Check the following:
Is the freezer door closed completely?
Is the ice
storage bin installed correctly?
Is there ice in the storage bin?
Has the ice frozen in the storage bin?
Is ice stuck in the delivery chute?
Has the wrong ice been added to the storage bin? Use only
cubes produced by the current ice maker.
Has the ice melted around the auger (metal spiral) in the
ice bucket? Dump the ice cubes and clean the ice storage
bin.
Is the ice dispenser stalling while dispensing “crushed”
ice? Change the ice button from “crushed” to “cubed.” If
cubed ice dispenses correctly, depress the button for
“crushed” ice and begin dispensing again.
Has the dispenser arm been held in too long? Ice will stop
dispensing when the arm is held in too long. Wait 3 minutes
for dispenser motor to reset before using again.
I can hear a faint click when I push the crushed,but the forks on the auger motor do not move. The same thing occurs when I push the cube button. All the other button functions work.
Yes, I figured out that I had to close the door. Thanks
Are you closing the door when testing , or holding in the light switch when testing ? Door open and pushing dispensor will not do anything .
Do you get any noise when set for CRUSHED and press dispensor ? Remove the ice bucket , and press crushed , to see if the forks on the auger motor move . This and a little more information to fix .
