Question about i-mate JAM Pocket PC
Weird Bug on my Jam - Phone Indicator not functioning properly
I have a very serious problem.
By the phone indicator I mean the reception status indicator. After I wake from sleep mode it would not show any reception status at all.
I cannot use the phone, there are no incoming or outgoing calls.
A related bug that I noticed, I cannot disable flight mode properly either. after entering flight mode phone shuts off (normal) but when I wake it would not come back alive. phone indicator remains with an 'X' on it and I cannot force it to register on my network.
I doubt the network is causing this grief.
Is anyone else experience this?
So far there's only 1 ROM version available that I'm aware of. so I don't think that'll have any effects on this.
suggestions would be appreciated.
    Problem Solver:
  • 12 Answers
I definetly would try to insure you have the latest ROM and a memory manager on your Jam.
I had a problem, still do, where the blue tooth will not toggle on. I have to turn the flight mode on and off a number of times, mix in a soft reset and suddenly I'm back in business. Flight mode is easy to toggle on and off. There are deeper phone settings with regard to network access etc. Does your provider recognize the JAM--for example T-mobile does not really know the JAM though they have the MDA. There are certain network settings (cell network) that are most appropriate for the JAM>
I know this is limiting in help but it's a starting point. I would again look to a third party application as well for blue tooth connecitivty, so as not to have it interfering with the phone signal.
Posted on Dec 31, 2007
  • 56 Answers
This is a bug in the windows version either you install a new windows 2003 CE
or try to get the last windows updates from club i-mate site ,
this will fix this bug problem
and you cannot recieve any call because the flight mode disable the phone so u can't register your phone on the network
Posted on Dec 11, 2007
SOURCE:
Tip
Printer error (orange or blinking light)
<b>Printererror (orange or blinking light)</b> After your printer has completed its initial startup you shouldhave a solid green light. If the light indicator is blinking or orange oftenthis is an indication of a printer error. For example, this could indicate a paperjam, issue with the ink or toner cartridge, or other serious error. Because there is no standard to what a blinking light or orangelight means if you're getting either of these we suggest referring to theprinter documentation for troubleshooting steps or methods of determining whatthe status indicator is reporting.
on Mar 31, 2011 | Office Equipment & Supplies
Hp deskjet d1560 printer light flashing
After your printer has completed its initial startup you should have a solid green light. If the light indicator is blinking or orange often this is an indication of a printer error. For example, this could indicate a paper jam, issue with the ink or toner cartridge, or other serious error.
Because there is no standard to what a blinking light or orange light means if you're getting either of these we suggest referring to the printer documentation for troubleshooting steps or methods of determining what the status indicator is reporting.
http://h10025.www1.hp.com/ewfrf/wc/searchResults?tmp_product=HP+Deskjet+D1560+Printer&product=3374275&tmp_qt=power+light+flashing&lc=en&dlc=en&cc=us
Aug 06, 2010 | HP D1560 Deskjet Printer InkJet
What does the status light mean,it's green
When it's green that just means that you're phone has service. When it blinks red that means you have a text message, virgin alert, missed call, or sometimes a voicemail message. You can turn of the status indicator light by going to Menu > Settings > Display > Status Light and select "Off".
May 10, 2010 | LG Flare Cellular Phone
Red light stays on after changing the water filter and running about 2 gallons through it
Water Filter Status Indicator
Light (select models)
The Water Filter Status Indicator Light serves as a
reminder to replace the water filter. A green light
indicates that the filter is in good condition. A red light
indicates the filter should be changed. Once light turns
red, it will remain red until function is reset.
To Reset Indicator:
• Press and hold both the Lock and Water
buttons simultaneously for four seconds. The
green filter status indicator light will flash
three times when the function has
successfully reset.
Nov 27, 2009 | Maytag MZD2665HE Side by Side Refrigerator
Change filter light
To Reset Indicator:
successfully reset.
Sea Breeze
Nov 25, 2009 | Maytag MSD2650H Side by Side Refrigerator
Changing light after installing new water filter
(select models)
To Reset Indicator:
• Press and hold both the LOCK and WATER
successfully reset.
Aug 12, 2009 | Jenn-Air 21.6 cu. ft. Side-By-Side...
Logitech Setpoint Caps Lock indicator won't work
Hi, I suggest you to update to the last version of set point version 6.00 Yes logitech is listening that's why they released 3 set point version since the 4.72 that you are running. www.logitech.com/download Thanks and have a nice day ! J-
Aug 01, 2009 | Logitech Cordless Desktop EX110
Power indicatoror
From the manual:
"Attach the barrel tip of the AC Charging Adapter to the AC Charging port of the POWER TO GO® and plug the standard two-prong plug into an appropriate, functioning 120 volt AC outlet. The red Battery Status LED indicator will flash, indicating a proper connection has been made and the unit is charging. The green Battery Status LED indicators will gradually light as the charge level rises. The POWER TO GO® must be charged for approximately 11-17 hours prior to first use. All Battery Status LED indicators will be lit solid (the red indicator will stop flashing) when the unit is fully charged.
Aug 29, 2008 | Black & Decker Power To Go Cordless AC/USB...
Reception / signal keeps cutting in and out
there is a bug with the i-mate jam bluetooth , it may cuase this  when this happend try to enable and then disable the bluetooth,
if it works agian there is a file fix this bug in the bluetooth from club i-mate site try to download it
Dec 10, 2007 | i-mate JAM Pocket PC
i-mate JAM Pocket PC Logo
115 people viewed this question
Top i-mate Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you an i-mate Computer and Internet Expert? Answer questions, earn points and help others
