If your computer is running kind of sluggish, you can fix it with an easy clean up of your registry. Here's a link to a free scan that works well: www.your-free-info.com/RegCure
I've used this one and it sped up my computer by quite a bit. Hopefully this helps.
Was this solution helpful? Show your Appreciation by rating it:
Show your appreciation by commenting on Tech com driver:
Solution #2
posted on May 04, 2008
Guest
Rank: Apprentice Rating: 0%, 0 votes
A good registry scanner can clean up a lot of problems with your computer. Here's a link to a good free one: www.your-free-info.com/RegCure
Solution #3
posted on Apr 29, 2008
Guest
I fixed this same problem using a registry scanner. Here's a link to a good free one: www.your-free-infor.com/RegCure
I've used this one and it sped up my computer by quite a bit. Hope this helps.
Solution #4
posted on Apr 27, 2008
Guest
Try right clicking to the My Computer icon on your desktop. scroll down
to properties, and then select the hardware tab. The choose device
manager and scroll down until you see the webcam and then choose to
update the driver. If there is a more current one out there then the
updating will generally find it for u.
