LOT OF MONITOR
I need LOT of 56 V samsung monitor No. FQM15A009
Color wheel
hello sir you can go to this web site www.discount-merchant.com
overthere they have color wheels and a lot of parts that you could need for your tv. Ness
Dec 24, 2009 | Samsung DLP HL-P5663W 56" TV
Dlp hum sounds like the color wheel, have the same thing
Sansui DTV1300 lot remote need to change change, but the up down arrow is skipping channels
Dec 21, 2008 | Samsung DLP HL-P5663W 56" TV
SAMSUNG 56 V MONITOR DOES NOT TURN ON
1. change the 7805 reguletor ( cheak o/p voltage 5V comming or not )
2. solder the dry points in proccer , cristel
3. dry points in neck board.
Nov 17, 2008 | Computers & Internet
No power
replace dl605 a three legged IC used as a 12 volt rectifer
Aug 08, 2008 | SAMTRON 55V 15" CRT Monitor
Samtron 56V monitor
Its aproblem of command section.Check its components one by one.you can identify this section (the front panal buttons goes in this section and a ic in big size and pasted horizantally in the circuit).if the components are ok then change command ic with new one.This will solve your problem.
Jul 27, 2008 | SAMTRON 55V 15" CRT Monitor
Samsung 50" DLP TV
Since the lamp generates a lot of heat, the fans are continuously monitored for correct function. The owner's manual should show you the location of the fans. Make sure that the grills covering the fans are clear of dust and that the fans are clean. Sometimes dirt can cause the fan blades to slow down enough to trigger the safety alert.
Keep us posted.
Dan
Jun 27, 2008 | Samsung DLP HL-P5663W 56" TV
Not optimum mode 510v 17" LCD Monitor
well, you need to change the EEPROM on the AD board.
Mar 04, 2008 | Samsung 710V 17" LCD Monitor
Monitor some times gives shades with black
While 50 inch dlp samsung is on, 6 inch black line on left side of screen. This is the second time this has happened. The first time it happened then the lamp blew......do I need to replace the lamp again?
Feb 19, 2008 | Samsung DLP HL-P5663W 56" TV
Computers & Internet Logo
1,153 people viewed this question
Ekse
Alun Cox
