Question about HP Pavilion 7850C PC Desktop
Operating system not found
When I turn on this computer that is the message that I get... I do not have the disc's to restart it, any help?
  • 83 Answers
Erm, How are you on this website if it is not working? -- If you're on a different computer, search for the disk, if you certainly cannot find them contact microsoft (or what your computer company is) located in a phone book, or manual and explain what happened to them, Hope this helped
Posted on Nov 29, 2007
SOURCE:
System disc
What type of system disc ?
operating system disc
Create a Windows 7 System Repair Disc:
http://www.sevenforums.com/tutorials/2083-system-repair-disc-create.html
"This will show you how to create a Windows 7 system repair disc to use to boot to the system recovery options if you don't have a Windows installation disc, can't find your Windows installation disc, or can't access the recovery options provided by your computer manufacturer."
If you do not have access to either disc: Windows 7 - Repair Disc download
http://neosmart.net/blog/2009/windows-7-system-repair-discs/
a) Insert the Windows 7 System Repair DVD or Installation DVD and reboot.
b) Select the correct keyboard input method and click 'Next'.
Note: If you are using the Windows7 Install DVD then at the 'Install Now' prompt (Do not pick the Install Now option) instead choose the 'Repair your computer' option located in the lower left of the dispay.
c) The System Repair tool will search for a valid operating system and will report that "Windows found problems with your computer's startup options.
Do you want to apply repairs and restart your computer?"
d) Click 'Repair and restart' and reboot again to the Windows 7 System Repair environment.
e) Click 'Next' at the keyboard selection prompt and when the 'System Recovery Options' screen appears verify that the "Use recovery tools that can help fix problems starting Windows" is selected.
Note that on your Dual Boot system there now should be only one operating system listed. Click the 'Next' button.
f) Now from the menu list select the 'Command Prompt' option.
g) At the DOS prompt type the following three commands:
bootrec.exe /fixmbr
bootrec.exe /fixboot (may return an 'Eliment not found' message)
bootrec.exe /RebuildBcd
h) Close the command prompt window and click the 'Startup Repair' option.
i) The repair process may take some time, so wait until the process completes at which point you will see two messages "Windows cannot repair this computer automatically" and "Startup Repair cannot repair this computer automatically".
These messages are the result of the radical changes made by removing the other drive. Ignore the Send/Don't send options.
J) Close this message window by clicking on the X in the upper right corner of the Send/Don't send window.
Next click on the 'View advanced options for system recovery and support' option and from the main menu once again click 'Startup Repair'.
This time the repair process may only that a few seconds and when prompted "Startup Repair could not detect a problem", click 'Finish' and run the 'Startup Repair' option one more time, click 'Finish', and then remove the System Repair DVD and click 'Restart'.
Reboot the computer.
Hope this helps.
http://neosmart.net/blog/2008/download-windows-vista-x64-recovery-disc/
vista recovery disk
not longer free
http://systemdiscs.com/?utm_source=neosmart&utm_medium=article&utm_campaign=Vista_Recovery
Mar 06, 2014 | HP Compaq Presario SR1750NX PC Desktop
When I turn on the computer it says boot mgr is missing. I guess I totally messed up when I tried to do a full system recovery. The discs I have are from geek squad there is tow of them.
An operating system would have been nice ?
How to Create a Windows 7 System Repair Disc:
or
c) The System Repair tool will search for a valid operating system and will report that "Windows found problems with your computer's startup options. Do you want to apply repairs and restart your computer?"
bootrec.exe /fixmbr
J) Close this message window by clicking on the X in the upper right corner of the Send/Don't send window. Next click on the 'View advanced options for system recovery and support' option and from the main menu once again click 'Startup Repair'.
This time the repair process may only that a few seconds and when prompted "Startup Repair could not detect a problem", click 'Finish' and run the 'Startup Repair' option one more time, click 'Finish', and then remove the System Repair DVD and click 'Restart'. Reboot the computer.
hope this helps
Nov 24, 2012 | eMachines ET1810-01 PC Desktop
I need to find a set up disc
What operating system set up disc are you referring to ?
bootrec.exe /fixmbr
http://windows-xp-pro-startup-disk.soft32.com/free-download?gclid
windows xp pro start up disc
vista recovery disc
Hope this helps.
Nov 20, 2012 | Computers & Internet
System disks startup
bootrec.exe /fixmbr
hope this helps
Nov 12, 2012 | Acer Aspire X1 Ax-1430g-uw30p Slimline...
How do I make a recovery disk?
Which operating system ?
there are some you can download
If you computer crashes and your hard drive fails, you can lose a lot of data and spend a great deal of time trying to find all your discs and re installing all of your information.
It can be very difficult to find and re-install your operating system if you do not have the original CDs that came with your computer.
But if you create a recovery CD for your computer, the restore process can be much faster and quite easy.
Put the blank CD in your CD writer.
Click on the Windows Start button.
Click on the Control Panel option.
Click on Backup Your Computer from under the System Maintenance section option.
Click on the Backup Your Computer button on the Backup and Restore menu.
Select your CD drive from the drop-down list and press the Next button.
