Question about Samsung SCX 4521F All-In-One Laser Printer
Scanner Just wanted to know does this machine scan i n colour in which resolution. Thank You [email protected]
    Sergeant:
  • 264 Answers
You may check the details below.
Internal Scan Depth: 16.7 Million Colors (24-bit),256 Gray Shades (8-bit)
Max Scan Resolution: 4800 x 4800
Optical Scan Resolution: 600 x 600
You may refer to the link
http://computers.pricegrabber.com/printers/m/11922472/details/
Posted on Nov 29, 2007
SOURCE:
Color image scan produces black and white pdf
This is purely down to the scanner settings. In the scan settings, choose the resolution and if to scan in monochrome (or B&W) or colour. SAVE the settings. Try a rescan and you should find that will work.
Nov 26, 2013 | HP Officejet Pro 8600
Is this TV digital
This is not a digital TV. This TV has only an NTSC (analog) tuner. A converter will be needed to tune digital broadcast TV stations, your CATV or satellite company supplies a converter to allow this set to display programs.
The display is limited to "480P" resolution, called "Enhanced Definition", which is a step up from the traditional NTSC standard of "480i" resolution or "Standard Definition". ("P is "progressive scan" and "i" is "interlaced scan"). Progressive scan provides a better picture quality when compared to interlaced scan images. High Definition or "HD" is a signal that contains data that allows display of images with 720P, 1080i and 1080P resolutions (the larger numbers indicate more information, or higher picture quality). Your TV will receive all signals, SD, ED and HD, but will down convert to ED. Signals can be brought into the set via 2 composite-video connections, 1 each component- and S-video, an RF antenna/cable-box/VCR input, and a 15-pin D-Sub analog RGB input. More info can be found here.
I hope this helps and good luck! Please rate my reply. Thank you.
Jun 01, 2011 | Philips 15PF7835 15 in. LCD Television
It's about 4 years old Samsung SCX -4521F, now it prints and scan very light colours. I have changed the toner with samsung original toner, but still quality of print is very poor, How can I fix it? thank...
Turn off the TONER SAVE mode if on.
With power cord detached, clean the HVPS contacts (between print cartidge & Printer's cartridge slot).
If still required increase the print resolution setting thru printer properties thru your PC.
If print bnot to the mark replace HVPS supply PCB.
Feb 11, 2011 | Samsung SCX 4521F All-In-One Laser Printer
Re. HP ScanJet 3970 Flatbed Scanner Horizontal lines.\r\n When I scan, I get light coloured lines approx 2mm apart across the complete scan, which show up primarily on the dark colours. Different...
Hi! I had a same issue with another HP Scanner model. I was not able to repair, so I ask my company to buy a new one. I know that it can be repaired as ething can, but as I undertand this issue occur as the head of the reader is not scrolling in the glass as expected and it can be for differnt reasons or power supply is not work properly.
Have more success,
Sly
Nov 19, 2010 | HP ScanJet 3970 Flatbed USB 2.0 Color...
Color has gone a little crazy. Printing in green etc. How to fix?
Hi..
Take the ink cartridge out and clean it with little alcohol and cotton, and make sure the cartridge is reseated properly.
Let me know.
Thanks
Smith
Aug 20, 2009 | Brother Office Equipment & Supplies
Scanning 35mm slides
No you need a slide scanner inkypete
Apr 22, 2009 | HP PSC 950 All-In-One InkJet Printer
Difference between ''Auot Color'' and ''Full Color Mode
Most Colour machines have three settings.
Auto Colour, Machine will determine if the original is Colour or Black and White from its scan. Then print in the format that best suits the original.
Full Colour, Machine will copy in full Colour regardless of Original type.
Black and White, Machine will copy or scan in B & W regardless of original type.
Hope this is of some help.
Ed
Apr 17, 2009 | Kyocera Office Equipment & Supplies
Scanning in colour
Who and where do you get the idea that you should be able to, to scan in colour you need a colour scanner, yours is not it has a greyscale scanner only.
This machine has a scanning kit option but that is not colour see specs below.
AR-NS2 Network Scanning Kit (optional) 4
Type:
Flat bed monochrome scanning system
Original Feed System: Platen/document feeder, simplex/duplex with RSPF feeds up to 39 opm
Resolution:
200 dpi, 300 dpi, 600 dpi
Image Format:
TIFF 6.0, ITU-T G3/G4 TIFF, G3/G4 single/multi-page PDF
Scan Destinations:
E-mail, Desktop, FTP, URL
Destination Profiles:
Up to 200
Operating System:
Windows 95/98/ME, 2000, XP
Network Protocols:
TCP/IP (includes SMTP, LDAP, FTP)
Network Security:
E-mail server user authentication
Software:
Sharpdesk Document Management Software (included)
Link to brochere of the AR-M 237 GREYSCALE copier
Jan 10, 2008 | Sharp AR-M237 Copier
Samsung SCX 4521F All-In-One Laser Printer Logo
148 people viewed this question
Top Samsung Office Equipment & Supplies Experts
HEMANT GROVER
Victorman
Victorman
jasbo
jasbo
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
