Question about Briel ED271AP 10-Cup Multi-Pro Espresso / Coffee
Espresso stopped working
I had the machine about 2 years and it worked fine. Now when I push the button to make an espresso it makes a sound but nothing comes out. Any ideas??
Would also appreciate any suggestions on Seattle area repair shops - not much of a fix it myself kind of person. Thanks in advance.
E
  • 1 more comment
  • Anonymous Mar 21, 2008
    I have the same problem. I think the system needs to be cleaned. There may even be some grinds clogging it up. I don't have an instruction manual anymore. I looked on the Briel website and there was no manual but I was able to email customer support.
  • Jon Durham Jul 05, 2008
    My pump quit working. I have another espresso model. are the pumps the same?
  • wendyrthomse Nov 02, 2008
    I hear it girgle but it is like the pump won't bring the water up into the espresso
  • 32 Answers
Possibly you might need the Brew Head Screen and/or filter basket cleaned of built up coffee oils. Depending on how much you use it, is best to clean it every week or couple of weeks.
Remove brew head screen and filter basket, also if you have a screw in the filter basket and soak with in a cleaner for removing oils (not descaler) at: www.urnex.com or Dezcal etc.
Or, if you have not used it in awhile you might need to prime the pump manually:
Fill water tank.
Turn power on.
Open the steam knob all the way.
Press the coffee button.
Put a cup under the steam pump wand.
Wait until you see a steady flow of water and no air.
When you see the flow of water, close the steam knob.
Turn off the coffee button.
Now the machine should be ready to brew an espresso.
For further details email: [email protected] or the service center:
Electra-Craft
41 Woodbine St
Bergenfield NJ 07621
phone 201-439-1700
fax 201-439-1701
[email protected]
www.electra-craft.com
Posted on Jun 04, 2008
SOURCE:
Krups 897 stops after pushing the cup-button.
my friend i don't quit under stood but it sound like you have problems on the PCB give more info
Feb 26, 2016 | Krups Coffee Makers & Espresso Machines
We have a 4 month old gaggia titanium. Today, the steam wand stopped working. (It makes coffee just fine.) I've cleaned the steam wand. When I turn the steam dial, very little steam comes out and I hear a...
Sounds like the steam wand is getting blocked some where either at the metal end or in the parnello wand if you machine has one at the end of the steam wand, if both of those are clean then try this push in on the steam knob if that works then tap rod assemble or steam valve needs to be replaced, make sure to ask about the stainless steel valve instead of the plastic one.
Oct 06, 2010 | Gaggia Titanium Espresso Machine
Our machine stopped working; the steamer works, but no water comes through the part that makes the espresso ... does this mean the pump is broken? Our machine isn't new ... we've had it for a good number...
Hi
If you open the steam knob, push the middle button and you get a continuous stream of water, your pump is good. You probably have a bad 3 way valve, that needs to be replaced. Its behind the panel in the front. 2 screws and it slides to the right.
Oct 15, 2009 | Rancilio Silvia Espresso Machine
Saeco vienna saying brewunit blocked !
Hi There is a test mode for the Digital and we can see if you have a bad power board. Turn the machine off in back. Push and hold the small coffee button and the menu button (top left) at the same time and while you are holding the buttons turn the machine on. Release the buttons and you should have numbers in the display. If you can push the bottom left button and the machine makes a sound like the motor is moving, turn it off and then back on. If you don't get the message now you should really clean and lube your brew unit.
Jun 05, 2009 | Saeco Vienna SuperAutomatica Coffee...
Steam not working
i dont know your location, but you can check this sites mentioned above:
www.oemmeci.it
www.nuovaricambi.it
or you can check in car parts shops at your location, you should look at parts> sealings for brake pipes.... you request the sealing from rubber named VITON or SILICON.
Feb 28, 2009 | Gaggia Classic Espresso Machine
Machine does not stop after dispensing two shots of espresso
That kind of machine is pretty well engineered!Very solid and work on a basic deal.The problem could be just the simple on/off button.
The pump is controlled by the button and if the button don`t stop the machine still understanding you need more until you close the circuit.Sometimes coukld be also a loose wire.
In some way you are lucky because that machine have not electronic board so...less part.....less problem
Don`t forget to rate your experiene
Fabio
Nov 26, 2008 | Saeco VIA Venezia
Knob not working
Try crupsusa.com
They can steer you to the nearest espresso repair.
Mar 04, 2008 | Krups Palatino 905-42 Espresso Machine
Gaggia Espresso Machine bought about 10 years ago
  1. if it is fine ground coffee sometimes you get this result at machines.
  2. low pressure pump = you get water from it but only when handle is out or steam valve open.
  3. pump with non return valve broken = in this case you get water if you open tea valve during pump works. this pump can work long even she has 1 valve damaged, only when she is empty you need to open steam valve and leave pump running while you don't get water from valve.
Feb 15, 2008 | Gaggia Espresso De Luxe Espresso Machine
Kitchenaid Espresso maker no longer dispenses hot water from frother
by frother you mean it puts out steam ? if yes then I need to know how long you hold down the button and have you checked the hose in back to see if it has cracks or is kinked?
Dec 31, 2007 | KitchenAid PRO LINE KPES100PM Espresso...
Briel ED271AP 10-Cup Multi-Pro Espresso / Coffee Logo
364 people viewed this question
Top Briel Coffee Makers & Espresso Machines Experts
Marvin
Marvin
Vitally Alcher
ray gallant
ray gallant
Are you a Briel Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
