Question about Maytag SAV4655A Top Load Washer
Washer leaking water from bottom
All of the hose connections seem to be secure; however, during the spin cycle water comes out of the bottom of the machine Most of the water seems to drain through the the drain hose, but we are still getting puddles underneath the machine. My Maytag MAV7600 is leaking during spin and agitation cycles. It appears to be dripping from the metal housing that mounts the black plastic tub. I tore everything down and thoroughly inspected the parts/assemblies except the transmission. Is there some seal inside the shaft that could be leaking that is replaceable? My transmission is still under warranty, if that could be the problem, it just costs a lot to have someone come in and replace it under warranty During the spin cycles my Maytag washing machine throws water over the top of the tub. (worked fine for about two years; now it's doing this) I replaced the seal around the roof of the tub but it's coming over the top! Machine seems level.
  • 248 Answers
SOURCE: Washer leaking water from bottom
Probably a main tub seal, big job!
Posted on Nov 16, 2007
0 characters
1 Points
My GE washer leaks water during spin cycle only, seemingly from bottom of valve(?) where water hoses hook up, hoses look to be in good shape, only a year or so old.
If it is leaking at where the drain hose comes out of the wash machine, make sure the plastic spider clamp is seated securely in the groove on the drain hose. If that's not it, then, yes, you'll need to open up your washer to gain access to the inside of it. I don't know which model GE wash machine you have, but most of the GE top loaders can be opened by following the instructions in this youtube video:
Oct 19, 2014 | Washing Machines
Washer is leaking during rinse/spin cycle
What is the model number of your unit?
Nov 23, 2012 | Washing Machines
Washer seems to be leaking during spin cycle.
If the water is gushing from the washer, check the small plastic air dome hose on the lower right hand side of the wash tub. Sometimes the hose can come loose and come off. This will cause the water to begin pouring out of the bottom of the the washer when it begins to fill. The following link has some other things you may consider as well:
The link explains how to remove the exterior washer case in order to accurately inspect the washer interior components for the source of your leak.
Another common source of leaks with Whirlpool manufactured top loaders is a leaking drain pump. These pumps are not serviceable and if damged, must be replaced. The following link explains how:
Don't forget to check all drain hose connections under the washer and the center tub seal.
Replacement parts (if required) can be purchased at any of the following websites:
Prices vary between sites, so shop and compare. the first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
If you have any questions, please post back and let me know. I hope this helps you.
May 07, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer does nothing during rinse then leaks during spin cycle
hi thanks for the question i would check the drain hose your problem is the washer is not draining check the drain hose thanks the appliance doc
Sep 27, 2008 | Maytag Atlantis MAV6000 Top Load Washer
looks like you have to replace the RUBBER SEAL thats inside the tub at the center post , try this , remove the panel so you can see inside , put the washer to fill w/ water , and watch closely underneath the tub wheres the transmision is connected , and watch for LEAKS . hope this info helps
Apr 22, 2008 | GE WBSR3140DW Top Load Washer
Whirpool Front Loading HE (GH9400PW4) washer is leaking! Hellllp!
remove the bottom acesss panel and run through drain/spin cycle youll see where the leak is then. perhaps debis has puntured drainline hose or pump housing is leaking
Mar 02, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Nov 16, 2007 | Maytag MAV7600 Top Load Washer
Leak from maytag top load coin machine during spin drain cycle only
Possible that you would have a tub seal leak if it is only noticable during spin cycle. Possible that it "drips" slightly while in agitation, but not enough to notice it. While in spin mode you have a lot more parts moving as well as a lot more water pressure on the seal itself. Pump could also be leaking, but highly doubtful since it would leak a constant amount at all times. Good Luck!!! Jim
Sep 07, 2007 | Maytag MAT13MN Top Load Washer
Amana LWA50AW Washer Leaks!
you need to get the front off... grap a light and get down and look inside to find out whats leaking... with out looking its just guessing check all water hose connections, water pump, and main seal where transmission goes thu drum
Sep 05, 2007 | Amana LWA40A
You may want to check the seal at the bottom of the agitator, there is a o-ring that keeps the water in the drum from leaking through the agitator as it spins. This is a cheap seal and will wear over a period of time from exposure to bleach and detergent. You need to take the agitator apart and remove it from the drum and you should see this seal at the base of the agitator were it meets the drum.
Replace the seal and reassemble, take the metal casing off the washer and fill the drum with a little water, wait, and see if the water is leaking under the drum. If no leak, try to reassemble and run the washer. If is still leaks then check
Yours Truly,
Jul 30, 2006 | Maytag Atlantis MAV6000 Top Load Washer
Maytag SAV4655A Top Load Washer Logo
204 people viewed this question
Top Maytag Washing Machines Experts
Richard Roth
Richard Roth
Al Clark
Todd Marr
Todd Marr
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
