Question about Microsoft Excel for PC
FORMULA FOR TEXT FORMATING
SIR,
I AM USING EXCEL 2000, IS THERE ANY FORMULA THROUGH WHICH WE CAN GIVE AT TEXT OUTPUT IN CERTAIN FORMAT SUCH AS BLINK OR COLOUR CHANGING FORMAT.
SUPPOSE ANY DATA MISMATCH HAPPENS IN CERTAIN CELL THEN THE RESULTANT CELL WILL GIVE AN RED BLINKING TEXT. "ERROR"
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 58 Answers
You can use "Conditional Formating", just look for it on the help. It is a great tool and it is relatively easy to set, you can choose blinking red text when the condition occur, in your case mismatch.
I have excel 2007 but I know this function exists in 2000 as well. Let me know if you need more help and I will be happy to assist you
Posted on Dec 18, 2007
    Novelist:
    Champion:
  • 244 Answers
Yes of course, if you have a little background of visual basic programming that's possible you can enhance your requirements.
Please see link http://www.techonthenet.com/excel/questions/cond_format1.php
Posted on Nov 30, 2007
  • Cheater Cheater Nov 30, 2007
    I just the example given before you proceed to blinking colors mode. It is little harder than this example. You need to use visual basic coding for great result. Please don't forget to rate me SOLVED.
How can i export the data tally to excel
There are 2 ways to do it..
Step 1
You can export as text and import it back to excel using the text file you created.
Or
You can select HTML and give the file name as eg-XYZ.xls
Step 2
You can export all reports and statements. For this a separate export button is provided in right hand button bar. To do this go to any report e.g. day book you to export or any statement e.g. balance sheet. You would see export button on top right hand side on button bar. Press it and a screen would pop up with export related options.
The first option is format of data to be exported namely ASCII, HTML, SDF, and XML. Which ever application you are importing this data in would decide in which format you should export the data.
For statements like balance sheets and trial balance which we use to send and import file in word and excel etc. HTML format is good. We need minimum formatting in this format while using it in MS Word and MS Excel.
certain applications accept continuous data where we have defined field length. Then ASCII format is better.
For application which accept SDF and XML format these formats can be chosen.
Give a file name and the exported file is saved in the parent Tally directory on your computer. You can now use that file to import its contents into another program, send it as it is (say if it is HTML file) to a colleague or view it using a browser.
Step 3
Consider exporting day-book.Go to day book press export button or use shot cut key Alt+E. Exporting screen will displayed.
Press Back space on your keyboard. And select Format as ASCII (comma delimited). Now give output File Name as Daybook.csv, now select some other option you want to export from the bottom of the screen.
Press enter to accept screen. Day book is exported in to tally program folder. Check program folder for file daybook.csv,
Double click on it, the file will open in excel program. If you want it in excel work sheet file, use the option Saveas, and save it in Microsoft excel workbook (*.xls) format.
Hope this is helpful. Let us know if the issue is resolved.
*Rating and Comments are invited for this solution
Nov 24, 2010 | Tally T2245 Matrix Printer
I HOW I EXPORT TALLY 7.2 DATA IN EXCEL FORMAT
Step 1
Or
Step 2
Step 3
Nov 10, 2010 | Tally T2245 Matrix Printer
When I enter a formula the cell displays the formula and not the result. For instance, I type: =left(L27,13) Instead of showing me the 13 leftmost characters in cell L27, it shows ''=left(L27,13)''. Any...
You can change this under the Excel, options menu. Select the advanced option and uncheck the option to "Show Formulas in cells instead of their calculated value", or you can jjst press Ctrl + `
This will either turn on or off the show formula option.
Apr 27, 2009 | Microsoft Excel for PC
How to use vlookup
you can a tutorial here.
please rate.
Feb 06, 2009 | Microsoft Excel for PC
Need Formula
TEXT CASE
Convert to UPPER, Proper or lower
Auto Convert to UPPER, Proper or lower
Stop VBA Being Case Sensitive
SELECT CASE VBA
Select Case Statement. Great alternative to Else If Statements
CONVERSION
VBA: CBool(),CByt(),CCur(),CDate(),CDbl()Double,CDec(),CInt(),CLng(),CSng(),CStr(),CVar().
Example
dDate=cDate("25-Jan-07")
Convert Numbers to Words
Convert Numbers to Dollar Amount in Words
Spreadsheet Converter. Versions: HTML/JavaScript,Excel ASP.Net and Excel Java/JSP. $
SQL Database Migration $
Converters. Database Converters, Spreadsheet Converters, Text Converters, E-mail Conversion, Document Conversion, PDF Conversion and more! $
CSV Converter $
IMPORTING
Import SQL Into Excel-SQL Tester $
Import Excel Into Access $
CONDITIONAL FORMATTING
Conditional Formatting
More Than 3 Conditional Formats
Conditional Format Fonts for greater than 3
CUSTOM FORMATS
Custom Formats
Excel see a cells format as having four Sections. These are, from left to right: Positives;Negatives;Zeros;Text.
To hide zeros cell-by-cell use a Custom Number Format like 0.00;-0.00; where 0.00 is desired format for non zeros. Note the use of -0.00 for negatives.
To hide zeros on the Workbook level go to Tools>Options>View - Zero Values.
Dec 15, 2008 | Microsoft Windows XP Home Edition
Need a formula for excel
select CONDITIONAL FORMATING in Format
select FORMULA IS , CELL VALUE = > < (condition)
after this select Format
font style , COLOR
SEE IT WILL WORK CHANGE OF COLOURS ........
Oct 10, 2008 | Microsoft Excel for PC
Forgot password to open Excel sheet
If you mean that you can open the Workbook and read the Worksheet - then all you have to do is select all and paste it to another Worksheet. This will allow for changes of formulas etc.
If you mean the whole Workbook - then I dunno.
In future, either use the same password for everything (easy to remember) or Protect the work with nothing entered into the password field (leave this blank). This last will protect the work from people who try to guess your password, but will be easy for you to remember - eg every password is left blank.
If you must use unique passwords, then keep a record of them somewhere other than on your computer.
Sorry I can't help with the "Workbook" solution - but somebody else out ther may be able to do so.
Apr 25, 2008 | Microsoft Office Professional 2007 Full...
Export tally data to excel format
Select ASCII. Give output file name Eg:d:/exp Open the file using EXcel.Select Delimite  nexxt comma finish.Export is completed
Jan 02, 2008 | Tally T2245 Matrix Printer
Excel Formula
Make sure that the cell is formatted as a number, not as text. (Right-click the cell, format cell, number, choose NUMBER.)
Dec 19, 2007 | Microsoft Excel for PC
When I enter a formula in a cell with the the insert functon device, it does not calculate itself, but shows as text
Is there by any chance a space or any other character before the equals sign? That could cause your formula to display as text.
Dec 03, 2007 | Microsoft Excel for PC
Open Questions:
See all Microsoft Excel for PC Questions
Microsoft Excel for PC Logo
147 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
