My dryer vents down through the basement and then snakes its way about 35 feet to an exterior wall where it vents out to the back yard under the deck. I have lots of water building up in the venting...not droplets but several quarts if not gallons..The A/c is in the basement so it is pretty cool down there is this simply condensation...Or is the run too long... I don't have many other options... Is it bad to just vent it right into the basement??
Hi, W/D here.
It would be best in your circumstance to slope your vent like one might slope a drain. 35 feet is waaaaay too long, 20 feet is max, and you can deduct 6 feet for every bend. If you can reconfigure your vent to a sloped drain, this will help.
The coolness of the basement is a contributing factor, but normally, it doesn't figure into the issue.
If you cannot shorten your run, or slope your line, you might do well with a trap that would have a mini sump pump in it. These are available from A/C companies, and are automatic in their operation. I have had one in one of my units, and the cost wasn't unreasonable. You can probably find one on-line (EBay?)
Venting into the basement may resolve your water issue, but you still have to deal with the lint that "escapes" the lint trap. Most of it will likely wind up in the air conditioner, and all over whatever you have in your basement.
A mini sump sounds like your best option, even if you have to set up a schedule to clean it out occasionally.
Best regards, --W/D--
Testimonial: "thanks ..I think i'll have to go with the mini sump , due to the dryer location and not being able to shorten the vent run..."
