Question about Fujitsu Plasmavision P42HHA10 42 in. Television
Power shuts off and blinks red .
Tv is plugged into a monster power supply with surge protector. have to unplug the plasma nd wait for about 5-30 min. before you can turn it back on. plasma is about 4yrs. old
  • 4 more comments
  • yodude Feb 05, 2008
    mine is about the same age and is doing the same thing....???????????
  • Beauxdahba Feb 26, 2008
    I have the same plasma with the same problem.
  • Anonymous Mar 07, 2008
    This has been a problem for over 2 years. I have burnt out 2 power supplies. The problem continues.
  • connorzack Nov 14, 2008
    Same TV, same problem, same approx age??? I can only turn it on at the main power button, LED goes solid red for a few seconds, solid green for a few seconds, then blinks a constant red. I can only turn it off using the manual power button.
  • Anonymous Mar 16, 2009
    power shuts off and blinks red also had a problem could watch dvd but not television
  • Anonymous Mar 18, 2014
    It's working and then shut down suddenly. I tried to power up by manual but it didn't work. I unplugged it and waiting until next morning to plug it in and trying to power up again but there is no power at all. Is that the power supply board problem?
  • 534 Answers
For information:-
I have recently fixed my P42HHA10AS 42" plasma which had a similar problem.
Would run ok for periods, (sometimes 30 mins, sometimes 2+ hours), picture perfect. Then it would randomly fail - with loss of picture, then shutdown. Front panel led indicator goes from green (normal) to flashing red continuous.
After switch off, removal and re-application of power it would often re-start and run normally for a while.
Sometimes it needed to be allowed overnight to cool before it would run again.
I also noticed that the failures generally coincided with any change to the screen display mode or input mode settings.
Fujitsu service supplied service manual and Service Bulletins regarding this problem :-
Service Manual P42HHA10 is available at http://www.eserviceinfo.com/download.php?fileid=41950
Service Bulletin PDP 0040-01 Main Digital pcb see http://www.eserviceinfo.com/download.php?fileid=43455
Service Bulletin PDP 0068-01 Main Digital pcb see http://www.eserviceinfo.com/download.php?fileid=43450
Service Bulletin PDP 0035-06 Main Power pcb see http://www.eserviceinfo.com/download.php?fileid=43471
Worked through the service manual checks (service manual very basic- overview / DC voltages only - assumes availability of replacement modules). The troubleshooting flow charts lead you nowhere helpful.
Could find no fault with the power board, except that the 6.5V(nominal) was actually 7.4V at CN351 Pin12.
Added 2x Schottky diodes (1Watt) in series with the transformer 6.5V output winding - this lowered the output voltage to 6.6V. - However, this made no difference to the continuing fault condition.
This units problem was fixed on implementation of Service Bulletin PDP 0068-01 Main Digital pcb.
No other faulty components were found.
The mounting solder on the main processor socket was cracked on one corner at the pcb mount point. (See last picture in PDP 0068-01, page 2)
Re-soldered same, and the set has worked faultlessly since.
I became convinced over time that the fault was to do with the main processor board, as the failures were so random, and the set would otherwise run perfectly.
This fault is caused by a combination of solder fatigue, vibration and the thermal cycling of the pcb over time.
I expect it is a cause of many of the reported problems experienced on these Fujitsu panels.
I suggest that the above work should only be attempted by suitably skilled person/s, as very fine soldering and knowledge of electronic pcb repair techniques are required.
Good luck.
Posted on Aug 21, 2009
I had a similar problem, but mine didn´t switch on when pressing on button, I had to take the back cover off and hit the relays, it seems they get stuck, and are difficult to find to replace them. Now it has been working during almost a year with no problem at all. Mine is 4 years old.
Posted on Apr 08, 2008
It is something to do with the power pack / transformer which needs replacing.
Posted on Feb 26, 2008
SOURCE:
My plasma tv won't turn back on after a power outage???
