Question about DCS RGS-486GD Gas Kitchen Range
RG 364 6D DCS gas range
Looking for the part that carries the gas to burner, the small simmer part,
do you know where I can find the part, all calls to Fisher & Paykell are non responsive.
Bummer when you buy an expensive product and the company sells.
Call 888-281-5698.  Parts ship from California, available next day.  I've had immediate, good, intelligent response.
Posted on Nov 26, 2008
SOURCE:
Igniter switch on top burner will not shut off
try thoroughly cleaning the burners, particularly the holes in the ring that the gas come through. The gas come through to heat the ignitor so that the ignitor knows to stop trying to light the burner ; if the holes are clogged the ignitor doesn't heat.
The burner is easily disassembled from the top by removing a thin bolt, and you can clear the holes with a paper clip.
Sep 21, 2013 | DCS RGS-305 Professional Gas Kitchen Range
When this range was installed the installer removed the natural gas orifices and installed the supplied propane kit. Upon use we discovered that the lowest flame positions for all burners was still quite...
call in a gas fitter as the jets for the propane are probably incorrect.
the jets for lpg and nat gas are different in size and they may not have needed changing at all
Mar 11, 2017 | Frigidaire FGDS3065KF Stainless Steel Dual...
DCS 305 cootktop: one burner will not stop clicking + the simmer flame is not on consistently around the burner.
Hello- What is probably happening is that the simmer orifice is clogged. If this gets clogged-up and not enough gas comes out to the burner it will continue to click. This is usually pretty easy to remedy. Take off the burner cap and you will see two holes, one in the center for the main burner and a smaller one that is on the perimeter of the burner. Look down that small hole and you should see a bronze orifice, it is pretty small, about 1/8" in diameter on the outside, looks like a nut. Most likely you will see grease or charred bits on the top of it (you can use one of the other burners for a reference if you are having trouble seeing it clearly) In the center of the orifice is a tiny hole, this is the part that is likely clogged. Now, you'll need to find something really skinny, like thin sewing needle and poke it into the orifice opening. Sometimes it is necessary to hold onto the needle with needle-nosed pliers in order to get it far enough in. Just be gentle with it and if what you are using seems too large in diameter then it probably is, you don't want to dent or cause any damage to the orifice opening. Once you get it cleaned out it should work ok. Let me know if you have any questions. Best regards.
Sep 26, 2010 | DCS 36 in. CTD365N / CTD365L Gas Cooktop
DCS gas oven and broiler that pulses
This sounds a lot like a defective pressure regulator. If you do not have one externally connected, then the internal regulator is faulty. If internal, it shouldn't be too difficult to DIY. Just make sure the pressure rating is the same as the one that has failed.
Mar 24, 2010 | New World G60m Gas Single Oven
Dcs 48" gas range igniter comes back when set on low/simmer
This is not a solution but something to think about for troubleshooting.
On the DCS there are two ports that feed gas to the burner.
One for high flame and one for simmer.
On the DCS if the flame is snuffed out on simmer it will automatically reignite.
So if the igniter will not shut off while on simmer, the sensor is bad and is trying to reignite the burner.
May 11, 2009 | DCS 24-24G-1 Gas Kitchen Range
Ignitor stay on all the time after one burner is on
The simmer flame turns the ignitor off. On my range, the tube that supplies gas to the simmer flame was plugged with rubber-cement-like stuff. Cleaned it out with goof-off and a pastic-covered wire, and it works perfectly now.
Sep 08, 2008 | DCS RGS-305 Professional Gas Kitchen Range
Electric ignition
I want to know more about your business I repair restaurant commercial equiptment please respond maybe I can help
DCS Range Ignition problem
I agree with two of the reviews here. Every so often after a good cleaning, or most recently after some oil spilled over, I had a burner that wouldn't light. All of them clicked, but the one I wanted didn't light. So after reading the above posts, I unscrew the hex nut, removed the shimmer ring, and cleaned it, and mopped up a bunch of oil under where the ring sits. Put everything back together and lit it manually. After 30 secs of flame I shut it down and tried to light it automatically. It worked! Looks like, thanks to some folks here, that I saved myself an annoying phone call and possible repair bill!
Aug 18, 2008 | DCS 36 in. CTD365N / CTD365L Gas Cooktop
DCS FREE STANDING RANGE
This should be fairly easy to do. You will have to get new jets that are sized for propane. These should be readily available. The jets on the stove top are located under each burner in the top of the pipe that delivers the gas. Remove the burner and you should be looking at a small hole in the center of a brass fitting, that's the jet. It unscrews and the new jet screws in. You may also have to adjust the simmer. This adjustment is located on each burner valve. When you pull of the knob, the adjustment will most likely be in a hole on the shaft where the knob came out or as was the case with my stove, it was behind and beside the shaft, just visible with a flashlight. This adjustment is done with the flame on in low medium. You may need to hold the shaft with pliers to keep the valve from opening. Turn the screw a half turn or so until the flame simmers to your liking and is not so thready tat it wants to go out.
For the oven, this will either be an adjustable jet, or you will need to replace it with one set up for propane. Either way its a doable project.
Mar 07, 2008 | Kitchen Ranges
DCS RGS-486GD Gas Kitchen Range Logo
354 people viewed this question
Top DCS Kitchen Ranges Experts
Paul Carew
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a DCS Kitchen Range Expert? Answer questions, earn points and help others