Click the Start Backup button to begin the backup process.
you might need to use dvd rw depending on the size of the backup
This will show you how to create a Windows 7 system repair disc to use to boot to the system recovery options if you dont have a Windows installation disc, cant find your Windows installation disc, or cant access the recovery options provided by your computer manufacturer.
or
b) Select the correct keyboard input method and click Next.
Note If you are using the Windows7 Install DVD then at the Install Now prompt (Do not pick the Install Now option) instead choose the Repair your computer option located in the lower left of the dispay.
c) The System Repair tool will search for a valid operating system and will report that Windows found problems with your computers startup options.
Do you want to apply repairs and restart your computer ?
d) Click Repair and restart and reboot again to the Windows 7 System Repair environment.
e) Click Next at the keyboard selection prompt and when the System Recovery Options screen appears verify that the Use recovery tools that can help fix problems starting Windows is selected.
Click the Next button.
f) Now from the menu list select the Command Prompt option.
bootrec.exe /fixmbr
bootrec.exe /fixboot (may return an Eliment not found message)
h) Close the command prompt window and click the Startup Repair option.
i) The repair process may take some time, so wait until the process completes at which point you will see two messages Windows cannot repair this computer automatically and Startup
Repair cannot repair this computer automatically.
Ignore the Send/Dont send options.
J) Close this message window by clicking on the X in the upper right corner of the Send/Dont send window.
Next click on the View advanced options for system recovery and support option and from the main menu once again click Startup Repair.
This time the repair process may only that a few seconds and when prompted Startup Repair could not detect a problem, click Finish and run the Startup Repair option one more time, click Finish, and then remove the System Repair DVD and click Restart.
vista recovery disk
not longer free
hope this helps
Oct 22, 2012 | Compaq Presario CQ70 Laptop AC Power...
Kenapa pada saat penginstalan laptop muncul tulisan BOOTMGR is compressed..?
google translate
why at the time of installation the laptop it says BOOTMGR is compressed
or
bootrec.exe /fixmbr
hope this helps
Aug 09, 2012 | Computers & Internet
My samsung Q45 notebook tells me to insert the windows installation disc and restart my computer. I have not got this, can anyone help?
First disconnect any external devices connected to the computer except the mouse and keyboard.
This error usually happens if the hard drive is not getting detected by the operating system or due to bad hard drive.
First check if all the physical connections to the computer are set correctly.
If it is a laptop remove the laptop battery, wait for 5 minutes and then connect back the battery, check if it works.
If the above step does not work then you will need to run CHKDSK tool to check if there are any bad sectors on the hard drive would suggest running chkdsk which would scan for any bad sectors on the hard drive and if those errors are repairable if would repair and if it cannot at the end of the chkdsk scan you would see a message "found one or more unrecoverable error on the hard drive" which means the hard drive is damaged.
If you have a Windows Vista installation disc, you need to restart (boot) your computer using the installation disc. If you do not restart your computer from the disc, the option to repair your computer will not appear.
1. Insert the installation disc.
2. Restart your computer.
Click the Start button, click the arrow next to the Lock button , and then click Restart.
3. If prompted, press any key to start Windows from the installation disc.
Note: If your computer is not configured to start from a CD or DVD, check the information that came with your computer. You may need to change your computer's BIOS settings. For more information, see BIOS: frequently asked questions.
4. Choose your language settings, and then click Next.
5. Click Repair your computer.
6. Select the operating system you want to repair, and then click Next.
7. On the System Recovery Options menu, click command prompt and in the command prompt typechkdsk /f and wait till the scan is completed and later restart the computer and check what happens.
http://windows.microsoft.com/en-US/windows-vista/Make-system-repairs-from-the-Windows-Recovery-Environment-from-Windows-Vista-Inside-Out
Important: While performing chkdsk on the hard drive if any bad sectors are found on the hard drive when chkdsk tries to repair that sector if any data available on that might be lost.
Hope this helps!
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
Jul 09, 2012 | Samsung Q45 Notebook
Hi there every time i turn on my laptop it says bootmgr compressed press ctrl-alt-del to restart,but when i do this nothing happens it stays the same,i just turned it off to go to my bed and then i turned...
By accident, your computer's operating system has been compressed. Enable for you to fix this kind of problem, you need to have the windows operating system disk. The disc came with the computer when you bought it.
Here are the things that you need to do:
1. Turn on the computer and insert the installation disc in CD/DVD drive.
2. Turn it off.
3. Turn it on again, once you see a message "press any key to boot to CD", then press any key.
4. You will reach to the options to "Install Now" or "Repair the PC". Select repair the PC.
5. In the System Recovery Options dialog box, choose the drive of your Windows installation
and click Next.
6. Click START UP REPAIR
7. Click Load Drivers if it asks you to do so.
8. After it loads, it will then restart your computer.
9. Don't press any key anymore once it asks you. Remove the CD.
I hope this helps.
Feb 02, 2011 | Computers & Internet
Computer problem, help.
This generally indicates a hard drive crash/failure, in which the hard drive will need to be replaced. Rare, but occasionally you will get this error from an operating system glitch. Before you run out and buy a new hard drive, try reloading the operating system. If you have any problems during or after the install, then the hard drive is shot.
Jul 01, 2008 | Sony VAIO FRV25 Notebook
HP Pavilion 7850C PC Desktop Logo
59 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
