Question about Nokia 446 XS Monitor
An Old Nokia Monitor
Hey there i have an old Nokia Monitor Model 446xs and i can not find a solution on reseting the password on my monitor navi controll i even tried calling nokia and they have nothing on file
  • 2992 Answers
SOURCE: Need manual for nokia 447za computer monitor
The adjustments you need to make are for the screen geometry. I haven't been able to locate a manual, so I can't tell you exactly how to access them. Usually there is a menu button that brings up the adjustments, and a couple more (usually marked + and -) to go through the choices and change the settings. A fourth button enters your choice. On some monitors there may be an adjustment knob/button combination. Press the knob to enter, and turn the knob left or right to adjust and choose.
Having said all that, what you want is called the pincushion setting. When set properly the image will be square. Improper settings cause the edges to bow in or out. Depending on how many adjustments your grandkid messed up, you may have to go through some other settings as well. Most monitors have adjustments for:
- vertical and horizontal position and size
- pincushion (adjust for the straightest top and bottom edges)
- trapezoid (also called keystone) which adjusts the top and bottom widths in opposite directions (adjust for the same length)
- parallelogram which adjusts the top and bottom positions in opposite directions (adjust so the sides are straight up and down)
There may a few other choices, but the previous ones have the most effect. There may be a choice in the menu to reset everything to midrange. If so, take it and then use the adjustments to fine-tune if necessary.
Posted on Feb 15, 2009
0 characters
1 Points
Forgot password to an old computer account hp 7500 how do I get in
boot with hiren boot CD and reset password . goole foe hiren boot CD and download latest
Aug 12, 2014 | HP Compaq MV 7500 17" CRT Monitor
Gateway FPD 1975W LCD monitor,on light blinking, but wont turn on
I will assume you have already try this monitor with other PC? You should also set the PC VIDEO output resolution to be at native resolution of this monitor, which is 1440x900 @60Hz.
Mar 29, 2010 | Gateway FPD1975W 19" LCD Monitor
Problem started with a white screen, now It just remains black, installed my old monitor, works fine, put the KDS back in line, no picture, just black tried on off on the monitor and on the computer,...
jimmoser45, Could be trash! Could be a Trade-in on a new monitor! Try to follow me on this will-ya!!! You take your K226WDB to store and maybe get $10 knocked off the new one? Anyhow, you walk out with new LCD display and 1, poss 2yrs warranty. But the sales guy who just toted your K226 back to the "bench tech" in the back room and says to his 'tech' "Hey, here's one more! You fix it,,, give it to your 8yr old!" The tech replys. "Hey... Thanks. I'll look it over after break." Well later that day the tech opens up you're K226 looks at some stuff inside and then proceeds to make a repair that might bring new life back to this monitor. Maybe an hour later the tech hooks up the K226 to a pc and pushes the "ON" button of the monitor and with $5 in new parts,and a little LUCK an 8 yr old will have an LCD monitor with a nice, bright, crisp text and graphics being displayed on your old unit!!! Check out youtube first for video clips on "lcd monitor disassembly" and "lcd monitor repair" to help you make a decision on what steps you might take to keep your K226 unit out of an 8yr old's bedroom!! 12fixlouie
Nov 20, 2009 | KDS K226WDB Monitor
Ned to find the right adapters and drivers to fix poor display
This monitor albiet old can do a whooping 1800 x 1440 resolution. I don't think that the monitor is your problem at this point but your Video card. What type of video card do you have in your system and are the drivers correctly installed for them. You can find the drivers for the monitor at
May 22, 2009 | Nokia 445 Pro 21" CRT Monitor
ViewSonic VX2235wm working fine on old computer, wrong on new
especially the old drivers. If you didnt remove them then you will have issues.
Dec 19, 2008 | ViewSonic VX2235WM Monitor
BenQ FP737-D 17 Monitor
Hey... what you need it a new backlight inverter, your old one it busted...
Sep 14, 2008 | BenQ FP737S-D 17" LCD Monitor
Black screen
It's seems your backlight inverter are burnt out...Get a new one..or repaired old one by yourself.
Here how it done...need to replaced a new capacitors. Good lucks!
Aug 19, 2008 | X2Gen MG19MY 19" LCD Monitor
Password on toshiba notebook
Please visit this website as it has some methods for getting by or cracking that password protection:
Good luck and let me know if these methods work!
May 14, 2008 | Kogi L7CH Monitor
StudioWorks 700s Monitor No Signal
It could be that the resolution settings that you had with the old monitor are not compatible with the new monitor. Try hooking up your old monitor and either lowering or highering the resolution and see if that corrects the problem. Can you give me the model number off the new monitor so I can further look into the compatibility of the video card and the monitor.
Apr 29, 2008 | Proview PL926WBi 19" LCD Monitor
Envision EN7410e monitor
Just fixed mine. Maybe it's a few years late. Hope you guys still have the display. It's the power supply board. I've just replaced 4 bulge capacitors near one edge of the PS. They are 2x1000uF 10V, 1x470uF 25V & 1x470 10V. I salvaged my parts from an old CRT monitor. Hey you can go green with your repairs too!
Apr 25, 2008 | Envision EN7410 17" LCD Monitor
Nokia 446 XS Monitor Logo
35 people viewed this question
Top Nokia Computer Monitors Experts
 Mike M
Mike M
John Trigg
Are you a Nokia Computer Monitor Expert? Answer questions, earn points and help others
