printheads.
I hope this helped.
Try Printing Again. I hope I was able to solve your problem. :)
The HP Officejet 6500 will now only print color copies, the black copies do not print, the officejet does not recognize the request to scan copies, the officejet will send faxes and show a fax is being...
not ridiculous as the new printer costs less than replacement cartridges
check for ink in the black cartridge
check that the driver is still connected
check for compatibility with the pc
2helpful
Printer only won't print in black
My printer did that a few months ago. I tried everything to get it printing black but in the end I had to take the ink cartridge back and return a new one. Some ink cartridges dry out when they are being shipped if not stored in proper conditions.
My HP 6500 won't print blue. New ink cartridge installed, heads aligned, and cleaned. Still no blue. Any ideas.
Print test page in the software, if no blue try print head clean again, if no go return cartridge for replacement.
Is it genuine or refilled??
2answers
Recently bought an HP Officejet 6500. How do I
This video shows how to change ink cartridge on HP 6500 and 6500A
k24674
Grand Canyon Tech
Grand Canyon Tech
