Question about Whirlpool LTE5243D Top Load Stacked Washer/Dryer
How do i get to the components?
How do I get to the components of the machine?
  • Anonymous May 23, 2008
    dryer drum does not spin
    Genius:
  • 1,073 Answers
Working on either since stacked the washer top should be off, if working on the dryer remove the top the top is held in place with 3 screws washer likewise
Posted on May 07, 2008
SOURCE:
The machine stopped working and tripped the fuse box i changed the fuse still not working
Something electrical has blown in the machine causing the fuse to blow. After replacing the fuse , the machine isn't going because whatever blew is now "open circuit" Have a look for obvious blow outs on any of the switches, control boards , all other electrical components and the wiring. look for telltale black marks where something has "blown" on the cabinet or around the components.
Mar 20, 2017 | Washing Machines
After short circuit how do i reset my washing machine
You should first remove short circuit and replace destroyed components and after that the appliance should reset itself. If is still not happend there is some other components destroyed including PCB.
Dado
Jul 27, 2014 | Electrolux EW1200i Front Load Washer /...
Bosch exxcel 1200 express
As the control board failed it could have let too much power reach any of the other components in the machine. Any electronic components could now be damaged. The new controller could now be damaged by power from the other parts. You could carefully replace them all one by one until it works, but this will be expensive. Buy a used machine of the same make and model (search Ebay) and swap all its electronics over in one go. Or replace the machine.
Dec 20, 2013 | Washing Machines
Water still in machine says LE on display
LE error code means Locked Motor Error.
Sometimes this can be cleared by unplugging then plugging back in the machine. If this does not clear it you have a faulty component.
This usually failure of a component called the Hall Effect Sensor which may need to be replaced.
Dec 16, 2010 | LG WM-2277HW Front Load Washer
What is the component called which has the live wire from the mains attached to it ? My wixe127 indesit has a burned brown/live wire to it. The component is located at the top right hand side of the...
It is possibly 1 of 2 components involved, the terminal block, or the thing they call they the capacitor or condenser as it is sometimes called.
This could be round or cylindrical in shape.
Nov 28, 2010 | Washing Machines
Fisher and paykel washing maching top loader screen does not light up?
If there is power to the machine and the display panel doesn't show any lights when 'power' is pressed there is a good chance that a fuse has failed in the motor controller module or that the module itself has failed.
Motor modules can fail when another component fails and overloads the module.
Modules should not be replaced without first checking the other electical components in the machine for resistance and/or continuity.
It's probably best to call an experienced tech who is familiar with F&P machines. I'm sorry not to help you fix the problem your self, but you can easily do more damage to the machine by not thoroughly checking and testing the machine. A repairer who is experienced won't replace a component without testing, and you won't have to pay for parts which might fail on installation..
Good luck....Nomess
Sep 05, 2010 | Fisher and Paykel WL26CW1 Top Load Washer
I changed the water pump and the devater valve the machine work for 5 min. Then went dead know power.
Unfortunately you've probably got a failed Motor Controller Board. This could be because of a water leak, or another component failed...When servicing F&P machines all components should be checked for resistance...Good luck....Nomess
May 15, 2010 | Fisher and Paykel GWL11 Top Load Washer
IBM Thinkpad X41 wont turn on.
change your RAM slot,or run it on single RAM.
Nov 06, 2009 | IBM ThinkPad X41 Tablet PC
Husqvarna sewing machine
There is an electronic component called a supressor, used to filter interference by your machine to the power in your home which may cause radios & TVs etc to have sound crackle or lines on the image each time you press the pedal........it is not essential to the safe function of the machine, tho' domestic harmony may be strained if others are watching TV at the same time you sew............but it doesn't always cause interference even without the suppressor
You may also have noticed a small amount of smoke and an acrid smell when this component failed.
Generally they are located in the foot control, although some machines bury them inside the main body somewhere near the power inlet.
Ensure machine is unplugged and have a look inside the foot pedal for a rectangular "electronic" looking component with two stout wires.......it will probably be a brown yellow with oozing nasty thick brown gunge.....undo connectors and remove it ....wipe excess nasty stuff off and any associated residue with a fast drying solvent like denatured spirit or metholated spirit.
Now, with the offender removed, re-assemble foot control and you are back in business..............if the component is inside the machine, it will look the same, but the exact location may take some finding......open the base and look near the power inlet for something bearing the former description.
Mar 08, 2008 | Husqvarna Viking 1
Whirlpool LTE5243D Top Load Stacked Washer/Dryer Logo
63 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
