Question about T-Mobile MDA
Hard reset i cann't hard reset my device thru Clear Storage botton (it doesn't work)?
  • 83 Answers
Well, What is your device?
Posted on Nov 29, 2007
  • 27 Answers
GO AND HOLD THE COMM MANAGE BUTTON AND THE VOICE TAG BUTTON AT THE SAME BUTTON AND THEN WHILE HOLDING THOSE BUTTONS DO A SOFT RESET AND THE SCREEN SHOULD GO BLACK AND IT WILL SAY PRESS SEND TO RESET AND THATS HOW U REALLY DO IT!!!
I WAS CONFUSSED ABOUT THAT TOO
UNTIL I CALLED HTC
Posted on Dec 03, 2007
I went cleaning my htc p5500 screen with a dap clothes and rub it up and down now the touchscreen isnt working,jus would like to know if i reboot it will the touchscreen work?
FOLLOW this steps and fix it. God bless you
  1. Hard Reset
    • 1
      Pull out the stylus from the back of the HTC Touch Diamond or the side of the HTC Touch Pro.
    • 2
      Using one hand, press and hold the volume down button on the left side of the device, the power button on the top of the device and the circular button on the face of the device. It is generally easiest to hold the volume down button with your thumb, have your palm over the LCD, press the power button with your index finger and the circular button with your pinky.
    • Sponsored Links
    • 3
      Continue to hold the buttons down while you turn the device over to access the back side. Use the stylus to press the "Reset" button, located near the end of the stylus cavity on the Diamond, and by the port on the bottom of the device on the Touch Pro. Release the "Reset" button, but do not stop holding the volume down, power and circular buttons.
    • 4
      Turn the HTC Diamond over and watch the LCD. When a message appears saying that this operation will delete your data, release the three buttons. Press the volume up button to complete the hard reset.
    Clear Storage
    • 5
      Slide your finger to the right along the bottom of the LCD until the "Settings" option appears. Tap "All Settings" on the device.
    • 6
      Tap the "System" tab on the screen and then tap "Clear Storage"
    • 7
      Select the drop-down box and choose "Clear Storage Only." Type "1234" into the text box confirming that you do want to delete your information and then press "Yes."
Jul 25, 2013 | HTC Touch Dual P5500 Smartphone
Tip
HTC Touch Clear Storage Clear Storage Another way of clearing the device...
Clear Storage
Another way of clearing the device storage and reset all settings back to factory default settings is to use the Clear Storage feature. You will lose all your data and files on the device storage when you use Clear Storage, so make sure to do a backup first.
  1. Tap Start > Settings > System tab > Clear Storage.
  2. Enter “1234” then tap Yes.
I hope that helps.
________________________
Download the HTC Touch Manual.
HTC Touch Soft Reset.
HTC Touch Hard Reset.
on Apr 18, 2010 | HTC Touch Cellular Phone
All our contact phone number seem to be on the sim card and on the phone hpw do I delete them from the phone
There are two ways, by clearing the Device Storage or you can try a hard reset, here are the steps:
To clear storage:
1. Tap Start > Settings > System Tab > Clear Storage
2. Enter "1234" now tap yes
To Hard reset:
1. Press and hold the TALK and END buttons, and at the same time, use the stylus to press the RESET button at the bottom of the device
2. Release the stylus and continue pressing the TALK and END buttons and you will see a message on the screen that says "This operation will delete all you personal data...." now press ACTION to proceed
3. Release the TALK and END buttons and then press ENTER on your device
GoodLuck!
eBookBoy
Jul 10, 2011 | HTC Touch P3450 Smartphone
Hi my htc touch diamond restarts randomly few times a day. can anyone help
try updating your software to 1.93 rom, i was having the same issues when i was on 1.37 and my partner was on 1.35 updated and not had the issue since!
update site - http://www.htc.com/www/supportdownload.aspx?p_id=133&cat=2&dl_id=2
also if that doesnt work try doing a soft and/or hard reset -
Performing a soft reset
Perform a soft (normal) reset to clear all active program memory and shut down all active programs. This is useful when your device is running slower than normal, or a program is not performing properly. If a soft reset is performed when programs are running, unsaved work is lost.
To perform a soft reset
1. Pull out the stylus, then remove the back cover.
2. Use the stylus tip to press the RESET button (red) located at the opening of the stylus bay. Your device restarts and displays the Home screen.
HTC Touch Diamond 2 hard reset
Performing a hard reset
If a normal reset does not solve a system problem, you can perform a hard (full) reset. After a hard reset, the device is restored to its default settings-the way it was when you first purchased it and turned it on. You will lose any programs you installed, data you entered, and settings you customized on your device, and only Windows Mobile® software and other pre-installed programs will remain.
Warning! Your device will be set back to factory default settings. Make sure that any additional installed programs and/or user data have been backed up before you perform a hard reset.
Important If Encrypt files when placed on a storage card is enabled, backup all files from the storage card before using Clear Storage, hard reset, or updating the operating system. Otherwise you will no longer be able to access the encrypted files on the storage card. Use ActiveSync or Windows Mobile Device Center to transfer files between your storage card and computer. After the procedure, copy your files back to the storage card.
To perform a Diamond 2 hard reset
1. With the device turned off, press and hold the VOLUME UP and VOLUME DOWN buttons, then briefly press the POWER button.
2. Continue pressing the VOLUME UP and VOLUME DOWN buttons until you see this message on the screen:
3. Release the VOLUME UP and VOLUME DOWN buttons.
4. Press the VOLUME UP button to perform the hard reset, or press any other button to cancel the reset.
Dec 29, 2010 | HTC Touch Diamond Smartphone
I have buy a new htc p3470 mobile fone.i have a
try a hard reset of your phone:
this will get you back to factory default and take you through wizard for setup.
