Question about Panasonic PTAE500 Multimedia Projector
Blue spots on screen
Hi, have a panasonic projector PT AE 500E it has a lot of blue spots which are on the screen, I thought they might have been dust spot on the lens, I have cleaned everthing I can get at but nothing has worked, the lamp has just over 900 hours on it.
  • dingoblack Nov 29, 2007
    any thoughts
  • rick2778141 Dec 06, 2008
    I have the same problem. Tried taking it apart and cleaning everything I could and using compressed air to blow things out. Still have the problem though.
Obviously this is not the first lamp you have replaced in you projector. These are great projectors however, the LCD panels expire quite quickly. You will find that the spots are related to the LCD panels needing to be replaced. This is not an inexpensive maintainence solution as the panels cost about $1500 each.
Posted on Jan 25, 2008
Take out the air filter, get a can of compressed air and blow out the entire inside w/ the air. Do not tip can. Spray all openings w/ the air. It will work again
Posted on Dec 27, 2007
Panasonic projector TV PT-43LC14 has a light yellow splotch on the left hand of the screen. Can this be fixed?
yes and no. it is a burn spot on the light filter on the blue lcd panel due to excessive dust and heat. panasonic does not sell individual parts of the optical engine, so you'll have to replace the entire engine. to avoid it happening again or getting worse, keep the projector cool and dust free. use canned air to blow it out.
Nov 30, 2009 | Panasonic PT-AX200 LCD Projector
I have a yellow spot in the middle of my screen. How do i get rid of it or do I need to replace the bulb.
neither. the light filter on the blue lcd panel is fried due to excessive dust and heat. you may need to replace the entire optical engine if you cannot get the individual part.
Nov 12, 2009 | Panasonic PT-AE700U Multimedia Projector
I have a panasonic pt l500u, just started getting large yellow spot in middle of screen- looks like a giant finger print. Bulb was replaced less than two months ago.
The problem here is the one of the miniature LCD screens in the unit is faulty, in this case its the blue one. There are three of them inside the unit RED<GRN<BLUE. The blue seems to be failing in your unit, for instance if you mix red and green you get yellow. Have a local shop service the unit and clean and refocus the unit back to factory spec's..
Nov 04, 2009 | Panasonic PT-AX200U Projector
Permanent blue hue down one side of screen PT ae700 panasonic replaced lamp made no differance tried compressed air no change please help
if the discoloration has a sharp pixelated edge, it may be the lcd panel. if the edge blends, it's the light filter (polarizer) that is burnt from excessive heat and dust. either one needs replacing.
Sep 09, 2009 | Panasonic PT-AE700U-EC HD Cinema Front...
PT-L735 U projectors. Green screen and stretched
The green is the result of the blue device failing. Happens about 4000 hours or so. LCDs can't handle the heat. Check the scaling of the image of the second projector. 16x9 vs 4x3.
good luck
Jun 25, 2009 | Panasonic PT L735U Multimedia Projector
Panasonic PT-L701e - colour fault, blacks are blue with lines
Can you connect a computer (vga) signal to this projector? I'd like to know what your "white" computer screen does on the projector....example, Excel spreadsheet....
I am leaning towards these problems, a bad video card...or worse delamination of one of your LCD panels and possible polarizer burn in the optical engine.
Best Regards,
Dec 11, 2008 | Panasonic ET-LA702 Projector Lamp for...
Colored spots on dlp tv screen
coloue spots on screen. how do you fix with screwdriver?
Jul 22, 2008 | Panasonic PT-52LCX65 44" HDTV
Yellow middle, Blue Exterior
Hi Druaga
This is a Blue LCD Polarizer that will have to be replaced if the spot shows yellow.
You will find that this will only get worse as time goes by.
May 28, 2008 | Panasonic PT-AE700U Multimedia Projector
Panasonic PTAE500 Multimedia Projector Logo
1,375 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
