FixYa.com
Tags:
Emerson VR4450 VHS VCR
VCR PROBLEM(Emersonvr4450)
By Cato - usenet poster
The problem on this Emerson VR4450 is that after the tape loads and the tape goes
around the head successfully and the deck is waiting for a command, push play/reverse/ff
the deck will put the tape in the correct motion for 5 seconds and then the unit will shut down.
All belts are fine and idler assy. looks to be working.
All suguestions are welcome:
Thank You All For Your Time.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 09, 2005
Not Rated (0)
kioner
kioner - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Greetings!
This certainly sounds like a faulty motion sensor under the the take-up reel disk.
The Emerson model you are working on is not familiar to me and I don't have the exact
service manual.  You can probably get the part # from Emerson or Citronix/Panson.
Stan Cramer
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
Luisa_K
Luisa_K - usenet poster
Rating: 0%, 0 votes
Reel sensors.  Does the count increment during the 5 seconds? See the FAQ.
--- sam
In article <565lnj$ @mtinsc01-mgt.ops.worldnet.att­.net> william.rothanb @worldnet.att.net (Bill Rothanburg) writes:
   Big,
      Well, when you get yours working, I have another one here with a similar
   problem.
   Bill
   In message <561inm$ @crow.cybercomm.net> - s @crow.cybercomm.net (Big
   Daddy)Sat, 09 Nov 96 14:11:44 GMT writes:
   :>The problem on this Emerson VR4450 is that after the tape loads and the tape goes
   :>around the head successfully and the deck is waiting for a command, push play/reverse/ff
   :>the deck will put the tape in the correct motion for 5 seconds and then the unit will shut down.
   :>All belts are fine and idler assy. looks to be working.
   :>All suguestions are welcome:
   :>Thank You All For Your Time.
Solution #3
Not Rated (0)
Cornish
Cornish - usenet poster
Rating: 0%, 0 votes
On many (most?) VCRs, the reel rotation sensor is active even with no tape
inside.  Turning the takeup reel with your fingers should result in the tape
counter changing.  (May advance or decline depending on which mode the micro-
brain thinks the VCR is in.)
--- sam
   Big Daddy wrote:
   > The problem on this Emerson VR4450 is that after the tape loads and the tape goes
   > around the head successfully and the deck is waiting for a command, push play/reverse/ff
   > the deck will put the tape in the correct motion for 5 seconds and then the unit will shut down.
   > All belts are fine and idler assy. looks to be working.
   > All suguestions are welcome:
   > Thank You All For Your Time.
   Greetings!
   Stan Cramer
Solution #4
Not Rated (0)
maartenw
maartenw - usenet poster
Rating: 0%, 0 votes
Big,
problem.
Bill
Can you Help with these VCRs problems?
VCRs
VCRs
Hello, I need to buy a new VCR.... Answer This...
VCRs
timer recording, more than 1...
I have a Sylvania 6260VF VCR. I... Answer This...
VCRs
I don't know how to set the...
I was unable to set video to... Answer This...
VCRs
no reception from vcr
when I plug the cable wire into... Answer This...
VCRs
When I only want to set the...
I select from the menu the... Answer This...
Repair Service
Find VCR Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
