Question about HP Photosmart C3180 All-In-One InkJet Printer
Knowledge Base articles lose the ends of lines when printed.
Both Knowledge Base articles and many web pages when printed do not finish the line.How can one correct this?
  • minkiebabe Dec 03, 2007
    The only way I have found to fix the problem is to print in landscape instead of portrait
  • a67994 May 11, 2010
    Are you using Internet Explorer or Mozilla Firefox?
A67994 I'm using I.E.6 (Internet Explorer)
The correction was given by an H.P. workaround program which corrected the effect in Print Preview and in 2 printers.
Mario133
Posted on Mar 12, 2008
SOURCE:
Where can I get an engine vacuum line routing diagram for 2001 JEEP CHEROKEE 4.7?
in uSA/?
open hood, look up, and under, see that vacuum map.
or read the FSM
all that is covered in the huge book,, just read it.
did the lines fall off? what is the reason to ask? JOB at hand.?
there is very little engine vacuum lines.
there is brake, cruise, HVAC, too.
a vacuum reservoir
the emission page covers most. EVAP, is one.
and fuel. (FPR reg uses vacuum)
would be nice if you named one hose loose.
not ask for them all.... but you can read the book , like all can.
MAP sensor does not use lines
if one hose lose. tell where it goes,?????????
WJ
http://www.morris4x4center.com/knowledge-base/index.htm?utm_source=cj#service
Dec 17, 2015 | 2001 Jeep Cherokee
When printed document is sent to printer, it prints with dark lines below each line of print often obscuring every other line of print .
  1. When connected by a USB cable, reseat both ends of the cable going from the computer to the printer.
  2. When connected to a wired or wireless network, make sure the network is working correctly and that the printer is connected to the network.
  3. (to make sure the printer is on the network, print a network set up page, for more information on how refer to the user's guide, refer to the Downloading and Viewing Printer Manuals section for information on how to download and view the user's guide).
  4. Restart the computer.
  5. Turn the printer off.
  6. Unplug the printer power cord from the A/C outlet or surge protector and wait at least 30 seconds.
  7. Plug the printer power cord back into the A/C outlet or surge protector.
  8. Turn the printer back on.
  9. Make sure the desired printer is set as the default printer.
    • For instructions on how to check which printer is set as the default and change it if needed, Click Hereextlink.gif
  10. Print a test page.
    • For instructions on how to print a test page from Windows, Click Hereextlink.gif
  11. Run the automated printer fix available from Microsoft.
    • For instructions on how to run the automated printer fix available from Microsoft,
      Click Here
  12. Uninstall the printer driver, download and install the latest printer driver.
Nov 08, 2010 | Dell 948 All-In-One InkJet Printer
Need manual
The manual is available from the Stanley Tools web site. http://www.stanleytools.com/default.asp?TYPE=STATICLEFT&PAGE=knowledgebase.htm&LEFT=left_knowledgebase.htm . Click on the Search the Knowledge Base button and put in 77260 in the search box in the pop up window. Then click on the link for the line for 77-260 IntelliLaser Pro Instructions. Then click on the icon for the format (PDF) of the manual at the end of the listing.
I hope this helps.
Oct 12, 2010 | Stanley 77260 IntelliLaser Pro Combination...
Test page prints every time I turn printer on
Maxkath,
Rather than retype something that has already been typed, I've copied the link to the knowledge base article below.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01336397&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
~Dave
Nov 18, 2009 | HP Photosmart C3180 All-In-One InkJet...
Prints test page every time I print
Maxkath,
I see that you have several posts for the same issue. Again, rather than retype something that has already been typed, I've copied the link to the knowledge base2.gif article below.
