Toshiba 50HDX82 50 in. Rear Projection Television
Problem for Toshiba 50HDX82 50 in. Rear Projection Television
Color separation
By mayjnt7 on Aug 12, 2009
color separation
Comments:
Aug 12, 2009
- Thank you very much for your response. Yes that is my model #. I will call someone in my area to repair and let them know in advance what I think I need. I appreciate your answering me. I tried to vote but it isnt letting me do so. I think because you are requesting clarification. If you give a response (as someone else did with the same answer) I would be happy to give you a good vote. Thanks again.
Clarification Request
Posted by SD Tech on Aug 12, 2009
if the model number is 50hdx82 you most likely have a bad convergence Ic====this set uses two STK-392-110----both need to be replaced and the set adjusted---if you are able to do the work yourself go to Ebay and look for the stk number---best place to buy from there is Suburban Electronics--you can buy both IC's for about 12 dollars plus shipping and they also offer a kit with soldering iron, solder and both chips for about 20 dollars---if not, get a quote from local people to get this done, most of the time this kind of problem can be repaired right in your home. If this was helpful give me a vote.
Best Solution
posted on Aug 12, 2009
Very Helpful)
roety
Rank: Guru  Televisions & Videos  Expert
Rating: 90%, 189 votes
Convergence ICs may be bad, requires parts and soldering
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Toshiba 50HDX82 50 in. Rear
Questions and Unsolved Problems for Toshiba 50HDX82 50 in. Rear
Do you recommend Toshiba 50HDX82 50 in. Rear Projection Television?
Answer
Answer
hi! the remote was not working so i bought an universal one. then i've realized the problem is the... (More)
Answer
when i turn on my tv it starts with a very distorted and jumpy picture that moves left to right... (More)
Answer
I own a toshiba 50" plasma less than 3 yrs old and 2 pink lines have appeared to the left... (More)
Answer
does anyone have pics of the inside of a toshiba 50hdx82. I think i might have something hooked up... (More)
Answer
my tv is on like a demo mode it is automaticly going through the menu . the remote doesnt work or... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Projection... Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(21591) 042-9690
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
