Question about Apple iPhone Smartphone
How do I get the cursor between letters?
So I've been told that I can move the cursor from just the end of a line to anywhere I want when I'm typing some text, but I can't for the life of me figure out how.
  • 47 Answers
Hi there, this is a fairly easy follow this link http://www.apple.com/iphone/fingertips/ the one you want is no.7 it will show you exactly what to do.. pretty useful tips on there too.
hope it helps
Z33m
Posted on Dec 07, 2007
SOURCE:
How do I use alphabet keys on remote
Generally, entering text is carried out the same way as with most cell phones.
  • 0, 1, 2, 3, 4, 5, 6, 7, 8, 9: Enter a character to the position pointed by the cursor.
    • First press: enter the first character from a set of characters related to this button. Each subsequent press: you may change the entered character to the next one from this set.
    • 0: enter the space.
    • 1: enter a special character (punctuation marks, etc).
      • Up, Down, Left, Right after pressing 1 (special character entering mode): select the required character.
  • ENTER: confirm selection; finish text entering.
  • SUBTITLE: enter the period (for numeric mode); functions like button 1 (character mode).
  • CLEAR (<-): delete a character to the left of cursor.
  • SELECT (cap'num): switch input mode:
    • abc: character mode, small latin letters.
    • ABC: character mode, capital latin letters.
    • 123: numeric mode, digits.
  • RETURN: cancel the text changes and finish text entering.
  • Left/Right: move the cursor one character left/right.
  • Up/Down: move the cursor to the start/end of a text line.
    • If the cursor is already in start/end position: select another user interface element which is under/over the current text entry area (only for dialogs with several elements of user interface; text changes are confirmed automatically).
  • POP UP MENU: show context menu with a list of available commands. They allow you to cut, copy and paste text using the clipboard, much like it is done on a PC.
  • http://electronicshelponline.blogspot.com/
Jun 26, 2016 | Televison & Video
Laptop keyboard does not type inline. It types the correct letters anywhere on an email and web page (where typing is required), any place it wants, not after the last letter typed to make a sentence.
I've had this happen to me when I drag a thumb across the touchpad. Watch where the cursor is while typing and see if it moved because of inadvertent swipes on the pad. For me, the typing cursor looks like a pipe character ' If that's not what you mean, please clarify.
If it's the touchpad swipes causing the problem, you can adjust the sensitivity in the control panel. In addition, you can attend Ms Bilby's typing class and keep you wrists high or get a scolding ;)
Thanks
Oct 30, 2014 | Acer Aspire Computers & Internet
Problem with text cursor
Check the issue in safe mode. If the issue not present in safe mode,Try calibrating the touch pad.Also try creating new admin account and check the issue.
Aug 18, 2009 | Dell Keyboard for Inspiron 1420, 1520,...
Cursor randomly jumping to last occurance of a letter
it is not a problem with your cursor, i think you didnt install the TOUCHPAD program of your Laptop that is why its jumping anywhere, install it to control your cursor on the screen.
Jul 21, 2009 | Sony VAIO VGN-NR220E/S Notebook PC
Cursor not moving when I type
try other programs to see if it works fine there. it could be an issue with the web browser. if you are using Internet Explorer, try using Mozilla FireFox. It is more secure and really easy to use. goto getfirefox.com to get it.
If you need further help, reach me via phone at https://www.6ya.com/expert/jarrad_11786570be7a2abd
Jun 10, 2009 | Dell Latitude D820 Notebook
Changing the Cursor Appearance
I had this same problem on my TI 89... You must have accidentally set your calculator to insert mode. To switch it back to the thin cursor, input the following keystrokes... Go to the "2nd" key to enter second function mode. Then press the button with an arrow on it pointing to the left(The key that you use to backspace). Do you see the "INS" lettering above the backspace key? There's your solution :-)
Apr 07, 2009 | Texas Instruments TI-89 Calculator
Emachines Keyboard Model No. KB0511
Here you go:
Enter
The computer brings the cursor to the beginning of the next line. This key can also be pressed
to open a program after you have HILIGHTED* it. It will execute a command.
Shift ▲ Hold the shift key down and press the letter key you want to make a CAPITAL letter.
This key is also used to type the charters at the
top of some keys. Eg: Shift + 1 = ! or Shift + 2 = @
Caps Lock
Makes all letters CAPITAL letters. When the Caps Lock key is pushed, a light will
show up on the upper right corner of your keyboard
next to the capital “A”. When caps lock is turned on it remains on until you press the Caps Lock key
again. When you press the Shift key when
Caps Lock is on, a lower case letter will be produced.
Space This key places one space every time it is pressed. (The long, unlabeled key at the
bottom center of your keyboard).
←Backspace Deletes the character to the left of the cursor each time you press it. (If you hold it
down it will continue to delete so be careful).
Delete Deletes the character to the right of the cursor each time you press it.
Home Brings you to the beginning of the line the cursor is on.
End Brings you to the end of the line the cursor is on.
Esc Located in the upper right corner of your keyboard. Cancels an incomplete command;
it will also close an open menu.
Moves the cursor to the left one space each time it is pushed; does not delete the
character.
Moves the cursor up one line each time it is pushed; does not delete the character.
Moves the cursor to the right one space each time it is pushed; does not delete the
character.
Moves the cursor down one line each time it is pushed; does not delete the character.
Insert Deletes the character to the right of the cursor and replaces it with whatever is typed on
the keyboard.
↔Tab Moves the cursor to the tab marks and between columns.
Shift + print screen Prints what is on your computer screen.
Highlight (to select) To make the item stand out. To choose or select it.
? *When an icon is highlighted (left click the mouse button one time while the cursor is pointing at
the icon), the program has been chosen and the name of the icon will change color. When this has
happened, you may press the Enter key to open the program.
? *To highlight a character or characters, move the cursor, using your mouse or the arrow keys, to
the left of the item you wish to select. Press the left mouse button and hold it down while you
move the mouse to the right. Let go of the left mouse button and your item(s) should be
highlighted. Then you can choose what you want to do to the selected item(s) e.g. bold, underline,
delete, italicize, etc.
“Drag and drop” Move the cursor to the item, click the left mouse button and hold it down.
Move the mouse, while holding down the left
mouse button, to the location you want to move the item. Let go of the left
mouse button.
Cursor - The arrow on your screen. The mouse is used to move the cursor.
Let me know if this helped
Jan 02, 2009 | E-Machines eMachines Desktop PC
Over sensitive touch pad, causes cursor to jump all over the LCD
Try control panel and double click the mouse icon then settings you can adjust sensitivity there
Dec 28, 2008 | Sony VAIO FRV25 Notebook
Letter writting problems
Do you use a laptop or some sort of keyboard with a mouse pad? My son used to have that problem when he would type as his thumb would accidentally hit the mouse pad and move the cursor. We solved it in a very low tech way by taping a notecard over the mouse pad when he was using the computer. Depending on the manufacurer, there are ways to turn off the mouse pad while continuing to use a mouse.
Dec 24, 2007 | Microsoft Digit Media Pro bx100005...
Apple iPhone Smartphone Logo
161 people viewed this question
Top Apple Cell Phones Experts
Ekse
jacobcheatha
Level 1 Expert
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
