40 Other Users Have The Same Problem - Continued
Comment by catalystiscl, posted on Mar 20, 2009
that site doesnt work anymore any other ideas?
Comment by Guest, posted on Feb 20, 2009
drivers curupted
Comment by koliver001, posted on Jan 31, 2009
driver for cd-rw drive corrupted
Comment by Guest, posted on Jan 22, 2009
CDR/DVDR Stopped working 2 weeks ago. Isn't recognized when loading CD.
Comment by Guest, posted on Jan 18, 2009
optiarc. cd-rw crx880a ata is no working
Comment by ef_melo, posted on Jan 05, 2009
The driver is installed but it is no recognized by the system in order to be used by the end user.
Comment by Cisi, posted on Dec 19, 2008
after installing Nero 7 Optiarc CD - RW CRX880A refuss to work
Comment by madnaniajay, posted on Nov 21, 2008
OPTIARC CD-RW CRX880A ATA DEVICE problem
Comment by gp_phillips, posted on Nov 20, 2008
CODE 39!
AAAARRRGGGGHHHHHH!
Comment by neil_dianna, posted on Sep 29, 2008
the optiarc driver is installed but it is not working properly
Comment by Guest, posted on Sep 25, 2008
leitor de cd nao funciona optiarc crx precisa ser instalado
Comment by Friedolin60, posted on Aug 18, 2008
Habe Nero ( installiert doch jetzt ist mein laufwerk weg zeigt kein Laufwerk an kann keine cd abspielen habe winows Business
Comment by Guest, posted on Aug 18, 2008
Notebook can not find device driver.
Comment by kvans87, posted on Aug 08, 2008
Thanks for the effort, but I had no luck with deleting the registry entries, mine only seemed to have the upper registry entry though, is that bad? HELP! thanx!!!!!
Comment by taote, posted on Aug 04, 2008
My notebook have a OPTIARC CD-RW CRX880A ATA DEVICE problem, don´t read cds.
Comment by gouse1968, posted on Jul 21, 2008
Device is working properly but not reading any type of discs
Comment by Guest, posted on Jul 12, 2008
IN my pc i have installed nero 7 due to which it is not working OPTIARC CD-RW CRX880A ATA DEVICE
Comment by Guest, posted on Jun 01, 2008
I have a new Acer laptop, I cannot burn with cd or dvd, it keeps asking me to insert a cd or dvd, it cannot read it.
I am trying to burn my backup for the pc and it shows optiarc cd-rw crx880A as a cd or dvd to be inserted.
Does it mean I have to buy that type of dvd?
GL
Comment by click68, posted on May 29, 2008
error 39
Comment by Guest, posted on May 26, 2008
I have the same Optiarc device on a lenovo laptop. The solution about deleting two registry entries does NOT work for me. Any other suggestion? Thanks!
Comment by Guest, posted on May 21, 2008
el sistema me dice que se encuentra dañado pero nquiero saber como puedo restaurar el controlador ya que no me reconoce la unidad
Comment by Guest, posted on Apr 26, 2008
Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39)
Click 'Check for solutions' to send data about this device to Microsoft and to see if there is a solution available.
Comment by Guest, posted on Apr 04, 2008
my laptop cant read from cd,i knewfrom devicemanager to get:
optiarc cd-rw crx 880 A ATA Device.
please kindly tell me what to do.
Comment by Emotobucket, posted on Mar 12, 2008
I am trying to burn a movie to a Maxell DVD+RW and my CRX880A won't even recognize that there is any sort of CD in the drive. When I go into Computer, it does not register that any sort of CD is in. I only have this problem with blank CD's. Windows Media and Nero do not allow me to burn since... well, they don't think there is a DVD RW in the drive.
Comment by riddicksteel, posted on Feb 28, 2008
my optiarc cd-rw crx880a ata isnt working with vista anymore, it keeps coming up with the driver might be corrupte or something along those lines. I have uninstalled it and reinstalled it may of times but it still keep coming up with device failed to install and when i go to check the promblum out it keeps saying that the driver might be curropt, any body got a sulution to this? plz email me at
manzano.yonatan@gmail.com thank you.
Comment by Guest, posted on Feb 17, 2008
everytime i plug in my flash drive i lose the use of my cd-rom drive and the computer does not acknowledge
Comment by shamal4, posted on Feb 04, 2008
Optiarc Cd-CR CRX880A ATA Device
Comment by lisaetx, posted on Jan 07, 2008
How do you get into the registry to make the changes toby suggested????
Comment by help2008, posted on Jan 04, 2008
DOSE NOT READ CD
Comment by Guest, posted on Dec 26, 2007
Comment by ornot_doobie, posted on Dec 17, 2007
tried to install software for my new aiptek camera and after restart, my optiarc cd-rw crx880a ata device no longer works. I did an update, disable, enable, unistall, find hardware, and it says I have the most up to date driver for this device and still not seeing the drive. Can anyone tell me what to do?
Comment by toby89, posted on Dec 03, 2007
My daughter's ACER Aspire 3680 laptop DVD/CD drive stopped working after an attempt to install a printer driver. Device Manager for the drive, under General, says "windows cannot load the device driver for this hardware. The driver may be corrupted or missing (code 31).
I'm going to google for a driver, and see if I can fix by updating the driver.
If there is another/better fix, I'd appreciate it.
Sid
Comment by japalma, posted on Dec 02, 2007
Optiarc cd-rw crx880. unable to acess cd/dvd. device manager says no problem, drivers up to date. acer arcade says unable to locate a cd/dvd player on the computer! can anybody tell me what to do short of getting a better computer? thanx
Comment by jcrcp, posted on Dec 02, 2007
Comment by Guest, posted on Nov 30, 2007
i have installed nero 7 due to which my CD-RW/DVD DRIVE NOT WORKING
so i have uninstalled nero 7 from my pc.
but now my pc is not able to detect the cd-rw/dvd drive and when i opened the properties - it is saying configuration information file is damaged or incomplete
so can anyone help me how to solve this problem and any website to download the necessary software or drivers for this cd-rw/dvd drive
i will be waiting for the reply
