Question about Philips 42FD9954 42 in. Plasma HDTV
Phillips hdtv 42PF7220A/37
No signal When I turn it on green light last for about 10 sec. then red light comes out and a little noise inside
  • unfixer Dec 27, 2007
    I have the same problem. Can you tell me where the power supply is located or what it looks like? Thanks Kevin
  • 934 Answers
Most of the reported symptoms like these are power supply related and not usually an expensive repair.. If you're doing this yourself take a look at the power supply board - you'll have to remove it - check the cap at 2662 for any signs of buldging. If you have an ESR meter measure it's equivilent series resistance and replace if necessary. Next look closely at the board for ring cracks of the various solder joints. Pay close attention to the diodes at 6041 and 6046. part of the bridge system. Any ring cracks found flow some solder across them to make good contact then re-install the power supple and try to power the unit.
Bill
Posted on Nov 29, 2007
  • Jeramie
    Jeramie Feb 08, 2011
    you must be referring to a different board premtech. All my diodes and caps are numbered above 8000 on my power supply for the same tv.
SOURCE:
Toshiba regaza 37rv635db wont turn on
seems like capacitor problem, chack them and if thay have exploded replace them.
Aug 25, 2013 | Toshiba 37RV635DB Regza 37-inch Widescreen...
I have a 37" Phillips LCD TV. it will not turn on and the light that used to show green (to signal the tv on) now blinks red. What does that mean?
how many times does it blink red. the will help determine whats wrong. Most lightly its going to give you 6 or 7 blinks whick points to the power supply this is sometimes a false indication to the ssb/signal board being bad. you coulb try the parts or have a tech come out and verify which is the problem.
Apr 27, 2010 | Philips 37PF7320A 37 in. HD-Ready LCD...
Vertical Line on Phillips 42PF7320A/37
Hold down the cursor button towards the green line, it's really that easy...
Mar 07, 2010 | Philips 42PF7220A 42 in. Plasma Television
Red lines on plasma screen.
you may want to check out your buffers.
for cheap buffers check out hssparts.com
thank you
Dec 11, 2009 | Philips 42PF7220A 42 in. Plasma Television
42PF7220A/37 Blinking red led (7 times)
sounds like your tv in shut down mode why lamp needs 2 be replaced nominal cost 120 200$
Jul 25, 2009 | Philips 42PF7220A 42 in. Plasma Television
I have a phillips 42pf7220a/37 and 7 blink led
The Ymain Board is out if you have the back of the tv exposed disconnect the ymain board and then plug in the tv set and turn it on. the light should remain green and no longer flash. If this happens the Y main and upper and lower buffer boards should be replaced
Jun 15, 2009 | Philips Televison & Video
Phillips hdtv model 30pw9110d/37 won't turn on
Common short the cover cap over the video & sound boards short out if you remove it the cap only (shield metal) it usually will fix this
Apr 28, 2009 | Mitsubishi WT-46805 46" Rear Projection...
Phillips Plasma - Model #42PF7320A/37 - 3 flashing red lights
it sounds like you could have a signal board problem they are pretty expensive but there is a web site that sells refurbed parts
Nov 17, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Philips 42PF7320A blinks 3 times every time i hit the power button
The SSB is small self contained board that u connect your Antenna, and HDMI to. An error three is a communication error between the SSB and to Logic board ( located underneath the SSB on the back fo the plasma panel that is just below the power supply. U can check parts.com and see if u want to purchase a SSB for this TV. Is the 3blinking lights coming from the front of the TV. Also check the power supply and see how many times the green led blinks on the upper left of the power supply and let me know.
Apr 24, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Philips 42FD9954 42 in. Plasma HDTV Logo
135 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
