Question about M-Audio FireWire 410 External Sound System
Keeps blinking my firewire 410 doesn't turn on, but blinks rapidly when plugged in. What does this mean, how do i fix it?
  • Anonymous Sep 23, 2008
    I have the same problem.
  • Rambo noir Nov 03, 2008
    I have a problem with my firewire 410. I have left it on even when my G5 Power PC is off (Blue light stays on) because everytime I got out of Logic Pro 7 and turn the interface off, the blue light would start blinking.
    Now my interface completely crapped the bed. Don't know if it's because I always left it on. My computer just fails initializing core audio when I start up Logic. It made every software on my Mac run real slow and sometimes not even open when I kept the troubled firewire410 plugged in. When I disconnected the firewire everything runs fine exept for I can't record now. Is my recording interface trashed? Can anyone help?
  • 382 Answers
It means its waiting for your computers operating system to recognize it. UNplug it. Update your operating system to the latest version ( free ), and then go to and download the latest drivers.
Do not ever install drivers for a device while its connected.
Plus it would help to know whatt kind of computer and what your operating systems is.
Keep me posted.
Posted on Dec 05, 2007
What does a orange power light mean
please see the commentary. God bless you
  • The majority of laptops will display a solid green, blue or purple battery light to indicate that the battery is fully charged. Most manufacturers indicate that a laptop is in the process of charging by displaying a solid or blinking green, orange, blue or purple light. If your battery indicator light is green, blue or purple, the battery is probably functional, regardless of whether the light is blinking. If the light is solid orange, the laptop is probably in the process of charging.
Battery Error Coneventions
  • Many battery manufacturers use rapidly blinking lights to indicate that a battery's charge level is low. In general, a laptop will rapidly blink orange or red when its charge drops below a certain level until the computer is plugged into a power outlet and charged. If your laptop's battery indicator continues to blink rapidly in orange or red or if it remains red even when it is plugged into the charger, it indicates a problem with your battery or the charger.
Read more:
Sep 25, 2013 | Computers & Internet
How to fix Rapidly blinking left turn signal on 2007 BMW 328i?
One of the bulbs is not working. Check and fix.
Jan 14, 2013 | 2007 BMW 328i Sedan
Tachometer works sometimes and won't work others, plus the right turn bsignal blinks rapidly ; what is the cause and how to fix
Check the right indicator bulb either front or back wouldnot be working replace it it will work normal.
Jan 20, 2018 | 1997 Chrysler Sebring
What does theblue light mean when its blinking
the steady, blinking blue light means it is working. If the light blinks quickly, ususally 3 times, then it is either turning itself off or turning itself on. if you're getting a steady blink, try holding the button down long enough for it to flash rapidly 3 times in succession. after that, it should blink no more, because you have just turned it off. Want to turn it back on? hold the same button down until it flashes rapidly 3 times again, and you have just turned it back on.
Jan 23, 2011 | Mad Catz PS3 Bluetooth® Headset Wireless...
Blinking yellow power button xps 410 will not turn on
I suggest replacing the memory as the diagnostics lights suggest.
Memory can and does fail in some cases.
May 04, 2010 | Dell XPS 410 PC Desktop
When 1 is inop and the other rapidly blinks that generally means a bad ground to the front light if you can't find it just attach another ground wire to the bulb socket and see if the light blinks normal.
May 27, 2008 | 2000 Mitsubishi Diamante
Rover 620ti
definately operated at 5400rpm, that should be minimum. Those all audio apps recommend recording at 7200rpm, ala 3.5 hard disks. It's the set standard for hard disk recording. The drive is spiining to slow to keep up with system clock speed.
Keep me posted.
Dec 10, 2007 | M-Audio FireWire 410 External Sound System
Lots of noise when laptop power cord is plugged in
You must be running on pc, or it sounds like you may have a ground loop issue. If you are running a mac, then bus power over the firewire should be enough. If your running on a pc, try getting a pcmcia card with 6 pin firewire ports. If not then your pc laptop will have to power the 410 via ac adapter. That means both should be plugged in tot he wall. Ive gotten that interference before, and gett it on any audio, whether im producing or playing itunes. I find the trick is to reset the 410 via the output window in the top right. It's right above the level knob. Also, try just installing the latest driver, with the 410 disconnected, then launch it from a different file path than the icon.
I still use it for the macbook pro, and its not always top notch. I bought it 3 years ago for 500, and i see what 500 buys nowadays.......MOTU!!!!
Keep me posted.
Dec 08, 2007 | M-Audio FireWire 410 External Sound System
Open Questions:
M-Audio FireWire 410 External Sound System Logo
870 people viewed this question
Top M-Audio Computers & Internet Experts
Gareth Cockram
Gareth Cockram
mukhtar21 shaikh
mukhtar21 shaikh
John Bolton
Are you a M-Audio Computer and Internet Expert? Answer questions, earn points and help others
