Question about Brother IntelliFAX 1570MC Plain Paper Fax
Error when fax get on it gives maintaince 7 error
0 characters
1 Points
Error 0548H Ricoh fax 4420L
Fuser Error. Check fuser thermistor. reset fuser error. Go to Service Mode press 1 0 7 , clear/stop , 1 copy, 5 mode, ok, 810, ok, change to 1, press half tone and ok simultaneously. fax will rebook automatically and fuser error is reset.
Jun 20, 2015 | Ricoh Fax Machines
Panafax uf-895 faxes, won't print. Put a new toner in, gives message 021
Error 021 relates to the Fuser unit (the bit that gets hot inside).
It is not related to the toner, which is a bit strange, but try switch off/on first.
Failing that you may need to clear the error in service mode. To access this:
Press "Function", "7", "Monitor" four times, then "*".
The machine should be saying "Service Mode"
Then press "7"
The machine should say "LBP Parameter Set"
(not 100% about the next bit but it should be reasonably straightforward to follow the display on the machine)
You are looking for "LBP Fuser Reset"..I think it is this:
Press "2" for "LBP Fuser Reset"
Press "Start"
The machine may reboot at this point.
If this is done correctly and the error still remains, the Fuser Unit will need replacing.
Sorry to be a bit vague on the instructions..not worked on these for a few years :)
Jun 19, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
Error light blinks
If I am not mistaken:
Press "menu" or "Function"
then go to last item, either 7 or 8, it should be Factory reset function
Press SET
and the machine is cleared.
Good Luck.
Mar 10, 2009 | Samsung SF-3100 Plain Paper Inkjet Fax
I can't fax,I dial the number and the other end don't pick it up,thay have been getting faxes all day?
Nov 03, 2008 | Fax Machines
Press the following keys:
monitor key slowly 4 times
scroll down to SHIPMENT SET
Wait for the fax machine to reboot.
Oct 21, 2008 | Panasonic Panafax UF-490 Plain Paper Laser...
Message in memory 32%
Unplug the power cord.
Hold down the ENERGY SAVER key while plugging in the power cord.
Scroll down to ALL JOB CLEAR
Press SET
Wait for the machine to reboot.
press the MONITOR key slowly 4 times
press *
press 6
press SET
Wait for reboot
Oct 14, 2008 | Panasonic Panafax UF-790 Plain Paper Laser...
Can not fax any document
when machine clear this problem may be solved, First you make setting as i said to machine. Press buttons respectively as i written function 9 * 8 # 7 then start button , it gives DIAG MODE then press satrt, With the help of star button go to memory clear and press start key. machine cleared memory, gives printing of MEMORY CLEARED. this setting will solved your problem.
May 07, 2008 | Sharp UX B700 Plain Paper Inkjet Fax
Lexmark all in one 5470 printer/fax
The only thing to tell you is go through your menu to your fax settings and make sure all of your choices are set right. Make sure it is on auto not manual for sending.
Oct 17, 2007 | Fax Machines
How to get fax reports
Your only option is to have it print out automatically after every 32 transactions, print out after every transaction, or print out only when there was an error with the transmission.
That parameter is Comm Journal and you can get to it by going to Function 7, option 4. That should give you a fax parameter table. You want options 12 and 13. Set 13 to "1" if you want it to print out every 32 transactions. Set that to "2" if you don't.
Set 12 to 1 for Comm Journals Off, 2 for Always, and 3 for Incomplete Only (errors).
Oct 02, 2007 | Panasonic Panafax UF-490 Plain Paper Laser...
Brother IntelliFAX 1570MC Plain Paper Fax Logo
19 people viewed this question
Top Brother Fax Machines Experts
Paul King
Paul King
john archer
Are you a Brother Fax Machine Expert? Answer questions, earn points and help others
