does not want to ignite even if you turn thermo up 90, blower will not turn on auto from thermostat an thermostat is new. However it does turn on at the furnace.
It sounds like the thermostat was installed incorrectly..... There is an industry standard color coding of wires, but unfortunatly this is not always followed. The format is Rh and Rc are a red wire (these terminals may be jumped together if you have gas heat), which is 24v hot, W is a white wire, which is 24v common, Y is a yellow wire, which is power to the outdoor A/C unit, and G is green, which turns on the high speed fan. I must assume that your old thermostat would turn the fan on, since you mentioned it above. Your best bet is to check at the furnace to see which wires go to where
Please Note that if you have oil heat the jumper between Rh and Rc should be removed. Rh is power for the heating circuit (usually red), and is connected to the oil burner primary control. Rc is power for the cooling circuit (usually blue) and is connected to the fan relay. I hope this helps
"replace better" msg light came on; I replaced with 3 AAA Alkalines...3 days later, same...
(More)
"replace better" msg light came on; I replaced with 3 AAA Alkalines...3 days later, same message- replaced AAAs again, with what are absolutley fresh ones, same msg. Is there a backup batter somewhere on this unit that needs replaced? The manual does not indicate or show or mention a backup battery...stumped, 'HEP! thx, ed zeppelin the temperature guy
Mod#BLU100K948A The 2 selenoids on top of gas valve click when they open (normal). Sometimes they...
(More)
Mod#BLU100K948A The 2 selenoids on top of gas valve click when they open (normal). Sometimes they work fine, sometimes they have a rapid clicking noise and do not open the gas valves. Furnace just runs and blows cold air. How do I find what causes these valves not to open.