To perform a hard reset
1. Remove the back cover.
2. Press and hold the SOFT KEYS, then use the stylus to press the RESET
button located below the battery compartment.
3. Release the RESET button, but
continue pressing the SOFT
KEYS until you see this message
on the screen:
4. Release the SOFT KEYS, then
press TALK/SEND to perform the
all your personal data,
to manufacturer default.
Press Send to restore
manufacturer default, or
press other keys to cancel.
Clear Storage
Important If Encrypt files placed on storage cards is or was enabled before, then
reset or updating the ROM system software. Otherwise you will no longer
storage card.
2. Enter “1234”, then tap Yes.
Your device restarts and displays the Quick Setup Wizard
Mar 27, 2010 | HTC P3470 Smartphone
Hello! I have a problem. My HTC Diamon 2 in Russian I need to change it from Russian to english.is it possible? and can u help me please how to do it step by step, Thank U VERY MUCH
If you perform a hard reset, it should allow you to choose the language the phone displays. Just be sure to back up all your info/programs you have on the phone because it will go back to factory default when you do this!!!
If a normal reset does not solve a system problem, you can perform a hard (full) reset. After a hard reset, the device is restored to its default settings—the way it was when you first purchased it and turned it on. You will lose any programs you installed, data you entered, and settings you customized on your device, and only Windows Mobile® software and other pre-installed programs will remain.
1.
This operation will delete all your personal data, and reset all settings to the manufacturer default settings. Press VolUp to restore manufacturer defaults, or press other keys to cancel.
3.
Using Clear Storage
If you can access the device settings, you can use Clear Storage to reset your device back to factory default settings.
1. Tap Start > Settings, and then tap All Settings.
2. On the System tab, tap Clear Storage.
3. Enter "1234" and then tap Yes.
Dec 17, 2009 | HTC Touch Diamond Smartphone
How do i hard reset the htc p4600?
This will wipe all the storage (not the sd card) and your device will be reset to default settings.
Hard reset (option 1)
  1. Pull out the stylus.
  2. With the device turned on, press and hold the VOLUME DOWN and CENTER buttons, then press the RESET button with the stylus tip.
  3. Continue pressing the RESET, VOLUME DOWN and CENTER buttons until you see this message on the screen:
This operation will delete all your personal data, and reset all settings to manufacturer default. Press ?VolUp to restore manufacturer default, or press other keys to cancel.
Hard reset (option 2)
You can also use Clear Storage to reset your device back to factory default settings.
  1. On the ?TouchFlo3D Home screen, slide to the Settings tab and then tap All Settings or goto Start and press Settings.
  3. Enter “1234” and then tap Yes.
Hard reset (option 3)
  2. Turn device OFF.
  3. While pressing the CENTER button, turn the phone on with the POWER button.
  4. Continue pressing the CENTER button until you see this message on the screen:
This works on at least some Verizon CDMA phones on which option 1 will not work.
Hard reset (option 4)
  2. With the device turned off, press and hold the VOLUME DOWN and CENTER buttons, then press and hold the POWER button.
  3. Continue pressing the POWER, VOLUME DOWN, and CENTER buttons until you see this message on the screen:
This operation will delete all your personal data, and reset all settings to manufacturer default. Press ?VolUp to restore manufacturer default, or press other keys to cancel. (works with Alltel touch pro)
Sep 29, 2009 | HTC Touch Diamond Smartphone
How can I do Hard reset my HTC S730 ?
1) Click Start
2) Click Expert
3) Click "Clear storage"
and follow on-screen instructions to reset your phone.
REMEMBER that all of your data will be deleted and the phone returns to factory deafult settings.
That should be all :)
Aug 21, 2009 | HTC FUZE Smartphone
I need to reset my password for my Sprint HTC Touch MP6900
Hard Reset
Press and hold the TALK and END buttons, and at the same time, use the stylus to press the RESET button at the bottom of your device.
Release the stylus, but continue pressing the TALK and END buttons until you see the following message on the screen:This operation will delete all your personal data, and reset all settings to manufacturer default. Press Action to restore manufacturer default, or press other keys to cancel.
Release the TALK and END buttons, and then press ENTER on your device.
Warning! Your device will be set back to factory default settings. Please ensure any additional installed programs and/or user data have been backed up before a hard reset is performed.
Another way of clearing the device storage and reset all setings back to factory default settings is to use the Clear Storage feature. You will lose all your data and files on the device storage when you use Clear Storage, so make sure to do a backup first.
Nov 20, 2008 | HTC Touch Cell Phone (Unlocked) - Soft...
Hard reset for a HTC Touch Diamond
3. Release the RESET button, but continue pressing the VOLUME DOWN and ENTER buttons until you see this message on the screen:
4. Release the VOLUME DOWN and ENTER buttons, then press the
Clear Storage
You can also use Clear Storage to reset your device back to factory default settings and/or format the internal storage.
1. On the Home screen, slide to the Settings tab and then tap All
Settings.
3. In the drop-down menu, select whether to Clear Storage only,
Format internal storage only, or Clear storage and format internal storage.
4. Enter “1234” and then tap Yes.
Sep 14, 2008 | HTC Touch Diamond Smartphone
T-Mobile MDA Logo
148 people viewed this question
Top T-Mobile Computers & Internet Experts
ismael castillo
Marvin
Marvin
matt
matt
Are you a T-Mobile Computer and Internet Expert? Answer questions, earn points and help others