First, unplug the TV, wait 30 seconds to 1 minute, then plug back in & try it. This allows the unit to reset.
Be sure you AC outlet breaker has not tripped.
could also be the TV fuse or power supply PCB.
You should be sure to put a good surge protector in line with this TV as these constant surges are going to severely shorten the life of the unit.
Jul 24, 2014 | Televison & Video
I purchased a Panasonic TC-P50s30 50" Plasma TV
You did a good thing; really!! Keep that TV aside you always.
Jul 11, 2017 | Panasonic 50 in. Plasma TV
RED LIGHT KEEPS BLINKING..WAS LIKE A POWER SURGE THIS MORNING..I UNPLUGED TV OFF MOSNTER SURGE PROTECTOR..CAME HOME AND PLUGED BACK IN...TV RED LIGHT TV REC STILL BLINKING
Surge protectors aren't perfect... If the surge was big enough and long enough then it can cause problems. Most manufacturers have on-board protection as well. That's not perfect either. Often the surge does nothing more than confuse the microprocessor (computer) that controls all aspects of your television. The fact that the red light is blinking means that your set is trying to protect itself. This can happen for one of two reasons. Something in the set has failed. Usually the power supply inside the set possibly also a trouble in the scan section of your set. These are normally a shop repair. The other thing is when the microprocessor is confused it will do nothing further until it's reset. To reset the processor simply unplug the set from the wall and wait 10 minutes. Plug it back in and if it works then happy viewing. If it doesn't then you will need a repair.
If is a failure caused by a failure in the grid that delivers power to your set then you are usually able to file a claim for the repairs. Contact your local power company. explain what happened. If it's their fault then usually they will pay for a repair. I know the PG&E does.
Zashiban
Jun 23, 2010 | Toshiba 42LX196 42 in. LCD HDTV
2003 Sony Trinitron 36" television. Just shut off, light blinkin
The STANDBY light will flash if the television detects an issue within the television. Some of these issues can be resolved simply by following the steps below to reset the television.
If the issue is still unresolved after following all of the troubleshooting steps, Service will be required. Please note the number of times the STANDBY light flashes and relay that information to the service center.
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
Sep 14, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Sony KV-34HS420 shuts of and stand-by light blinks
If the issue is still unresolved after following all of the troubleshooting steps, service may be required. Please note the number of times the STANDBY light flashes and relay that information to the service center.
Source
Sep 01, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Replacing the exhaust fan on a KDS-R60XBR1
4 times blink shows problem of fans not running or connector of fan is not attached properly.
Please recheck the things what you removed during fan replacement and make sure all that is mounted and connected securely.
Feb 13, 2009 | Sony KDS-R60XBR1 60" Projection HDTV
My wii won't turn on
You likely had a power failure. You need to reset your AC adapter. Here's how:
  1. unplug the power cord from the wii. Unplug the adapter from your surge protector or the power outlet.
  2. wait 90 to 120 seconds. (Some people say to wait 30 seconds. Wrong! At least 90 secs is required for the AC adapter to rest.
  3. plug stuff back in and you're good to go.
NOTE: electronics like your wii, ps3, etc should be protected from power surges and power failures! Plug them into a good surge protector. Always!
Jun 27, 2008 | Nintendo Wii Console
Tv won't turn on
I suggest you unplug the set for about 15 minutes and then plug it in and try again. Sounds like you may have had a power surge/bump in the middle of the night. Althoguh you are using a surge protector, doesn'r mean the devise hooked to it can't lock up during a power surge.( Surge Protectors are an insurance policy only, not a garrentee ). If unplugging the set and waiting doesn't fix it, it will need to have the power supply section of the board repaired. Good Luck
Ed
NC Electronic
Mills, Wyoming
Jan 06, 2008 | Protron PLTV-32 Television
Fujitsu Plasmavision P42HHA10 42 in. Television Logo
561 people viewed this question
Top Fujitsu Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Fujitsu Televison and Video Expert? Answer questions, earn points and help others
