Question about Biostar M7VKD Motherboard
Need to install bios for this mobo
M7vkd ver 1.1
    Genius:
  • 1,601 Answers
Have a 2005 a1250n Hp computer with Hp ver XP SP3 OS installed. MOBO failed. Can it be replaced by same p/n 5188 1936 using current all ready loaded XP OS. Will GUID be a problem?
If you can get the exact mobo you may replace it. No driver issue will raise. You can also buy a new mobo with same chipset and replace it. Same chipset mobo will require to install Sound, ethernet and vga drivers
Apr 12, 2016 | HP Computers & Internet
ECS MCP61PM-GM
Lan card Intel Lakeport-G i945G / Intel 82801GB ICH7 I am receving audio voice
Feb 06, 2014 | Computers & Internet
MS-7297 Ver 2.1 Not booting: system fan not detected. I've bought in ebay a working msi mobo (so vendor says it works) that I can't boot because a message saying system fan not detected (bios...
you need the right heat sink for the cpu that you are using for the board check on board for cpu plug in, then plug the fan in make sure that you have enought heatsink paste on cpu not to much just enought to do the job. if that dose not do it then the board is bad.
Sep 24, 2013 | MSI Computers & Internet
Wont accept bios update that was sent from packard bell after total failure keeps asking for bios file. also clear cmos feature on board three pins one with white square which i assume is pin 1 but header...
Ga-8SIML is a generic gigabyte mobo and does not need a packard bell bios. you could goto the gigabyte site and get latest from there. If your PB displays a logo at the start then its likely that you will lose that logo as the generic bios will not know it was fitted to a PB machine but thats no hardship.
Be sure to check the board version. version 1.0 takes one type of bios ver 3.2 another and they wont load into the wrong versions of the board. F12 is the latest non beta. I just did two of these recently so i know F12 is ok.
suggest you visit gigabyte site anyway just to check how the bios should be blasted and which version supports which mobo model no..
Aug 13, 2010 | Gigabyte GA-8SIML Motherboard
I need bios ver 1
Man this is like when i first stepped into the ring to work boxes. Ok what you do is find all imfo on the product so you can download and install the firmware revision
Oct 18, 2009 | MSI PM8M-V Motherboard
Blue screen on start-up. Mobo SIS-741 Chipset SIS741GX Rev 03
This problem can be caused by several things. First, are the memory chips exactly identical (brand, type, size, etc.)? If not, that will definitely cause the problem. Second, how many memory slots are there? If you have four, check the manual and make sure you're putting the memory in the correct slots. Some Mobo's require that you put chips in slots A1 and B1 and not A1 and A2. Also, some Mobo's have DDR slots and DDR2 slots, so make sure you're putting the right kind of memory into the proper slots. Some people fudge the memory by putting 400 mhz memory into slower slots, and that works one chip at a time - but if you install a second, identical chip, the system will fail. If all else fails and you've met these conditions, check the type of memory to be sure of the proper fit (use manufacturer's recommended brands and numbers) or try a different chip in the second slot. One chip could be bad.
May 25, 2009 | SIS741GX-MN Motherboard
S-ATA Hard Disk not detect
hi Dear,
You have to update your BIOS. If you have intel mother board just go thought their website and download BIOS Flash utility of your particular Board and Update BIOS.
The above fix will surely solved your problem.I had same problem as you and it's now fixed.
May 10, 2009 | Computers & Internet
Download sound drivers
My mobo is MS-6763 ver 1.0 M-ATX, internal sound. After formatting to a new win XP pro, no sound was detected. I need to know is it the mobo itself need a driver or i have to install only the sound driver. Pls help me to find a solution.
Jul 04, 2008 | ASUS P4P800S-X Motherboard
Upgrade cpu
According to the product website your board supports all intel socket 478 cpu's. Maybe you bought a faulty cpu ?
M266A
  1. Socket 478 for Intel® P4 processor
  2. VIA® P4M266A chipset
  • FSB 533MHz
  • Supports Hyper-Threading Technology
  • Hybrid Booster - a safe overclocking feature
  • 2xDDR 266/200
  • Integrated ProSavage8 3D Graphic
Socket 478, Intel® Pentium 4 / Celeron
- FSB 533/400MHz
Jun 22, 2008 | Asrock M266A Motherboard
Biostar M7VKD Motherboard Logo
76 people viewed this question
Top Biostar Computers & Internet Experts
Jayburt
David
David
Jerry Umali
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
