Usb devices not detected
I'm the owner of a VGC-LA series (PCG-242M) Desktop all-in-one computer.
I have problems with my USB accesses.
My control panel doesn't detect my HP Photosmart C5283 printer (working yesterday on that same computer) and my Ipod.
I have 4 usb-drives; none of them are detected.
What can I do...
(When I first installed my computer, in april, the same thing happened to my CD-DVD-drive, but then for no reason, it reappaeared...Culd it be a weakness of the system?)
How can I fix this?
Thank you for your quick answer,
Stephanie stephaniekegels@hotmail.com
  • steffie68 Nov 29, 2007
    The installation of the printer and the connection of the ipod went right. I used it before. It is a problem that occured today, after weeks/months of working correctly...
    Did anyone see this before?
  • Anonymous Feb 29, 2008
    e-machine does not communicate w/printer
  • 83 Answers
Well, I am not sure about Hp photosmart, But most printers, Like all hard drives, you must install a CD-Rom disk in order to do this, I see that your CD-DVD-Drive was not working also, It should've came with a disk to install it on probably floppy, or your old driver, Hope this helps.
Posted on Nov 29, 2007
SONY VAIO PCV-1112 CANT USE KEYBOARD OR MOUSE
Please test it using other USB keyboard and USB mouse, and see the device status in the Control Panel (Control Panel, Device Manager). Is the keyboard item missing? Is there any USB item with an exclamation mark?
Feb 18, 2014 | Sony VAIO PCG-505 PCG-671L PCG-700...
My buffalo drivestation external harddrive don't power up?
A USB hard drive is a portable external storage device that works just like a conventional hard drive. The device is simply plugged into a USB port on your computer as you would connect a flash drive. Unlike a flash drive, however, a USB hard drive can store a much larger amount of data. If your computer will not recognize your USB hard drive, you can try troubleshooting steps to resolve the problem.
Plug one end of the USB cable into the port on your hard drive and plug the other end into the USB port of your computer. Ensure that both ends of the cable are connected securely. Open "My Computer" (Windows XP) or "Computer" (Windows Vista/7). The USB device should be listed as "removable disk" once it is plugged into the computer. If it is not listed among the available drives on your computer, proceed to the next step. Ensure that the data cable is working properly. Sometimes they become faulty due to overstretching age or heavy objects sitting on top of them. Try another USB cable if you have one available. Disconnect all other USB devices from the computer as they may interfere with the operating system detecting the external hard drive. Reboot the computer if the USB hard drive is still not recognized. Plug the USB cable into another USB port and check to see if the device is detected. If you are using a USB hub, remove the device and plug the external hard drive directly into a USB port. If the computer still fails to recognize the device, the external hard drive itself may be experiencing a hardware problem. Check the status of the hard drive in the "Device Manager" window. Under Windows XP, right click "My Computer" and select "Device Manager." For Windows Vista and Windows 7, click the "Windows" button in the lower left corner of the screen, then type "Computer Management" in the search bar and press "Enter." Select "Device Manager" in the "Computer Management" window. In the Device Manager window, click the "+" sign that appears beside "Disk Drives." If the external drive is not listed, click "Other Devices" in the Device Manager window and see if an "Unknown Device" appears. Windows 7 First, please disconnect all USB devices and then perform the following steps:
Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically. If the hard drive that has failed is the same one that you are trying to recover from might the reason that you are getting this error. This could be an issue where the part of the hard drive you are trying to access is corrupt and not accessible which would explain the reason that it would let you access the other partition. Now I have seen cases where Malware can break the link of a Hard Drive. So let's try a couple of steps. Let's go back in to "Disk Management" Lets right click on the partition that you are not able to access and select "Change Drive Letter and Paths" Now try selecting a new Drive Letter. This will restore the path if it has been broken. The external hard drive may have been detected but the device is not working properly. If it is still under warranty, take the device to the computer store where it was purchased to have it repaired or replaced. Hope this helps.
Jan 02, 2013 | Buffalo Technology Buffalo 1TB Drive USB...
