Question about Nu Mark Numark Cdx Table Top CD Player CD Player
CD is stuck in the Numark CDX cd turntable
Hello, i was wondering if you could please help me with a technical issue im having with my Numark CDX cd turntable....it's saying "CD OUT" whenever i try to eject the cd.....then a few seconds pass by (and no cd pops out), then it says "CD IN" again.
i tried removing the 4 screws to pop out the cd drive bay, and even removed the 2 screws on top of the bay to remove the metal cover.....but i still cannot access the disc inside. can someone please help me out with this problem? i got laid off about 5 weeks ago from my job, so this is just depressing me even more :( PLEASE HELP!!!!
my email address is [email protected]
any suggestions on how to remove the disc would be appreciated... thank you in advance, rich
  • DJ Mario Mar 25, 2008
    my cd won't enter into the icdx player?
Http://www.youtube.com/watch?v=jiRzpwTnU2g&feature=related
Posted on Jun 26, 2008
  • 4 Answers
...and when you put it back together, note the little white plastic lever that sticks up from the CD transport into the lid mechanism that you removed. This needs to poke back through the hole to engage with the mechanical bits in the lid!
Posted on Mar 27, 2008
Hello, there should 4 little black screws on the top of the cd tray when it is removed from the deck. two of them are on the rear top in black plastic. the other two are holding the silver plate down as well. remove those four screws. the top should slide off. after that is off, you should be able to see how the disc is being secured. careful not to pry any thing it should all come apart. good luck.
Posted on Jan 16, 2008
SOURCE:
Whenevr i put in a cd it takes forever for the
Gracenote corrupt? Try re-installing the software.
May 05, 2010 | Numark CDX Turntable
Numark CDX doesn't recognize any discs
You need a replacement CD drive. This is a common problem with this model. Im pretty sure they sell drives for $50-80. You could try removing and reinserting. 4 screws on front Casing, slides out straight.
[email protected]
Apr 21, 2010 | Numark CDX Turntable
I have the Numark CD Dj in A Box NDX200 and I'm getting a No
Did you try multiple discs? I would say the CD drive is defective. You should still be covered under warranty. Contact Numark for service repair.
Dec 25, 2009 | Numark CDX Turntable
Motor trouble cdx
What exactly is the problem with your numark cdx cd player ?
Regards.
uk/europe repairs link... http://www.audiovisualservices.info/
Dec 11, 2008 | Numark CDX Turntable
Numark CDX Search (for fast forward and rewind) not working.
Possible switch fault or servo problem,if you havent had it repaired you can send it to us.
Regards.
Nov 15, 2008 | Nu Mark Numark Cdx Table Top CD Player CD...
Numark CDX CD Turntable
HERE YA GO!! GOOD OLD FASHIONED BEATING FIXED MINE... I PROMISE THIS. When you turn on your CDX... HIT THE SQUARE AREA where the play button and the cue buttons are located. It will jump to CDX on the screen and work fine. Mine did this and i messed around with bumping it and stuff and figured this out
Apr 25, 2008 | Nu Mark Numark Cdx Table Top CD Player CD...
CDX wont read any CDs
The CD transport (reader) is shot. These units are known for this! To date, they still havent fully corrected the problem. A band-aid fix is to buy a new transport thru numark or parts dealer.
Apr 13, 2008 | Numark CDX Turntable
Cdx doesnt read any cd.....
Numark has yet fix this issue. You will need a replacement CD drive, they swap right out. Their warehouse is located in Cumberland RI (US). Unless you could score one on ebay. I have about 3 of them, you interested?
Mar 20, 2008 | Numark CDX Turntable
Not reading any cd's
they are known for this! Does it take cd in for a few seconds and spit out? Does it take cd in and just tick? (if you put ur ear up to the drive you'll actually hear it try to spin but just give a lil tick noise). Numark does sell a replacement cd drive which isnt exactly a 100% fix but worth a shot seeing how the unit cost quite a bit. If you do end up replacing the cd drive and does not fix your problem there is also an internal cable. Once you pull out the drive, look inside to the left you'll see a white flex cable which may need to be re-seated. Let me know how you make out!
~digitalscorpion
Jan 15, 2008 | Numark CDX Turntable
Nu Mark Numark Cdx Table Top CD Player CD Player Logo
393 people viewed this question
Top Nu Mark Audio Players & Recorders Experts
da surgen
 Ian Kayhan
Ian Kayhan
Are you a Nu Mark Audio Player and Recorder Expert? Answer questions, earn points and help others
