Cloths washer not working
All the lights on the control panel flash. Tried doing what the manual said but all the lights keep flashing and the machine won't work.
  • Anonymous Feb 22, 2008
    yep, I have the same. I start the machine in wash mode. instead of water filling, it starts washing with no water for 4 seconds and stops and the light start flashing and machine starts beeping the alarm. I've tried all different modes and unplugging and plugging the machine with no change. Any ideas? Avanti W789SA top loader. thanks!
  • Anonymous Sep 20, 2008
    Installed a new control panel and the lights just flash. Unit will not start. Unplugging unit for 30 minutes did not help.
  • 76 Answers
Not sure what make or model this is, just try unplugging it and leaving for a day and see what happens, if not let me know the make etc
Posted on Nov 30, 2007
Wtw4950xwo.Why does lid lock light keep flashing, especially at final drain and spin?
You have a vertical modular washer. And it keeps flashing because there was an error detected by the control board. Is it washing your clothes properly? Or is it leaving your clothes wet when cycle is completed?
Jan 21, 2016 | Whirlpool Washing Machines
The start button keeps blinking, WONT LET ME DO ANYTHING
Cycle light flashes, but machine wont start - Kenmore Elite ...
https://www.ifixit.com/.../Cycle+light+flashes,+but+machine+wont+...
iFixitIf this pin breaks off, the washer will not recognize that the door has be. ... Whatever cycle I choose, the light just flashes and holding the start button does nothing. ... I don't seem to have a black pin....the normal wash button just keeps flashing ...
GE Washer Start button flashing - DoItYourself.com Community Forums
www.doityourself.com/.../386041-ge-washer-start-button-flashing.html
Apr 6, 2009 - GE Washer Start Button flashing will not start Model WPRB8050D1WW, tried holding start button in for 5-10 seconds, did the unplug for 30 ...
Oct 29, 2015 | Washing Machines
Why are there no error codes when running diagnostic test?
it sounds like u fixed the problem. have u tried a load of clothing yet
Jun 14, 2014 | Kenmore HE2 Plus Front Load Washer
All the function lights and pause lights flash
follow the steps and fix it. USE the VOM . God bless you
Check Power
Check the outlet by plugging an appliance into the same outlet the washer was plugged into an running the appliance a hair dryer works good for this it will draw some amperage. If it works fine move on.
Control
To check the control remove the top panel and then remove the console to access the wiring to the control. Find the wire feeding the control from the main power cord. If you cannot visually see this refer to the tech sheet or service manual. Connect voltmeter to the 2 wires feeding the control if it is recieving power and it does not respond replace the control
May 28, 2013 | Washing Machines
Kenmore Elite Oasis HE Washer #27087. Doing a load of wash & wash & lock lid were flashing. Could not unlock lid & panel kept flashing. Unplugged cord for 30 minutes. When I plugged back in...
I would think the lid would unlock once you unplugged the machine. Check your owner's manual for any kind of "emergency reset" procedure. Perhaps the lock mechanism is jammed. Have you tried pressing on the lid or tapping it to see if that frees the lock?
Nov 18, 2017 | Kenmore Elite Oasis 27052 Top Load Washer
Finished, wash and spin lights flashing. Door
I just had this problem! To get the clothes out, open door manually (follow answers on other threads here about opening toe panel and gently pulling down on door release). But as it turned out, I didn't need to remove the clothes, and now my washer is working again.
A local repairman gave me this advice over the phone. Make sure dial is switched to off. Unplug your machine, then plug it back in. Hold down the rinse and delay buttons with one hand. With the other hand, switch the dial from off to cold or warm or whatever cycle you want. All the buttons flash a few times, then just the start button flashes. The second time I tried this, my washer worked afterwards. I've done several loads today with no problem.
Jul 19, 2010 | Bosch Nexxt 100 Series WFMC1001UC Front...
Kenmore he2 front load washer
remove bottom panel open pump port and ck for foreign objects lean washer toward rear wall this will help help keep water toward rear and reduce flooding floor might try opening door first and dipping out as much water as possible with bottom panel removed reach up to lock area there is a tear shaped plastic peace pull it down to release door
Jun 02, 2008 | Washing Machines
Washing Machines Logo
66 people viewed this question
Top Washing Machines Experts