Hp dc7100sff cant detect usb drives except printer
hello,
For this you sholud go to in xp my computer ->right click ->manage->device manager->usb ->right click and give to all update driver this is valid also for win 7
Sep 24, 2012 | HP Compaq dc7100 PC Desktop
Hi I need vaio pcg-242M drivers contact :prosper4@gmx.com thanks
Hello Prosper, I found drivers for a Sony Vaio VGC-LA1. It would appear that it is just a different name for the same model. These should work fine for you. Hope I have solved your problem, have a great day Prosper!
May 08, 2011 | Sony VAIO VGC-RB34G PC Desktop
Computer: Sony Desktop Model: PCG-242M. Computer does not start, with the inclusion hear one long beep and two short beeps. What is the problem?
Based on what you have presented...
1 long 2 short - (Video Controller Failure or faulty add-on card
Do you have an installed video card? Does the unit have a built in Card? (In other words part of the mother board?)
If you have an installed card check that it is not loose... If it is still not functioning (and)
If your unit also has a built in video card that is disabled... go to the BIOS and enable it... see if your unit will boot up...
If the video card is not loose and you do not have a built in card... you may want to see if you know someone with an extra card to loan... or purchase a new one....
Mar 31, 2011 | Sony VAIO VGC-RB34G PC Desktop
Looking for instruction manual for sony vaio desktop model pcg-281L
PCG-281L is the hardware configuration code of the computer. Based on the configuration code the computer belongs to VGC-LT1 series computer model. From the below link you can download the Manuals and Specs for this series models:
http://esupport.sony.com/US/perl/model-documents.pl?mdl=VGCLT10E&LOC=3
Thanks!!!!
Dec 11, 2010 | Computers & Internet
Hello, i just cant access anything through my usb, can u help me?
Hi ,
Please try these steps that im mentioning and i hope it works out for you .
go to ?start ?right click my computer ?click on manage?device manager .You will see the drivers listed with a + sigh next to it .Look for universal serial bus controler and then click on the + sign nex to it ...then right click un uninstall usb root hubs so anything that has the word hub right click on it an then click on uninatall restart the computer and then check if the usb gets detected ...
If this does not work go to the hp website www.hp.com/support ,once the page opens up and where is says select a country or a region select united states then click on the arrow and where it says for product put the model no that is HP Pavilion a420n then click on the arrow and then select software and drivers downloads from the next page which will finally take you to the Select a download page then it shows you the compatible software and drivers.The fourth option saya BIOS IN BLUE cliclk on the BIOS update for A7V8X-LA motherboard and on the next page click on download .A dialogue box opens up so click on save and then save it on the desktop .Go to the desktop and then run it .Restart the computer and then it should work
all the best
May 12, 2010 | HP Pavilion a420n PC Desktop
Usb ports no communication with compurter but supplies power. what is wrong ?
Click Start
Click Control Panel
Click Classic View
Click System
Click Hardware
Click Device Manager
Does the 'USB' branch of the tree show the USB ports?
Is there an 'Unknown Devices' branch of the tree?
Either way, the software "device-drivers" for the USB ports are not installed, or not installed correctly, and so you'll get the symptoms that you've observed -- power without device-recognition.
Access http://support.dell.com and click "Detect My Computer", and download and install the device-drivers for the USB ports.
Dec 30, 2009 | Dell Dimension 4600C PC Desktop
Lacie big disk 2.0 usb
For anyone with a Big Disk drive that doesn't get recognised by Windows and gets a TUSB 6250 message in Device Manager, the cause is very likely to be the power supply. Although the drive will be powered up, it is not spinning at the correct speed. I tried all of LaCie's technical support suggestions, some of which are outlined above and none worked. They finally suggested getting a new power supply. This solved the problem (Wattac, £22). This problem has affected a lot of LaCie Big Disk owners...
Mar 26, 2008 | Computers & Internet
Computers & Internet Logo
446 people viewed this question
David Payne
David Payne