~Dave
I am unabale to use smart web printing with IE8. I have a C4480 multifunction printer
In answer to your question, yes, there is no harm in leaving Add-ons disabled, however, some website features like Flash applets will not automatically start. Let’s try uninstalling IE8 and rolling back to IE7 to see if this resolves the print problem or to determine if there is something else going on. Here is a link the link to a Microsoft Knowledge Base article that has the steps to uninstall IE8 and return to IE7:
http://support.microsoft.com/kb/957700
Once you are back to IE7 try and print from IE and some of your other apps. If you can print from IE7 then we will know that there is something definitely within your IE8 installation we need to troubleshoot. If you are STILL unable to print web pages we will know there is something else going on. Lets us know what you find out.
Aug 11, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
I got sharp printer which is not printing PDF papers. could you please helpout.. please..
If you're trying to print out PDF's directly off a web site, this could be your problem. There's coding anomalies between web pages and imbedded PDF's that can cause some printers to lock up, show error codes or simply not print the screen out. You may want to avoid these web page PDF's as to my knowledge there's presently no solution to directly print these out.
Also, if the document is first in line in your print queue it can block any other documents from printing, so you'll need to delete the PDF from the queue.
Apr 06, 2009 | Sharp AR-M205 Copier
Scanner leaves three vertical lines on scanned page
A dirty glass base can cause ‘spots’ or blemishes to appear on your final printout. Additionally, if you had some sort of opaque liquid that may have transferred on to the glass base from a previous operation. But the majority of the unwanted vertical lines are generally caused by either a dirty or damaged print roller or faulty LEDs in the Scanner Module.
To separate one from the other you have to check the following:
Do you only see the lines with a Scan operation?
Do your print jobs print fine without any unwanted lines?
If you only see the unwanted lines during a Scan operation, then most likely you have a fault/dirty/obstructed LED module.
If you see the unwanted lines with all print operations (Scan, Print and Copy), then you most likely have a worn out, damaged or dirty Print Roller.
Hope this helps…
RojoSho
Sep 29, 2008 | Brother MFC-7820N Laser Printer
Stop Error: c0000221
This issue may occur if any of the following conditions exist: • A damaged file exists in the folder in which Windows is installed, and this file is not overwritten during Setup. For example, if you receive the error message that references the User32.dll file, the User32.dll file may be damaged. • One or more of the random access memory (RAM) modules that are installed in your computer is faulty, or the RAM configuration is incompatible
RESOLUTION loadTOCNode(1, 'resolution'); To resolve this behavior, use one of the following methods. Method 1: Extract a New Copy of the User32.dll File from the Windows XP CD loadTOCNode(2, 'resolution'); Extract a new copy of the User32.dll file from the Windows XP CD to the drive:\Windows\System32 folder on your hard disk, where drive is the drive on which Windows is installed: 1. Insert a Microsoft Windows Millennium Edition (Me) or Microsoft Windows 98 Startup disk into your computer, and then restart the computer.
NOTE: For additional information about what to do if you do not have a Windows Millennium Edition or Windows 98 Startup disk, click the following article numbers to view the articles in the Microsoft Knowledge Base: 186300 (http://support.microsoft.com/kb/186300/EN-US/) How to Create a Windows 98 Startup Disk from MS-DOS 267287 (http://support.microsoft.com/kb/267287/EN-US/) How to Create a Startup Disk in Windows Me 2. When the Windows Startup menu appears, use the ARROW keys to select Start Computer with CD-ROM Support, and then press ENTER. 3. Make a note of the drive letter of your CD-ROM drive. 4. Rename the User32.dll file to User32.old. To do so, type the following lines at the command prompt, pressing ENTER after each line, where Drive is the drive on which Windows is installed: Drive:
cd windows\system32
ren user32.dll user32.old 5. Insert the Windows XP CD into your CD-ROM or DVD-ROM drive. 6. Extract a new copy of the User32.dll file from the Windows XP CD to the Windows\System32 folder on your hard disk. To do so, type the following lines at a command prompt, pressing ENTER after each line, where CDROMDrive is the drive letter of the CD-ROM or DVD-ROM drive that contains the Windows XP CD-ROM, and Drive is the drive on which Windows is installed: a:
extract CDROMDrive:\i386\user32.dl_ Drive:\windows\system32\user32.dllFor example, if your CD-ROM is drive E and Windows is installed on drive C, type extract e:\i386\user32.dl_ c:\windows\system32\user32.dll, and then press ENTER. 7. Remove the Windows 98 or Windows Millennium Edition startup disk from your computer, and then restart the computer.
