Question about Kenmore Elite 45986 Front Load Washer
My washing machine issue
The rubber ring ( i believe that's what it's called) in my washing machine had rip apart. Can i fix it by myself and is there any rubber ring available at any stores, or should i order online? Can anyone help me solve this problem
    Champion:
  • 249 Answers
Order on line it should be easy to get one
Posted on Nov 29, 2007
  • eamonn close Nov 29, 2007
    it called door seal or gasket ok .close ireland
SOURCE:
Hi the large rubber section that joins fom the door t the drum inside on my Aqualtis AQ9L 29 I 9kg washing machine has come off????? Is there any way I can fix this back on myself? Any tips? The rubber...
there is usually a ring type clip with a spring on it that goes around the rubber section to hold it on...I am assuming this is a front load washer...you can remove the top of the washer by removing a couple screws..look inside for the clip..it may have fallen off inside....then you can put the rubber back in place and re-attach the clip
Jun 11, 2011 | Washing Machines
I just moved into an apartment equipped with a stackable moffat MCCH6110HSS washer and moffat 350A4502P547 dryer. I've discovered that the washer appears to repeat the rinse/spin cycle over and over again...
HI, I spent many years in apartment maintenance and most communities have maintenace staff to fix issues you have with their equipment,call the leasing office.The most likely cause is a bad timer.
Mar 06, 2011 | Washing Machines
The rubber ring inside the washing machine came out and a metal ring was under it, i dont know how to fix it?
that rubber is called the bellow. snap the bellow back to the machine. place plastic ring over it into the grove and work it all the way around. that metal ring should have a spring on it. use a needle nose pliers and pull the spring so it stretches, metal ring should snap right in place.
Feb 05, 2011 | Whirlpool WFW9200S Front Load Washer
Amana NFW7200TW washer - door seal ring has detached
The ring is a clamp that keeps the rubber part, called the bellow, attached to the front panel of the washer. To reinstall hook the edge of the bellow around the lip of the opening in the front panel (the hole through which you put your laundry). Then take the clamp and seat it in the groove of the bellow behind the lip of the front panel. The spring on the clamp should pull the bellow tight to the opening of the panel.
Like so:
Jun 11, 2010 | Maytag NFW7200TW Front Load Washer
Front gasket ripped
Typically the tear comes from something getting caught on the rubber boot or bellows as it is called on this machine. Or if a pen is left in a pocket it can cause a hole.
The bellows for your model is part number 8182119 and typically runs about $80.00
Here is a link to parts break down showing the bellows # 5 on this diagram. It is not hard to replace but you have to be fairly mechanically inclined. It is held on by a spring clamp in front and a large screw clamp to the tub.
http://www.searspartsdirect.com/partsdirect/showSubComp.pd?imageUrl=http%3a%2f%2fc.searspartsdirect.com%2flis_png%2fPLDM%2fK0503012-00002.png
Apr 20, 2010 | Kenmore Elite 45986 Front Load Washer
Maytag epic z-ripped piece of door seal
I would say that the rubber may have gone into the system, and is probably clogging up the water outlet hose, and or the Pump. This is a bit of a "Fix' it will require the taking off of the motor and Hoses, connected to see where that bit of rubber is.http://www.letsfixit.co.uk/html/washing_machine_faq.html
http://www.appliancerepair.net/apnet/frameset?http://www.appliancerepair.net/apnet/washer/toc.htm
If you do not choose to repair this yourself, using those links above. Then please get a "Quote" for repair.
Mar 24, 2010 | Maytag EPICz 3.7 cu. ft. Washer
Rubber ring ripped
You can buy and fit a new door gasket if you have the required mechanical knowledge
Take the power off , the top off remove the fitting band take off the old gasket and re-assemble in the reverse order
Jan 03, 2010 | GE WSXH208A Front Load Washer
The rubber seal came off of the inside during the spin cycle - behind door against the tub -- and a wire ring came out. I put the rubber seal back on but have no idea where the wire ring would go? Is this...
The wire ring is the seal retaining spring, it fits in a groove at the rear of the door seal.
Double the seal back in the drum, and fit the spring around the seal at the rear of same, it fits inside a groove, it is difficult, so persist and be patient.
Please rate my solution.
Thanks.
Nov 03, 2009 | Bosch WFMC 3200 Front Load Washer
Whirlpool Duet Washer GHW9100LW2 Bellow keeps on ripping
looks like it was a hair clip in my washer that did this :(
Apr 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
90 people viewed this question
fordexpert
Kristen Denison
Kristen Denison
Level 1 Expert
Gordon Richard...
