Question about Plantronics DSP-400 Headset
My new headset
I just received a dsp 400 headset, but it didn't come with any software to download.... how do i get it to work on my computer?
  • aorgirl Feb 22, 2008
    This headset worked fine with Windows XP, but my PC died, and I have a new one now which is unfortunately running Vista. Now the headset won't work. Any ideas?
If you are using windows XP -- as unreal as it sounds just plug the device in and allow the Plut and Play installer to do it's thing -- it will appear as a device without a driver (in the device management list) but it will generally work. I have tried it on an HP machine and the control panel for sound and audio devices voice tab (as well as the audio tab) needs to be set to the plantronics device, too -- if you use the sound icon in the system tray the device seems to reset periodically to the one in the sound and audio control panel (just learned yesterday). The headset control on the wire -- the mute button (red illuminated button) has ceased to work for some time (possibly around the Service Pack 2 update) but the volume control does seem to work.
Posted on Dec 06, 2007
SOURCE:
I have problem in plantronics dsp 400..regarding mike..i cab hear the incoming calls but i cant hav any conversation in mike..the end user cannot hear..so kindly rectify this problem..as it would be of...
<span style="FONT-FAMILY: 'Arial','sans-serif'; COLOR: navy; FONT-SIZE: 10pt; mso-fareast-font-family: Calibri; mso-fareast-theme-font: minor-latin; mso-ansi-language: EN-US; mso-fareast-language: EN-US; mso-bidi-language: AR-SA">The first thing you need to check is your audio settings and make sure that both sound recording and playback are set to the same device. If you
Aug 19, 2010 | Plantronics DSP-400 Headset
Where can I download a driver for my plantronics dsp 500 headset for Vista?
LJBENGE try to visit this site http://www.microsoft.com/windows/compatibility/windows-vista/Search.aspx?type=Hardware&s=Plantronics%20DSP%20500%20headset and try the drivers for vista... good luck!
Jan 19, 2010 | Plantronics DSP-500 Headset
How do I replace the ear cushions for a Plantronics DSP 400? Does the ear piece detach? Can't find a manual either.
There are some small silver inserts on the side of each earpiece. You can pry them off (gently) starting under the cushion and working your way around.
You can then remove the old cushions and put in the replacements and snap these silver retainer inserts back on.
You can get replacement cushions online for about $16.
Oct 14, 2009 | Plantronics DSP-400 Headset
Do I need a driver for plantronics USB DSP v4 audio interface
Yes you would need a driver for your Platronics headset if you intend to connect it to your PC
Could you please describe the model of your plantronic headset so that i can get the required drivers for you.
Thanks.
May 21, 2009 | Plantronics DSP-400 Headset
Can't Hear Anything
Did it come with software if so did you install that?
If you have it may just be a loose wire in the headset, i would take it back and ask for a replacement.
Hope this helps,
and good luck.
Ben
Oct 15, 2007 | Plantronics DSP-400 Headset
DSP 500
I have a dsp-400 and have had the same issue intermittently on a laptop. Recently on an HP desktop computer I found setting the device in the Sounds and Audio Device Control panel Voice Tab (and possibly Audio Tab) to reduce the issues with the device ceasing to work. Setting the device from the Sound Icon in the System tray recently only a very temporary fix where the settings reverted to the Sounds and Audio Device Control panel settings in minutes. This is at best an I hope it helps solution as I do not know your specific hardware and software configuration we cannot test a solution.
Aug 25, 2007 | Plantronics DSP-500 Headset
ITunes or sound card line in with my USB Plantronics DSP-500 headset
Recently on an HP desktop computer I found setting the device in the Sounds and Audio Device Control panel Voice Tab (and possibly Audio Tab) to reduce the issues with the device ceasing to work. Setting the device from the Sound Icon in the System tray recently only a very temporary fix where the settings reverted to the Sounds and Audio Device Control panel settings in at most minutes. This is at best an I hope it helps solution as I do not know your specific hardware and software configuration we cannot test a solution.
Jan 04, 2007 | Plantronics DSP-500 Headset
Plantronics DSP-400 Headset Logo
928 people viewed this question
Top Plantronics Radio Communications Experts
Anthony Ward
Anthony Ward
gggg
edward80
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
