Cd rom door won't open, and it won't play
I recently put together a custom build system
I have a
Asus mobo P5K3 Deluxe
2 Sata Opticals
2 Sata HDD
I IDE HDD
At first DVD drives were working fine. Then I upgraded to Service Pack 2 and after that the drives stopped working. I bought two new drives and they wouldn't work either. Right now I have 2 Sata DVD drives that the BIOS sees it, Windows XP Pro sees it. I have uninstalled the drives and windows re installs them fine. You see them in My computer. But when you try to open them they wont open and you can't get them to play. Any suggestions?
    Sergeant:
    Champion:
  • 298 Answers
Reisntall system without service pack 2
Reintall devices not working.
Or uninstall drives reinstall sp2
then reinstall drives
Personally I would leave sp2 uninstalled
but if it is installed prior to the drives it
might recognize them (microsoft likes to be 1st)
Posted on Nov 29, 2007
Hi from Portugal. I have got a mobo a8n-sli SE and im having trouble connecting my new wd 64mb 1gb green sata HD. I already have got 2 working hd´s, one IDE 128gb and one Sata 320gb and now i...
ur mother bios should support 1TB HDD, only then it ll get detected... u can update the bios of your motherboard with latest bios that is available for ur board in ASus support site...if you update the bios your hdd may get detected...
Sep 30, 2010 | ASUS A8N-SLI Motherboard
Asus P5KPL SE & Sata, Bios "Not Detected Problem"..
The Asus bios won't show SATA devices.
However if you are using Windows XP with Service Pack 2 (or newer operating system then the devices should be detected. If this is not happening then enter the bios -- Storage Configuration -- Configuration Enhanced and set the IDE devices to compatible. This allows all drives to be "seen" and you should then be able to load an OS.
Jan 22, 2010 | ASUS Computers & Internet
IDE Ports not working on ASUS P5LD2-VM Mobo
Good Day sir, hi, Have you tried to enable the IDE on BIOS setup. If the Bios setup did not solve the IDE problem, check the IDE port of the HARD drive, check if there are bent pins.
If still wont work, you can buy a PCI to IDE/SATA card, this is an expansion card in PCI format with IDE and SATA port.We use this card incase the IDE or SATA on the motherboard gets bad. Connect it on the available PCI slot. Then connect the IDE cable of the Hard disk to this card. Thats it.
Nov 10, 2009 | ASUS P5LD2-VM Motherboard
SOYO KT600 Dragon Plus mobo not recognize WD Caviar SATA 1TB HDD
Yuck! Soyo filed for bankruptcy in May and their website is gone!
You need to enable the SATA in the rom bios AND install the drivers for it; but, I hope you have the manual and the CD.
Jul 05, 2009 | Soyo Computers & Internet
Ecs 6100sm-m mobo connections
you have a few options
1) buy a sata harddrive (faster then ide), use the ide for the second harddrive (backup) and cd/dvd rom
2) buy a sata cd/dvd rom use the ide on both harddrives (1 set to slave)
3) depends on your budget, buy a sata drive + sata cd/dvd rom so your main drive is on sata (faster than ide) then you only have your second drive as your backup drive on ide.
i had the same problem when i rebuilt mine, i went for the seperate harddrive and cd/dvd rom and my 320 gb ide as my backup drive
sorry to jump on this post aswell, see what others think
Mar 16, 2009 | EliteGroup ECS GeForce6100SM-M (1.0)...
Mobo only one ide connection socket for HDD & CD-Rom
yes you can add both your HDD and CD-ROM Drive with the same IDE, get a IDE data interface cable (BUS) atleast three connection point. Add 1 to mobo, second to HDD and top 1 one to CD-ROM drive. Just connect and dun wrry m sure it will work....so............:))
If any problem just Ask me
Thanks
Iqbal
Apr 07, 2008 | Computers & Internet
Sata hard disk drive on asus p4v8x-x motherboard
i think you should install via raid tool from asus driver cd then check in control panel --> administrative tools--> computer management and you click to disk management
the sata hd will dectected by the computer so you can format it
you must reboot first after via raid tool instalation
i manage this way and succeed on my 500 gb sata drive
try it
Jan 28, 2008 | ASUS P4V8X-X Motherboard
SATA Drivers for Hitachi HDD
Is there a BIOS setting to temporarily put the SATA controller into legacy mode? XP would then think it's an IDE drive. Then, after installing XP, install the drivers from the motherboard CD, then go back into the BIOS and turn off legacy mode.
Jan 13, 2008 | Computers & Internet
Problems Installing my 160 GB Seagate SATA HDD
Check the SATA/RAID controller setting. It could have been set to [Disabled] Refer to your user?s manual for a detailed description on how to enable the onboard SATA/RAID controller by adjusting the jumper or BIOS settings. Regards SparkGap
Sep 24, 2007 | ASUS P5RD1-VM Motherboard
Not posting
Maybe a silly question to ask; but did you connect the processor power lead, as unlike some processors this needs a seperate supply.
Dec 18, 2006 | Mach Speed MK8-939A (VIPERMK8939A)...
Computers & Internet Logo
145 people viewed this question
Alun Cox
David Payne
David Payne
