Question about Seagate Barracuda 7200.7 ST380011A 80 GB Hard Drive
Strange problem I have a seagate 320 GB barracude HDD SATA 1 7200 RPMi have no problems using the drive while work on the system but when i do a disk intensive activity like Gaming , DVD converting or anything which involved lots of disk activity it shut off automatically i doesnt give any error messege no warnings or anything else i tried changing the sata ports all 4 ports give me same issue at varying intervals SATA 1 does it immediately and SATA 3 after some time but it happens regularly .i have tried upadating the drivers but nothing has worked for me Yet i ll be grateful for a solution.
  • 871 Answers
Re: Strange problem
have you tried putting a fan for the hard drive? although it may sound strange, auto shutoff happens in rare times.
i had this harddrive before that also had this problem, but eversince i transfered my pc to my moms room( airconditioned), ive noticed it doesnt have that problem anymore.
hope this helps.
Posted on Jan 22, 2008
0 characters
3 Points
How to upgrade ST380011A 80GB seagate hard disk to 500GB
First you check your Hard Disk connectivity type SATA or IDE. Then purchase same type of connectivity Hard Disk as your wish. Seagate Desktop internal Hard Disk Available in market (160 GB, 250 GB, 320 GB, 500 GB, 750 GB, 1 TB, 1.5 TB, 2 TB, 3 TB).
Nov 20, 2012 | Seagate Barracuda 7200.7 ST380011A 80 GB...
My seagate 320 GB hard disk is not gettin detected
my hard disk was 320GB bu that displayed only 298gb shall i no that reason
Aug 02, 2010 | Seagate Barracuda 7200.10 320 GB SATA Hard...
Windows xp will not recognize my seagate barracuda 7200.10 although it is recognized in the BIOS. I pressed f6 during setup and it is asking about the Manufacturer-suplied hardware support disk. Where...
If you have one HDD set it to master with your jumper settings. Try again. If No go than change the cable connector. If SATA HDD than change the connector on the MOBO try another connector. Restart. If still no go than write back
Jul 30, 2009 | Seagate Barracuda 7200.10 320 GB SATA Hard...
P4m80-m4 mobo not detecting SATA hard drive
go to bios setup,thn go to advncd settings thn u have to change the settings for hdd from ide to sata mode
Jul 23, 2009 | Seagate Barracuda 7200.10 320 GB SATA Hard...
Troubling in sata connection
  • I suppose there is a jumper(beside the power pin) on your new HDD,
  • if its true the your HDD supports 3GB/s mode but your motherboard does not .
  • So place the jumper on the HDD on 1.5GB/s combination.
  • Disconnect the 80 GB,
  • Connect the new HDD,
  • Boot from any bootable xp or vista or any disk tool like erd commander and try to format the new HDD.
  • Then connect the new HDD and boot from it.
Tell me what happened.
Jan 31, 2009 | Seagate 20PK 320GB SATA 3GB/S 3.5 7200RPM...
Trying to repair windows xp on a Seagate Barracude 7200.7 160gb SATA HDD
Can you pleae be a little more explicit? What is the make & model of your computer? What kinds of repairs are you trying to do? What kinds of errors or symptoms are you experiencing?
Jan 19, 2009 | Seagate Barracuda 7200.7 160 GB Hard Drive
Sata drive not detected
just no other solution except upgrading BIOS properly
Sep 24, 2008 | Seagate Barracuda 7200.10 500 GB SATA Hard...
there is a problem in your power supply, one of the capacitors maybe busted, it also happened in one of my computers, that is one of the most problems in computers specially when you used this for a long period of time. try to replace this with a new one.
Nov 29, 2007 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Seagate Barracuda 7200.7 ST380011A 80 GB Hard Drive Logo
130 people viewed this question
Top Seagate Hard Drives Experts
Brian Sullivan
Brian Sullivan
Michael Thomas
Michael Thomas
Are you a Seagate Hard Drive Expert? Answer questions, earn points and help others
