Just bought bose companion 5 speakers for computer. the volume control pod won't work. the speakers work and I can turn the pod off and one but the voulme wheel will not work. any ideas?
Check if the volume control needs to be replaced. volume controls gets bad in due time coz of the carbon layer which gets thinner and thinner till it gets cut off
? 3:18
www.youtube.com/watch?v=gXRJ5Zgq84UNov 15, 2014 - Uploaded by Guizmaille
(You can tell it's the control pod and not the sound system itself.... I tried different combination) until I have a decent sound, with both speakers and subwoofer working. ... I think that you can manage to keep the volume control.
check your wiring connections, sounds like you may have intermittent connection somewhere, and this is the most likely culprit. be certain that all connections are solid. multi pin plugs are notorious for having one bad pin.
I had exact same problem today. I moved my speakers from one room to the next. When I plugged everything back, the mute/unmute worked but the volume control no longer worked.
I got it working now!! I powered down my computer and then unplugged the power to the speaker system. Then plugged in the power to the speaker system again. Powered on computer and all is good again!!
I had the same problem right out of the gate, the volume dial on my control pod for my Companion 5 wasn't working, however, the touch pad and LED worked. I called Bose customer service and was instructed to:
First, unplug the power directly at the back of the woofer while the unit was on;
Next, I was instructed to unplug the control pod, visually inspect for any damage/defect;
Finally, re-seat the control pod on the back of the woofer and then lastly plug the power cable back into the woofer.