Method 2: Remove or Replace the Faulty RAM loadTOCNode(2, 'resolution'); Remove the memory modules that are installed in your computer, leaving enough RAM for the computer to start and run Windows. Restart the computer, and then run Setup again.
For additional information about Windows XP RAM requirements, click the following article number to view the article in the Microsoft Knowledge Base: 314865 (http://support.microsoft.com/kb/314865/EN-US/) System Requirements for Windows XP Operating Systems If the issue is not resolved, remove a different memory module. To identify the specific memory module that is not working correctly, you may have to restart your computer more than one time.
For information about how to add and remove RAM to the computer, contact the manufacturer of the computer, or view the documentation that is included with your computer.
Method 3: Install Windows to a Different Folder loadTOCNode(2, 'resolution'); NOTE: Before you install Windows to a different folder, first try the troubleshooting procedures in the following article in the Microsoft Knowledge Base: 310064 (http://support.microsoft.com/kb/310064/EN-US/) HOW TO: Troubleshoot Windows XP Setup Problems During Installation When You Upgrade from Windows 98 or Windows Me If the issue is not resolved by using the troubleshooting procedures in 310064, install Windows to a different folder. For more information about how to do this, see the "Installing to a New Folder" section of the following article in the Microsoft Knowledge Base: 316941 (http://support.microsoft.com/kb/316941/EN-US/) HOW TO: Install Windows XP MORE INFORMATION loadTOCNode(1, 'moreinformation'); For additional information about how to troubleshoot "STOP: C0000221 error messages", click the article number below to view the article in the Microsoft Knowledge Base: 314474 (http://support.microsoft.com/kb/314474/EN-US/) "STOP: C0000221 Unknown Hard Error" or "STOP: C0000221 STATUS_IMAGE_ CHECKSUM_MISMATCH" Error Message Occurs For additional information about upgrading to Windows XP, click the article number below to view the article in the Microsoft Knowledge Base: 316639 (http://support.microsoft.com/kb/316639/EN-US/) HOW TO: Prepare to Upgrade Windows 98 or Windows Millennium Edition to Windows XP For additional information about how to troubleshoot startup problems in Windows XP, click the article number below to view the article in the Microsoft Knowledge Base: 308041 (http://support.microsoft.com/kb/308041/EN-US/) Resources for Troubleshooting Startup Problems in Windows XP For additional information about Windows XP Setup, click the article numbers below to view the articles in the Microsoft Knowledge Base: 306824 (http://support.microsoft.com/kb/306824/EN-US/) Release Notes for Windows XP Setup Contained in the Home.txt File 286463 (http://support.microsoft.com/kb/286463/EN-US/) Release Notes for Windows XP Setup Contained in the Pro.txt File 286647 (http://support.microsoft.com/kb/286647/EN-US/) Windows XP Read1st.txt File Contents For information about how to contact your hardware manufacturer, click the appropriate article number in the following list to view the article in the Microsoft Knowledge Base: 65416 (http://support.microsoft.com/kb/65416/EN-US/) Hardware and Software Third-Party Vendor Contact List, A-K
60781 (http://support.microsoft.com/kb/60781/EN-US/) Hardware and Software Third-Party Vendor Contact List, L-P
60782 (http://support.microsoft.com/kb/60782/EN-US/) Hardware and Software Third-Party Vendor Contact List, Q-ZMicrosoft provides third-party contact information to help you find technical support. This contact information may change without notice. Microsoft does not guarantee the accuracy of this third-party contact information. Let me know if u got help and rate me as fixya please!!!
Mar 30, 2008 | Compaq Evo N1000C Notebook
HP Photosmart C3180 All-In-One InkJet Printer Logo
69 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
