Question about Brother IntelliFax-2820 Laser Fax
Problem in accepting the tonner by machine
When i insert a tonner into brother 2820 a massage displayed
THE TONNER LIFE END REPLACE THE NEW ONE
  • 89 Answers
First make sure the toner and drum unit are seated correctly. It may be that the chip on the toner is bad.
This has also been known to work.
Open front cover, leaving the toner cartridge and drum unit in.
Press Options button, when "Replace Drum?" comes up quickly press the Start button. I
mmediately press the "1" and "0" button. The display will say "Accepted" and the error will go away.
You need to do this pretty quickly for it to work.
Posted on Nov 30, 2007
This is a common problem. You need to be sure that the toner and drum unit are seated correctly. I assume you. You may also want to try a different toner in case the chip is bad on it.
The following has been known to work also. Open front cover leaving the toner cartridge and drum unit in.
Press the Options button,
When "Replace Drum?" comes up quickly press the Start button.
Immediately press the "1" and "0" button. The display will say "Accepted" and the error will go away.
You need to this these pretty quickly.
SOURCE:
My printer is requiard toner rear end
You meen tonner near end you have to purchase a new tonner cartridge and replace or refill if you refill it you must get with your cartridge a reset card
Apr 15, 2014 | Xerox Phaser 3100MFP/S Laser Printer
Sp 1200sf ricoh printer shows tonner life end
"toner life end" means that you should replace the toner.
Mar 04, 2012 | Office Equipment & Supplies
I change the drum for my fax machine, but it still says Toner Life End... and it is a bran new cartridge?? I tried turning it off and on, and unplugging it... but it still says Toner Life End... how do i...
1. With unit powered On, open the front cover.
2. Press the "Options" key. Display will show "Replace Drum?"
3. Press "Start" key.
4. Press 1,0 .
5. Display will show "Accepted" for approximately 2 seconds. Then display will change to "Cover Open".
6. Close cover and see if Toner Life End error message has gone.
Good Luck and Thank You for using Fixya.
Jan 08, 2011 | Brother IntelliFax-2820 Laser Fax
I replaced the black tonner on my Canon ir 3320n & this eror sho
try to set the toner a few times more, this error code is developer trouble.So it could be that toner isnt recognized, not properly inserted, or you have some tape leftovers on toner, or you have broken developer unit, or ...
May 06, 2010 | Canon ImageRunner 3320N Copier
Installed new cartridge and comming up machine won't regognise it saying tonner life end install new cartridge
To reset the sensor after installing a new toner cartridge follow these steps. 1. With unit powered On, open the front cover. 2. Press the “Options” key. Display will show “Replace Drum?” 3. Press “Start” key. 4. Press 1,0 . 5. Display will show “Accepted” for approximately 2 seconds. Then display will change to “Cover Open”. 6. Close cover and see if Toner Life End error message has gone.
Try this. We are Brother authorized.
Apr 15, 2010 | Brother MFC-7420 Laser Printer
Had toner life end message. Replaced toner and drum with oem,machine reset but now just making blank copies. Tried to print internal report that's blank too
4. Press 1,0 .
Please note that this must be done with a new cartridge so the unit will see that there is toner in the cartridge.
Aug 01, 2009 | Brother IntelliFax-2820 Laser Fax
We have to install a panasonic DP -8016P which is inpacked condit
so your machine is new then.
there is a installation manual inserted at the quick guide and cd manual
Mar 13, 2009 | Panasonic DP-8016P Copier
TONER LIFE END APPEARS ON LCD
try opening front door, press "options" then "start" then "1" and "0". if screen shows accepted, you're good to go. close front cover.
hth,
razors
Feb 06, 2009 | Brother IntelliFax-2820 Laser Fax
Brother 2040
Tonner light is blinking means that the tonner life is end.
The other problem come from usb cable change the cable.
Jan 21, 2009 | Brother HL-2040 Laser Printer
Brother IntelliFax-2820 Laser Fax Logo
201 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
